Ceramic SMT 4 Pad CMOS Oscillator
SXO22C Series
2.5mm x 2.0mm
Features
Applications
• ±20ppm (Frequency Stability) Available
• Micro Processors
• Ceramic Package
• SONET/SDH/DWDM
• CMOS
• Storage Area/Networking
• Tape and Reel
• Digital Video
• Base Stations
Part Numbering Guide
SXO 22 C 3 A 48 1 - 27.000M
FREQUENCY
MHz
TRI-STATE
(ENABLE/DISABLE)
BLANK : No Connection
1: Pin 1
SUNTSU OSC
2.5mm x 2.0mm
CMOS
SUPPLY VOLTAGE
1 : 1.8V±5%
2 : 2.5V±5%
3 : 3.3V±5%
FREQUENCY STABILITY
A : ±50ppm
B : ±30ppm
Cage Code : 4GUT4
C : ±25ppm
To customize your parameters, contact a Suntsu representative.
*D : ±20ppm
* For Frequency stability option D, contact a Suntsu representative.
CO M P L I A N T
Electrical Parameters
Units
Minimum
Frequency Range
KHz
32.768
Frequency Range
Frequency Stability (Includes Initial
Tolerance at 25°C, Frequency Stability
over Operating Temperature, Output Load
Change, Supply Voltage Change, and First
MHz
1
110
ppm
-20
+20
See part numbering guide for options
°C
-40
+85
Storage Temperature
°C
-55
+125
Supply Voltage (VDD) - 1.8V option
V
1.710
1.8
1.890
Supply Voltage (VDD) - 2.5V option
V
2.375
2.5
2.625
Supply Voltage (VDD) - 3.3V option
V
3.135
3.3
3.465
1.8V
2.5V
3.3V
Frequency Range
Current (IDD)
Maximum
Remarks
32.768KHz
mA
3
4
5
Maximum Value
1.0000MHz - 15.999MHz
16.000MHz - 39.999MHz
40.000MHz - 59.999MHz
60.000MHz - 110.000MHz
mA
mA
mA
mA
3
5
10
15
5
7
13
10
15
35
Maximum Value
Maximum Value
Maximum Value
Maximum Value
Output Load (CMOS)
pF
Output Logic Levels High (VOH)
Output Logic Levels Low (VOL)
Rise (TR) and
Fall (TF) Time
Typical
OPERATING TEMPERATURE
RANGE
07 : 0°C - +70°C
16 : -10°C - +60°C
17 : -10°C - +70°C
27 : -20°C - +70°C
38 : -30°C - +85°C
48 : -40°C - +85°C
V
15
0.9*VDD
V
0.1*VDD
32.768KHz
ns
200
ns
ns
ns
ns
10
8
6
4
Symmetry (Duty Cycle)
45
Tri-State Input Voltage - Enable
V
0.7*VDD
Tri-State Input Voltage - Disable
V
0.3*VDD
Start-Up Time
ms
10
Phase Jitter (12kHz ~ 20MHz)
ps
1
www.suntsu.com
Specifications are subject
to change without notice.
50
55
No Connection
Suntsu Electronics, Inc.
142 TECHNOLOGY DR., SUITE 150
IRVINE, CA 92618
Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXO22C Series
2.5mm x 2.0mm
Outline Drawing & Land Pattern
All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale.
Test Circuit (CMOS)
Waveform (CMOS)
Typical Phase Noise Performance (Measured By Agilent E5052A)
Frequency - 20.000MHz
www.suntsu.com
Frequency - 27.000MHz
IRVINE, CA 92618
SXO22C Series
2.5mm x 2.0mm
Typical Jitter Performance (Measured By Agilent E5052A)
Reflow Profile
Part Marking
Tp (Time At 260°C. 20-40 Sec)
260
Rup (Ramp Up, 3°C/Sec Max)
217
Temperature (°C)
200
TI (Time Above 217°C.
60-150Sec)
150
Rdn (Ramp Down,
6°C/Sec Max)
Ts (Preheat Time.
60-180Sec)
T 25°C to Peak (480Sec Max)
Time (sec)
Tape And Reel Dimensions
3,000pcs/Reel
www.suntsu.com
IRVINE, CA 92618
SXO22C Series
2.5mm x 2.0mm
Environmental Specifications
Mechanical Specifications
Temperature Cycling
MIL-STD-883, Method 1010, Condition B
Mechanical Shock
MIL-STD-202, Method 213, Condition B
Fine Leak Test
MIL-STD-883, Method 1014, Condition A
Vibration
MIL-STD-883, Method 2007, Condition A
Gross Leak Test
MIL-STD-883, Method 1014, Condition C
Moisture Resistance
MIL-STD-883, Method 1004
Solderability
MIL-STD-883, Method 2003
Resistance to Solvents
MIL-STD-202, Method 215
Moisture Sensitivity
J-STD-020, MSL 1
Resistance to Soldering Heat
MIL-STD-202, Method 210, Condition K
www.suntsu.com
IRVINE, CA 92618
SXO22C3B171-27.000M 价格&库存
很抱歉,暂时无法提供与“SXO22C3B171-27.000M”相匹配的价格&库存,您可以联系我们找货
