C2E-40.000-10-50100-X1-R
    AKER(安碁科技)
    SMD2520_4P
    无源晶振 40MHz 70Ω 10pF ±50ppm -40℃~+125℃ SMD2520_4P
C2E-40.000-10-50100-X1-R 数据手册
RoHS Compliant Pb - Lead Free AEC-Q200 Qualified Ltr Revisions Appr Date Electrical Specifications: Frequency Range 12.000 to 60.000 Fundamental 12.000 to 60.000 ±50 ±100 -40 to +125 -55 to +125 ±3 7 to 32 and Series Resonance 3.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc Mode of Oscillation Frequency Tolerance at 25°C Frequency Stability over Temperature Range Operating Temperature Range Storage Temperature Range Aging per Year Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 12.000 to 13.999 14.000 to 15.999 16.000 to 19.999 20.000 to 23.999 24.000 to 24.999 25.000 to 44.999 45.000 to 60.000 200 150 Fundamental Fundamental Fundamental Fundamental Fundamental Fundamental Fundamental 90 70 60 50 40 Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: May 1, 2017 Microprocessor Crystal Unit Automotive Temperature Range 2.5 x 2.0 millimeter Surface Mount General Product Specification Part Number: C2E X1 Series www.aker-usa.com MHz PPM Max ºC PPM Max pF Ohms uW Typ M Ohms Mechanical Outline: 2.5 ± 0.15 2.0 ± 0.15 #4 Ceramic Base Metal Lid #3 AKER #1 #2 0.65 Max. 0.9 1.65 #4 #3 0.575 0.7 #2:GND 0.9 #2 0.65 #1 1.225 1.0 #4:GND Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: May 1, 2017 P/N: www.aker-usa.com C2E X1 Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION AKER AKER AKER AKER AKER AKER AKER AKER A 3.4 Pin #1 A 8.0 3.5 B B 1.0 4.0 1.4 2.7 Dimensions millimeters. A-Aare SECTION Solder Reflow Characteristics: Page: 3/4 Date: May 1, 2017 P/N: www.aker-usa.com C2E X1 Series How to build a Part Number: Series Package C 2E Frequency 12.000 to 60.000 Load Capacitance 7 10 12 16 18 20 32 S Frequency Tolerance Frequency Stability 50 100 Temperature Range X1 Packaging M R R3 - - Parameter 2.5 x 2.0 mm MHz 7 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series ±50 PPM ±100 PPM -40 to +125 ºC 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: C2E-50.000-18-50100-X1-R C2E- 2.0 x 2.5 mm SMD Seam Seal Crystal Unit 50.000 MHz Nominal Frequency 18 pF Load Capacitance 50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability X1: -40 to +125° C Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Frequency Tolerance and Stability options are limited due to physical size. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape. 4- Specification subject to change without notice. Page: 4/4 Date: May 1, 2017 P/N: www.aker-usa.com C2E X1 Series
1. 物料型号:C2E X1 Series 2. 器件简介:Microprocessor Crystal Unit Automotive Temperature Range 2.5 x 2.0 millimeter Surface Mount General Product Specification 3. 引脚分配:#1 #2为引脚,#4 #3为地(GND) 4. 参数特性: - 频率范围:12.000到60.000 MHz - 振荡模式:基础模式 - 25°C时频率容差:±50 PPM最大 - 温度范围内频率稳定性:±100 PPM - 工作温度范围:-40到+125°C - 存储温度范围:-55到+125°C - 年老化率:±3 PPM最大 - 负载电容:7到32 pF和串联谐振 - 并联电容:3.0 pF - 等效串联电阻(ESR):见ESR表 - 驱动水平:100 uW典型值 - 绝缘电阻:500 MΩ(在100Vdc±15Vdc下) 5. 功能详解:文档详细描述了频率范围与ESR值的关系,以及如何构建部件型号。 6. 应用信息:适用于汽车温度范围的微处理器晶体单元 7. 封装信息:2.5 x 2.0毫米表面贴装,密封陶瓷金属封装
C2E-40.000-10-50100-X1-R 价格&库存
很抱歉,暂时无法提供与“C2E-40.000-10-50100-X1-R”相匹配的价格&库存,您可以联系我们找货
