LFXTAL078207Reel
LFXTAL078207Reel
    IQD
    SMD-4
    无源晶振 32MHz 70Ω 10pF ±10ppm -20℃~+70℃ SMD-4
LFXTAL078207Reel 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL078207Reel Customer Part: Description 2.5 x 2mm SMD crystal in a hermetically sealed ceramic package with a seam sealed metal lid. Model CFPX-218 Model Issue number 4 Frequency Parameters Frequency 32.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±10.00ppm @ 25°C ±10.00ppm Operating Temperature Range -20.00 to 70.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Electrical Parameters Outline (mm) 10.00pF 5pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 70.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Drop: 100cm drop (3 times) onto hard wooden board. Vibration: MIL-STD-883F, Method 2007.3: 20G (20Hz-2000Hz), 1.52mm amplitude, 20mins in 3 mutually perpendicular planes (total 4hrs). Manufacturing Details Maximum Process Temperature: 260°C (10secs max) RoHS Terminations NiAu RoHS Reflow Temp 260°C max for 10secs max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Dec 21 21:42 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL078207Reel
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为GND,6脚为Vcc。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms,响应时间小于10us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm。
LFXTAL078207Reel 价格&库存
很抱歉,暂时无法提供与“LFXTAL078207Reel”相匹配的价格&库存,您可以联系我们找货
