QTM750P-150.000MBE-T
    QST(矽睿)
    SMD-6
    有源晶振 3.3V 150MHz SMD-6
QTM750P-150.000MBE-T 数据手册
QTM750P MHz LVPECL Oscillator Fuel The Digital World Features ● ● ● ● ● ● ● ● Applications Frequency range : 25MHz to 312.5MHz SMD seam sealing ceramic package Supply voltage : 2.5V, 3.3V LVPECL output Low phase noise and phase jitter Tri-state function available External dimensions (mm) L : 7.0 x W : 5.0 x H : 1.4 RoHS compliant & Pb free ● ● ● ● ● Networking, Telecommunication, Data communication, Switch, Server, Storage Fibre channel, Ethernet, SONET, SATA, SAS, PCI-Express Optical module Microprocessor, DSP, FPGA, Clock source for ADC and DAC Test and measurement Electrical Characteristics Item Frequency Range (F0) Frequency Stability (Fstab) over Operating Temperature Range (T OTR) QTM750P Conditions 25MHz ~ 312.5MHz ±50ppm, ±25ppm -40°C ~ +85°C, Note [1] ±50ppm -40°C ~ +105°C, Note [1] -40°C ~ +85°C Operating Temperature Range (T OTR) -40°C ~ +105°C Supply Voltage (VDD) 2.5V, 3.3V Current Consumption (IDD) 70 mA Max. Output Type LVPECL Output Load 50 Ω (VDD - 2.0V) Output Voltage High (VOH) VDD - 1.025 Min. Output Voltage Low (VOL) VDD - 1.62 Max. Rise & Fall Time (Tr / Tf) 0.6 ns Max. Duty Cycle 45% ~ 55% Start-up Time 5 ms Max. Enable Voltage High, Logic "1" 70% VDD Min. Enable Voltage Low, Logic "0" 30% VDD Max. F0 = 156.25MHz 100fs ~ 300fs Max. F0 = 312.5MHz 70fs Typ. / 100fs Max. Phase Jitter VDD ± 10% 20% ~ 80% of output swing Input to OE pin Note [2] 12kHz ~ 20MHz, RMS Aging (Faging) ±3 ppm Max. Storage Temperature Range (T STR) -55°C ~ +125°C Rev. 1.01 Page 1 at 25°C±3°C, first year www.qstproducts.com QTM750P MHz LVPECL Oscillator Fuel The Digital World Notes: [1] Inclusive of frequency tolerance at 25°C, variations over temperature, supply voltage and vibration. [2] Output will be enabled if OE is Logic "1" or Open; Output will be disabled if OE is Logic "0". [3] The standard testing environment except temperature test is 25°C±5°C, 40%~70% relative humidity. Dimensions Pin function Pin 1 OE Pin 2 NC Pin 3 GND Pin 4 OUT Pin 5 OUT VDD Pin 6 Recommended pad layout (Unit: mm) * Pad dimension tolerance is ±0.2mm * Power supply decoupling capacitor is required. Ordering Information QTM750P - 156.25M B E - T Packaging Method Frequency in Hz T Please contact us for available frequencies Tape & Reel Frequency Stability Supply Voltage B C Rev. 1.01 E D G 3.3 V 2.5 V Page 2 ± 50 ppm ( -40°C ~ +85°C ) ± 25 ppm ( -40°C ~ +85°C ) ± 50 ppm ( -40°C ~ +105°C ) www.qstproducts.com QTM750P MHz LVPECL Oscillator Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min., 200 sec. Max. Peak temperature : 260°C ± 10°C, 10 sec. Min., 30 sec. Max. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.01 60 sec Page 3 Time (sec) www.qstproducts.com
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,包括输入侧的发光二极管引脚和输出侧的晶体管引脚。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信设备、工业控制等领域。
7. 封装信息:EL817采用DIP-6封装形式。
QTM750P-150.000MBE-T 价格&库存
很抱歉,暂时无法提供与“QTM750P-150.000MBE-T”相匹配的价格&库存,您可以联系我们找货
