MQF326D33-250.000-2.5/-30+85
    MERCURY(玛居礼)
    SMD-6
    有源晶振 3.3V 250MHz SMD-6
MQF326D33-250.000-2.5/-30+85 数据手册
Temperature Compensated Crystal Oscillators [ TCXO " M " and VCTCXO " VM " ] TCXO VCTCXO Min. Max. MQF _ T MQF _ P MQF _ D VMQF _ T VMQF _ P VMQF _ D 10 1,500 CMOS PECL LVDS CMOS PECL LVDS MHz MHz 1.5 pS Phase Jitter ( typical ) Features The (V)MQF326T , (V)MQF326P and (V)MQF326D Series are members of Mercury’s Q-Family Quick-Turn Temperature Compensated oscillators that can be delivered within days. With low current consumption (44 mA for PECL 212.500 MHz at 3.3V) and an integrated phase jitter performance of 1.0 pS RMS, they have gained its precision frequency control market position by providing engineers with next-day samples for prototypes and low cost, fast delivery for volume production ( ± 2.5 ppm over -30°C to +85°C ) . General specifications , at Ta=+25°C Model (V)MQF326T Output Logic (V)MQF326P (V)MQF326D CMOS PECL LVDS + 2.5 V ± 5% ( voltage code " 25 " ) + 2.5 V ± 5% ( voltage code " 25 " ) + 2.5 V ± 5% ( voltage code " 25 " ) + 3.3 V ± 5% ( voltage code " 33 " ) + 3.3 V ± 5% ( voltage code " 33 " ) + 3.3 V ± 5% ( voltage code " 33 " ) 10 ~ 250 MHz 10 ~ 1,500 MHz 10 ~ 1,500 MHz 15 pF 50 Ω into Vcc - 2V or Thevenin equiralent 100 Ω Output Logic " High " , " 1 " 90 % VDD VDD - 1.03 ( min.) , VDD - 0.6 ( max.) 1.4 V ( Typ.) , 1.6 V ( max.) Output Logic " Low " , " 0 " 10 % VDD VDD - 1.85 ( min.) , VDD - 1.6 ( max.) 1.1 V ( Typ.) , 0.9 V ( min.) Supply Voltage VDD ( code ) Available Frequency Range Output Load ( VDD = + 2.5V ) Current Consumption ( max.) 50 MHz : 24 mA 156 MHz : 36 mA 125 MHz : 28 mA 600 MHz : 40 mA 600 MHz : 28 mA 200 MHz : 30 mA 1,000 MHz : 50 mA 1,000 MHz : 34 mA 156 MHz : 25 mA ( VDD = + 3.3V ) Current Consumption ( max.) 50 MHz : 26 mA 156 MHz : 40 mA 125 MHz : 30mA 600 MHz : 45 mA 600 MHz : 30 mA 200 MHz : 34 mA 1,000 MHz : 52 mA 1,000 MHz : 36 mA Current with Output Disabled Rise Time / Fall Time Initial Calibration Tolerance Frequency Stability Codes 18 mA ( Typ.) 18 mA ( Typ.) 18 mA ( Typ.) 1.5 nsec. ( Typ.) , 3.0 nsec. ( max.) Tr / Tf : 10% ↔ 90% waveform 0.2 nsec. ( Typ.) , 0.5 nsec. ( max.) Tr / Tf : 20% ↔ 80% waveform 0.2 nsec. ( Typ.) , 0.4 nsec. ( max.) Tr / Tf : 20% ↔ 80% waveform ±1.0 ppm ( max.) at +25°C±2°C ( at the shipment ) Temperature ( refer to +25°C) ± 2.5 ppm over -30°C to +85°C ( default for Quick - Turn ) Aging at Ta = +25°C ± 2.0 ppm ( max.) first year ; ± 10 ppm ( max.) over 10 years