SXT11410CB38-40.000MT
    SUNTSU
    XO-4P_1612(METRIC)
    无源晶振 100Ω 40MHz 10pF ±25ppm -30℃~+85℃ SMD1612_4P
SXT11410CB38-40.000MT 数据手册
Ceramic SMT 4 Pad Crystal SXT114 Series 1.6mm x 1.2mm Features Applications • ±10ppm/±10ppm (Tolerance/Stability) Available • Bluetooth • Ultra-Miniature Package • High Density Applications • Wireless LAN • AT-Cut Fundamental • Tape and Reel Part Numbering Guide SXT 11 4 12 A A 48 - 20.000M SUNTSU CRYSTAL FREQUENCY MHz 1.6mm x 1.2mm 4 PAD OPERATING TEMPERATURE RANGE** 07 : 0°C - +70°C LOAD CAPACITANCE FREQUENCY STABILITY 16 : -10°C - +60°C FREQUENCY TOLERANCE S : Series A : ±50ppm A : ±50ppm 17 : -10°C - +70°C COMPLIANT 8 - 12 : 8pF - 12pF B : ±30ppm B : ±30ppm 27 : -20°C - +70°C C : ±25ppm C : ±25ppm 38 : -30°C - +85°C D : ±20ppm D : ±20ppm 48 : -40°C - +85°C E : ±15ppm E : ±15ppm Cage Code: 4GUT4 F : ±10ppm* F : ±10ppm To customize your parameters contact a Suntsu representative. * For frequency stability option F contact a Suntsu representative. ** For operating temperatures of -55-125°C a Suntsu representative. Electrical Parameters Units Minimum Frequency Range MHz 24 54 AT-Cut Fundamental. Frequency Tolerance at +25ºC ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Op Temp ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Aging ppm -2 +2 First year @ +25ºC. Operating Temperature °C -40 +85 Storage Temperature °C -40 +95 Load Capacitance pF 8 12 Shunt Capacitance pF Drive Level µW Insulation Resistance ESR - 24.000MHz MΩ ~ Typical Maximum Remarks See part numbering guide for options. See part numbering guide for options. 3 10 100 500 @ 100VDC ± 15V. 29.999MHz Ω 150 AT-Cut Fundamental ESR - 30.000MHz ~ 54.000MHz Ω 100 AT-Cut Fundamental Outline Drawing & Recommended Landed Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad Crystal SXT114 Series 1.6mm x 1.2mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K Moisture Resistance MIL-STD-883, Method 1004 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Solderability MIL-STD-883, Method 2003 Reflow Profile & Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 3,000pcs / Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SXT114系列
器件简介:超小型封装AT-Cut基础晶体振荡器,适用于蓝牙无线局域网和高密度应用。
引脚分配:文档中未明确提供引脚分配图,但通常4脚晶体振荡器的引脚为两个电源引脚和两个输出引脚。
参数特性: - 频率范围:24MHz至54MHz - 频率容差:±10ppm至±50ppm,具体取决于型号 - 频率稳定性:±10ppm至±50ppm,具体取决于型号 - 工作温度范围:-40°C至+85°C,具体取决于型号 - 负载电容:8pF至12pF - 绝缘电阻:最小500MΩ(在100VDC±15V下) - ESR(在24.000MHz和29.999MHz):150Ω,(在30.000MHz至54.000MHz):100Ω
功能详解:文档中未提供详细的功能解释,但晶体振荡器通常用于为电子设备提供稳定的时钟信号。
应用信息:适用于蓝牙无线局域网和高密度应用。
封装信息:1.6mm x 1.2mm的超小型封装,适用于表面贴装技术(SMT)。
环境和机械规格:文档提供了温度循环、微漏测试、粗漏测试、振动、耐焊接热、耐溶剂等环境和机械规格。
回流焊曲线和部件标记:提供了回流焊温度曲线和部件标记的详细信息。
胶带和卷轴尺寸:提供了胶带和卷轴的尺寸信息,每卷3000个部件。
SXT11410CB38-40.000MT 价格&库存
很抱歉,暂时无法提供与“SXT11410CB38-40.000MT”相匹配的价格&库存,您可以联系我们找货
