PXETGLJANF-125.000000 数据手册
PX Type
3.2 x 2.5 mm SMD Crystal Oscillator
Actual Size
FEATURE
- Typical 3.2 x 2.5 x 0.95mm ceramic SMD package.
- Tight symmetry (45 to 55%) available.
- Operation voltage: 1.8V, 2.5V, 3.3V
- Tri-state enable/disable
TYPICAL APPLICATION
- Computer Peripherals
- Set-top Box , HDTV
- DSC, PDA
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
2.10 ± 0.15
#2
#2
0.65 ± 0.15
1.65 ± 0.15
2.50 ± 0.15
#1
#4
#1
1.60
#3
#3
1.10
3.20 ± 0.15
#4
0.1 μF
[ B O T T O M V IE W ]
[ TO P VIEW ]
2.10
0.90 ± 0.15
Pin#
0.35
0.95 ± 0.15
[ S ID E V IE W ]
1
2
3
4
Function
1.20
Tri-state
GND
Output
VDD
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
Parameter
Supply Voltage Variation (VDD)
Frequency Range
VDD Sensitivity (±10 %)
1 MHz Fo < 30 MHz
Supply Current
30 MHz Fo < 75 MHz
75 MHz Fo
PXETGLJANF-125.000000 价格&库存
很抱歉,暂时无法提供与“PXETGLJANF-125.000000”相匹配的价格&库存,您可以联系我们找货
