SXO32C3C171-25.000M
SXO32C3C171-25.000M
    SUNTSU
    SMD3225_4P
    有源晶振 25.000000MHz -25~+25ppm 3.3V -10℃~+70℃ CMOS
SXO32C3C171-25.000M 数据手册
Ceramic SMT 4 Pad CMOS Oscillator SXO32C Series 3.2mm x 2.5mm Features Applications • ±20ppm (Frequency Stability) Available • Micro Processors • Ceramic Package • SONET/SDH/DWDM • CMOS • Storage Area/Networking • Tape and Reel • Digital Video • Base Stations • Part Numbering Guide SXO 32 C 3 A 48 1 X - 30.000M SUNTSU OSC 3.2mm x 2.5mm CMOS SUPPLY VOLTAGE 1 : 1.8V±5% 2 : 2.5V±5% 3 : 3.3V±5% CO M P L I A N T FREQUENCY STABILITY A : ±50ppm B : ±30ppm C : ±25ppm *D : ±20ppm Cage Code : 4GUT4 To customize your parameters, contact a Suntsu representative. * For Frequency stability option D, contact a Suntsu representative. ** For operating temperatures up to -55-125°C contact a Suntsu representative. Electrical Parameters Units Minimum Frequency Range KHz 32.768 Frequency Range MHz 1 133 ppm -20 +20 See part numbering guide for options See part numbering guide for options Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change, and First Year Aging at 25°C.) Operating Temperature Typical OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C FREQUENCY MHz LOAD BLANK : 15pF X : 30pF TRI-STATE Y : 50pF (ENABLE/DISABLE) BLANK : No Connection 1: Pin 1 Maximum °C -40 +85 Storage Temperature °C -55 +125 Supply Voltage (VDD) - 1.8V option V 1.710 1.8 1.890 Supply Voltage (VDD) - 2.5V option V 2.375 2.5 2.625 Supply Voltage (VDD) - 3.3V option V 3.135 3.3 3.465 1.8V 2.5V 3.3V Frequency Range Current (IDD) 32.768KHz mA 3 5 5 1.0000MHz - 29.999MHz mA 4 8 10 Maximum Value 30.000MHz - 74.999MHz mA 6 15 17 Maximum Value 75.000MHz - 133.000MHz mA 12 20 25 Maximum Value 15 See part numbering guide for options Output Load (CMOS) pF Maximum Value Output Logic Levels High (VOH) V Output Logic Levels Low (VOL) V 0.1*VDD 32.768KHz ns 200 1.0000MHz - 29.999MHz ns 10 30.000MHz - 74.999MHz ns 8 75.000MHz - 133.000MHz ns Rise (TR) and Fall (TF) Time Remarks Symmetry (Duty Cycle) 0.9*VDD 5 % 45 Tri-State Input Voltage - Enable V 0.7*VDD Tri-State Input Voltage - Disable V 0.3*VDD Start-Up Time ms 10 Phase Jitter (12kHz ~ 20MHz) ps 1 www.suntsu.com Specifications are subject to change without notice. 50 55 No Connection Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO32C Series 3.2mm x 2.5mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (CMOS) Waveform (CMOS) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 27.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 30.000MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO32C Series 3.2mm x 2.5mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 27.000MHz Frequency - 30.000MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 3,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO32C Series 3.2mm x 2.5mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXO32C3C171-25.000M
物料型号:SXO32C系列 器件简介:3.2mm x 2.5mm尺寸的陶瓷表面贴装CMOS振荡器 引脚分配: - 1:三态或无连接 - 2:地(GND) - 3:输出 - 4:电源电压(Vop)
参数特性: - 频率稳定性:±20ppm(可定制) - 工作温度范围:-40°C 至 +85°C(可定制) - 存储温度范围:-55°C 至 +125°C - 供电电压:1.8V、2.5V、3.3V(±5%) - 频率范围:32.768KHz至133MHz - 输出负载电容:3pF至15pF(可定制)
功能详解: - 三态功能允许输出被禁用 - 提供频率稳定性选项 - 符合RoHS标准
应用信息: - 微处理器 - SONET/SDH/DWDM - 存储区域/网络 - 数字视频 - 基站
封装信息: - 陶瓷封装,适用于SMT装配 - 提供详细的外形图和布局图案
环境和机械规格符合MIL-STD-883和J-STD-020标准,包括温度循环、泄漏测试、振动、湿度抵抗等。
SXO32C3C171-25.000M 价格&库存
很抱歉,暂时无法提供与“SXO32C3C171-25.000M”相匹配的价格&库存,您可以联系我们找货
