8W
MHz CMOS Oscillator
Features
Applications
Frequency range : 4MHz to 125MHz
Compact and thin
SMD seam sealing ceramic package
Supply voltage : 1.8V ~ 3.3V
CMOS output
Tri-state function available
External dimensions (mm)
L : 2.5 x W : 2.0 x H : 0.8
RoHS compliant & Pb free
Mobile phone, Wearables
Networking, Server, Storage
Wireless communications
Fibre channel, Ethernet, SATA, SAS,
PCI-E, USB, WLAN, BT
Notebook, HDD, SSD, Graphics card,
Computer peripherals
Audio, Video, Gaming, DSC, IP CAM,
Portable consumer products
Electrical Characteristics
Item
8W
Frequency Range (F0)
4MHz ~ 125MHz
Frequency Stability (Fstab)
±50ppm, ±25ppm
Operating Temperature Range (T OTR)
Supply Voltage (VDD)
Current Consumption (IDD)
1.8V, 2.5V, 3.3V
Output Load (CL)
15 pF
Output Voltage High (VOH)
90% VDD Min.
Output Voltage Low (VOL)
10% VDD Max.
Rise & Fall Time (Tr / Tf)
5 ns Max.
Duty Cycle
45% ~ 55%
Start-up Time
5 ms Max.
Enable Voltage High, Logic "1"
70% VDD Min.
Enable Voltage Low, Logic "0"
30% VDD Max.
Storage Temperature Range (TSTR)
VDD ± 10%
10 mA Max.
CMOS
Aging (Faging)
Note [1]
-40°C ~ +85°C
Output Type
Phase Jitter, RMS
Conditions
1 ps Max.
±3 ppm Max.
10% ~ 90% of VDD
Input to Pin1
Note [2]
Note [3]
at 25°C±3°C,first year
-55°C ~ +125°C
Notes:
[1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating
temperature, supply voltage, and load.
[2] Output will be enable if Pin1 is Logic "1" or Open; Output will be disable if Pin1 is Logic "0".
[3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz.
Rev. 1.02-a
Page 1
www.txccrystal.com
8W
MHz CMOS Oscillator
Dimensions
(Unit: mm)
Ordering Information
8W
30.000M
B B - T
Frequency in Hz
Packaging Method
T
Please contact us for
available frequencies
Supply Voltage
B
C
D
Rev. 1.02-a
Tape & Reel
Frequency Stability
3.3 V
2.5 V
1.8 V
B
C
F
Page 2
± 50 ppm (-10˚C ~ +70˚C)
± 100 ppm (-10˚C ~ +70˚C)
± 100 ppm (-40˚C ~ +85˚C)
www.txccrystal.com
8W
MHz CMOS Oscillator
Packing
(Unit: mm)
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min.
Peak temperature : 260°C ± 10°C, 10 sec. Min.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.02-a
60 sec
Page 3
Time (sec)
www.txccrystal.com
很抱歉,暂时无法提供与“8W-20.000MBB-T”相匹配的价格&库存,您可以联系我们找货
