LFXTAL069377REEL
LFXTAL069377REEL
    IQD
    SMD3225_4P
    无源晶振 32MHz ±20ppm 18pF 40Ω -40℃~+85℃
LFXTAL069377REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL069377Reel Customer Part: Description Standard 3.2 x 2.5mm SMD crystal in a ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPX-180 Model Issue number 10 Frequency Parameters Frequency 32.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±20.00ppm @ 25°C ±30.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±5ppm max per year @ 25°C Electrical Parameters Outline (mm) 18.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 40.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: MIL-STD-202F, Method 213B: 1000G, 0.5ms, 1/2 sine wave Vibration: MIL-STD-202F, Method 204D, Test Condition D: 20G (10Hz-2000Hz), 4hrs in 3 mutually perpendicular planes (total 12hrs) Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 5 Dec 21 4:12 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL069377REEL
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚门极,6脚集电极。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装。
LFXTAL069377REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL069377REEL”相匹配的价格&库存,您可以联系我们找货
LFXTAL069377REEL
    • 1+8.12160
    • 200+3.24000
    • 500+3.13200
    • 1000+3.07800
