WTL9S60560VH
WTL9S60560VH
    WTL(维拓)
    HC49S
    无源晶振 25MHz ±30ppm 20pF -20℃~+70℃
WTL9S60560VH 数据手册
Quartz Crystal, Series WX6 Resistance Welded HC-49S 11.05×4.7×3.68 mm Feature Resistance welded type crystal units A great number of standard frequencies Higher frequency available and lower equivalent series resistance Lower cost and highly mass production capability RoHS Compliant / Pb Free Electrical Specifications Item Specifications Frequency Range(MHZ) 3.2~6 6~8 8~16 16~54 Mode AT/Fundamental Load Capacitance (CL) 8pF, 10pF, 12pF or Specify Frequency Tolerance( at 25°C ) ±10ppm ~ ±30ppm or Specify Operating Temperature Range -20~+70°C or Specify Frequency Stability Over Operating Temperature Range 30~50 50~100 AT/3rd AT/3rd ±10ppm ~ ±30ppm or Specify Equivalent Series Resistance (ESR) max. 150Ω 60Ω 50Ω 30Ω Storage Temperature Range -55~+125°C Shunt Capacitance( C 0 ) Drive Level (Typical) 7.0 pF Max 1 μW~100 μW (10μW typical) Aging @25 °C 1st Year (Max) ±3 ppm/year or ±5 ppm/year 80Ω 60Ω Dimension(mm) 0.45 ± 0.10 3.8 MAX 3.68 MAX 13.2 ± 0.5 4.7 MAX 11.05 MAX 4.88 ± 0.20 http://www.wtlcrystals.com Email:wtl@wtlcrystals.com Tel:86-755-82677582 14
WTL9S60560VH 价格&库存
很抱歉,暂时无法提供与“WTL9S60560VH”相匹配的价格&库存,您可以联系我们找货
