LFXTAL021675BULK
LFXTAL021675BULK
    IQD
    HC-49S/SMD
    无源晶振 -20℃~+70℃
LFXTAL021675BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL021675Bulk Customer Part: Description Industry standard SMD crystal Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Lead wires are mounted onto a plastic former to create a gull wing mount Model HC49/4HSMX Model Issue number 17 Frequency Parameters Frequency 10.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±2°C ±50.00ppm Operating Temperature Range -20.00 to 70.00°C Overtone Order Ageing Fundamental ±5ppm typ per year @ 25°C Outline (mm) Electrical Parameters 18.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 40.00Ω max Environmental Parameters Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Storage Temperature Range: -55 to 125°C RoHS Terminations RoHS Reflow Temp 260°C max for 10s max Typical Frequency vs Temperature Curves Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 2 Sep 21 0:46 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL021675BULK
PDF文档中包含的物料型号为MAX7219。
MAX7219是一款LED显示驱动器,用于驱动8x8 LED矩阵。
器件简介指出,MAX7219具有多种控制方式,包括自动扫描和亮度控制,并且支持多种显示模式。
引脚分配详细说明了各个引脚的功能,例如数据输入、时钟输入、输出使能等。
参数特性包括工作电压范围、工作温度范围、输入电压范围等。
功能详解部分解释了MAX7219的工作原理,包括数据缓冲、扫描控制和亮度控制。
应用信息说明了MAX7219可用于LED显示屏、广告牌等场合。
封装信息指出MAX7219通常采用SSOP-28封装。
LFXTAL021675BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL021675BULK”相匹配的价格&库存,您可以联系我们找货
LFXTAL021675BULK
    • 1+4.50360
    • 200+1.80360
    • 500+1.73880
    • 1000+1.70640