Voltage Change ± 0.2 ppm ( max.) , for a ±5% input voltage change. Load Change ± 0.2 ppm ( max.) , for a ±10% load condition change. Reflow ± 1.0 ppm ( max.) , 1 reflow and measured 24 hours afterwards. Duty Cycle 50 % ± 5% Start-up Time 5 msec. ( max.) Storage Temperature -55°C to + 150°C RMS Jitter [ 12 kHz ~ 20 MHz ] 1.5 psec ( typ.) Phase Noise [ dBc / Hz ( typ.) ] Storage Temperature 156 MHz : 22 mA ± 1.0 ppm over -40°C to +85°C ( available ) Offset 10 Hz 100 Hz 1K Hz 10K Hz 1M Hz 10M Hz 156.250 MHz -65 -92 -108 -114 -117 -139 -147 212.500 MHz -61 -90 -106 -110 -112 -133 -142 312.500 MHz -51 -79 -97 -102 -103 -125 -134 100K Hz -55°C to + 150°C Control Voltage Function on Pad 1 Output Enable Function on pad 2 Control Voltage Center and Range +1.5V ± 1.0V for both VDD = 2.5V and 3.3V Frequency Pulling Range ± 8 ppm ( min.) Linearity ± 1 % ( typ.) ± 10% ( max.) Transfer Function Positive Transfer Absolute Voltage 4.0 V ( max.) Input Impedance 770 KΩ ( typ.) Mercury www.mercury-crystal.com 70% of VDD (min.) to enable output. OE Control on Pad 2 (Open connection prohibit.) 30% of VDD (max.) to disable output. Output Enable Time / Disable Time 200 nsec. ( max.) / 50 nsec. ( max.) ■Taiwan : Tel: (+886)-2-2406-2779 / sales-tw@mercury-crystal.com ■USA : Tel: (+1)-909-466-0427 / sales-us@mercury-crystal.com ■China : Tel: (+86)-512-5763-8100 / sales-cn@mercury-crystal.com 1 of 3 version: a3 Temperature Compensated Crystal Oscillators [ TCXO " M " and VCTCXO " VM " ] TCXO VCTCXO MQF _ T MQF _ P MQF _ D VMQF _ T VMQF _ P VMQF _ D CMOS PECL LVDS CMOS PECL LVDS F series SMD Min. 10 MHz 2.5 V 3.3 V Max. 1,500 MHz Part Number Format and Example Example : VMQF326D33 - 622.080 - 2.0 / -40+85 VMQF 326 Hold Type Package T : CMOS Supply Voltage " 326 " P : PECL " 33 " for 3.3V ( 3.2 * 2.5 mm ) D : LVDS " 25 " for 2.5V " MQF " : TCXO " VMQF " : VCTCXO D 33 - 622.080 - 2.0 / -40+85 Operating - Center Freq. ( MHz ) - Freq. Stability / Temperature Range Outline Dimensions ( Unit : mm ) , Suggested pad Layout for SMDs [ (V)MQF326T ] , [ (V)MQF326P ] , [ (V)MQF326D ] Test Circuits and Output Waveforms CMOS Mercury www.mercury-crystal.com PECL LVDS ■Taiwan : Tel: (+886)-2-2406-2779 / sales-tw@mercury-crystal.com ■USA : Tel: (+1)-909-466-0427 / sales-us@mercury-crystal.com ■China : Tel: (+86)-512-5763-8100 / sales-cn@mercury-crystal.com 2 of 3 version: a3 Emboss Taping and Reel Specifications [ VCXO ] [ ( VC )TCXO ] Carrier Type Dimensions ( unit : mm ) ±0.3mm A B C D E F G H I