QT532S-36.000MEEQ-T
QT532S-36.000MEEQ-T
    QST(矽睿)
    SMD-4
    无源晶振 40Ω 10pF 36MHz ±10ppm -20℃~+70℃ SMD-4
QT532S-36.000MEEQ-T 数据手册
QT532S MHz Crystal Fuel The Digital World Features ● ● ● ● ● Applications Frequency range : 8MHz to 125MHz Ceramic SMD package Seam sealing External dimensions (mm) L : 5.0 x W : 3.2 x H : 0.9 RoHS compliant & Pb free ● ● ● ● ● Bluetooth, Wireless LAN Cellular phone, Pager, DSC Display, TV Computer peripherals Consumer products Electrical Characteristics Item QT532S Frequency Range F0 8MHz ~ 125MHz Frequency Tolerance Ftol ±30ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Fstab Operating Temperature Range TOTR ±30 ppm ±10 ppm ±30 ppm -20°C ~ +70°C -40°C ~ +85°C Shunt Capacitance C0 5pF Max. (2pF Typ.) Drive Level DL 1 ~ 200μW (100μW Typ.) Load Capacitance CL 10pF, 12pF, 18pF, 20pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -40°C ~ +85°C at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 80Ω Max. 40Ω Max. 8 ~ 11 MHz 12 ~ 54 MHz 3rd Overtone 40 ~ 60 MHz 60 ~ 125 MHz Rev. 1.04 120Ω Max. 80Ω Max. Page 1 www.qstproducts.com QT532S MHz Crystal Fuel The Digital World Dimensions Ordering Information QT532S - 8.000M - A A J - T Frequency in Hz Packaging Method Please contact us for available frequencies T Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A E ± 30 ppm ± 10 ppm Q E J K 10 pF 12 pF 18 pF 20 pF Frequency Stability (over Temp.) A E H Rev. 1.04 ± 30 ppm ( -20°C ~ +70°C ) ± 10 ppm ( -20°C ~ +70°C ) ± 30 ppm ( -40°C ~ +85°C ) Page 2 www.qstproducts.com QT532S MHz Crystal Fuel The Digital World Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.04 60 sec Page 3 Time (sec) www.qstproducts.com
QT532S-36.000MEEQ-T
物料型号:QT532S MHz Crystal
器件简介:QST品牌的QT532S是一款用于数字世界的晶体振荡器,提供8MHz至125MHz的频率范围,采用陶瓷SMD封装,具有密封接缝。
引脚分配:文档中提供了晶体振荡器的顶视图和侧视图,但没有明确列出每个引脚的功能。
参数特性: - 频率范围:8MHz至125MHz - 频率容差:±30ppm或±10ppm(25°C时) - 频率稳定性:在-20°C至+70°C范围内为+30ppm,在-40°C至+85°C范围内为±30ppm - 工作温度范围:-20°C至+70°C - 负载电容:10pF, 12pF, 18pF, 20pF - 老化率:首年最大±3ppm - 存储温度范围:-55°C至+125°C
功能详解:文档中未提供详细的功能解释,但晶体振荡器通常用于为电子设备提供稳定的时钟信号。
应用信息:适用于手机、寻呼机、DSC、蓝牙、无线局域网、显示器、电视、计算机外围设备和消费产品。
封装信息:晶体的外部尺寸为长5.0mm x 宽3.2mm x 高0.9mm,符合RoHS标准,无铅。
QT532S-36.000MEEQ-T 价格&库存
很抱歉,暂时无法提供与“QT532S-36.000MEEQ-T”相匹配的价格&库存,您可以联系我们找货