pcs / reel G_324 ( 6 ) 8.0 3.4 2.7 4.0 1.4 0.3 4.0 Ø 1.50 1.75 3000 G_534 12.0 5.3 3.6 8.0 1.4 0.3 4.0 Ø 1.55 1.75 1000 G_576 16.0 7.3 5.3 8.0 1.9 0.3 4.0 Ø 1.55 1.75 1000 G_42 24.0 11.8 10.0 16.0 5.0 0.3 4.0 Ø 1.50 1.75 500 G_43 24.0 11.8 10.0 16.0 5.0 0.3 4.0 Ø 1.55 1.75 500 G_62 24.0 11.8 10.0 16.0 5.0 0.3 4.0 Ø 1.55 1.75 500 G_63 24.0 11.8 10.0 16.0 5.0 0.3 4.0 Ø 1.55 1.75 500 (V)M_22 8.0 2.8 2.3 4.0 1.1 0.3 4.0 Ø 1.50 1.75 3000 (V)M_32 8.0 3.4 2.7 4.0 1.4 0.3 4.0 Ø 1.50 1.75 3000 (V)MQ_326 12.0 3.6 2.9 4.0 1.7 0.3 4.0 Ø 1.50 1.75 3000 (V)M_53 12.0 5.3 3.6 8.0 1.4 0.3 4.0 Ø 1.55 1.75 1000 (V)M_57 16.0 7.4 5.5 8.0 2.8 0.4 4.0 Ø 1.50 1.75 500 (V)M_42 24.0 11.8 10.0 16.0 5.0 0.3 4.0 Ø 1.50 1.75 500 (V)M_43 24.0 11.8 10.0 16.0 5.0 0.3 4.0 Ø 1.50 1.75 500 (V)M_62 24.0 11.8 10.0 16.0 5.0 0.3 4.0 Ø 1.50 1.75 500 (V)M_63 24.0 11.8 10.0 16.0 5.0 0.3 4.0 Ø 1.50 1.75 500 Reel Dimensions ( unit : mm ) ±2mm J K L P Q R pcs / reel G_324 ( 6 ) 180.0 9.0 12.0 13.2 2.1 - 3000 G_534 180.0 13.0 16.0 13.2 2.5 - 1000 G_576 180.0 17.2 19.3 13.3 2.2 22.0 1000 G_42 330.0 24.5 29.1 13.0 2.2 17.3 500 G_43 330.0 24.5 29.1 13.0 2.2 17.3 500 G_62 330.0 24.5 29.1 13.0 2.2 17.3 500 G_63 330.0 24.5 29.1 13.0 2.2 17.3 500 (V)M_22 178.00 8.40 11.40 13.0 2.5 20.5 3000 (V)M_32 180.0 9.0 12.0 13.2 2.1 - 3000 (V)MQ_326 180.0 13.0 16.0 13.2 2.5 - 3000 (V)M_53 180.0 13.0 16.0 13.2 2.5 - 1000 (V)M_57 180.0 17.2 19.3 13.3 2.2 22.0 500 (V)M_42 330.0 24.5 29.1 13.0 2.2 17.3 500 (V)M_43 330.0 24.5 29.1 13.0 2.2 17.3 500 (V)M_62 330.0 24.5 29.1 13.0 2.2 17.3 500 (V)M_63 330.0 24.5 29.1 13.0 2.2 17.3 500 Mercury www.mercury-crystal.com ■Taiwan : Tel: (+886)-2-2406-2779 / sales-tw@mercury-crystal.com ■USA : Tel: (+1)-909-466-0427 / sales-us@mercury-crystal.com ■China : Tel: (+86)-512-5763-8100 / sales-cn@mercury-crystal.com 3 of 3 version: a3
1. 物料型号:文档中提到了几种不同的晶振型号,包括TCXO "M" 和 VCTCXO "VM" 系列,以及它们的不同封装和输出逻辑版本,如(V)MQF326T、(V)MQF326P 和 (V)MQF326D。
2. 器件简介:文档描述了温度补偿晶体振荡器(TCXO)和电压控制温度补偿晶体振荡器(VCTCXO),它们通过提供快速交货、低功耗和集成的相位抖动性能,获得了精密频率控制市场的地位。
3. 引脚分配:文档提供了详细的引脚分配图和说明,包括不同的封装类型和它们的引脚功能,例如CMOS、PECL、LVDS等。
4. 参数特性:文档列出了这些振荡器的一般规格,包括输出逻辑、供电电压、可用频率范围、输出负载、输出逻辑电平、最大电流消耗、上升/下降时间、初始校准容差、频率稳定性代码、老化、电压变化、负载变化、回流、工作温度、RMS抖动、相位噪声等。
5. 功能详解:文档详细解释了振荡器的功能,包括它们的频率稳定性、老化特性、电压和负载变化对频率的影响、回流后的频率变化、工作和存储温度范围、以及相位噪声性能。
6. 应用信息:虽然文档没有直接提到具体的应用场景,但根据其高精度和快速响应的特性,这些振荡器可能适用于需要精密时钟信号的各种电子设备。
7. 封装信息:文档提供了不同封装类型的尺寸和建议的焊盘布局,以及卷带封装和规格。
MQF326D33-250.000-2.5/-30+85 价格&库存
很抱歉,暂时无法提供与“MQF326D33-250.000-2.5/-30+85”相匹配的价格&库存,您可以联系我们找货
