C1E-40.000-10-50100-X1-R3 数据手册
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Ltr
Revisions
Appr
Date
Electrical Specifications:
Frequency Range
Mode of Oscillation
Fundamental
Frequency Tolerance at 25°C
Frequency Stability over Temperature Range
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
24.000 to 48.000
MHz
±50
±100
-40 to +125
-55 to +125
±3
6 to 32 and Series Resonance
3.0
See ESR Table
100
PPM Max
(Note 1)
ºC
PPM Max/Year
Frequency Range and ESR Values:
Frequency Range in MHz ESR Ohm Max
Mode of Operation
24.000 to 29.999
120
Fundamental
30.000 to 36.999
100
Fundamental
37.000 to 48.000
80
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: May 25, 2017
Microprocessor Crystal Unit
Low Profile
1.2 x 1.6 millimeter Surface Mount
General Product Specification
Part Number:
C16 X1 Series
www.aker-usa.com
pF
Ohm
uW Max
Mechanical Outline:
1.6 ± 0.15
Ceramic Base
1.2 ± 0.15
#4
Metal Lid
#3
AKER
#2
#1
0.4 Max.
1.05
0.5
#2
#4
#3
0.6
0.4
0.8
0.3
#1
0.5
#2:GND #4:NC
0.75
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: May 25, 2017
P/N:
C16 X1 Series
www.aker-usa.com
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: May 25, 2017
P/N:
C16 X1 Series
www.aker-usa.com
How to build a Part Number:
Series
Package
C
16
Frequency
24.000 to 48.000
6
10
12
16
18
Load Capacitance
Frequency Tolerance (Note 1)
Frequency Stability (Note 1)
50
100
Temperature Range
X1
Packaging
Parameter
1.6 x 1.2 mm Seam Seal
MHz
6 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
M
R
R3
±50 PPM
±100 PPM
-40 to +125 ºC
250pcs / Reel
1000pcs / Reel
3000pcs / Reel
Part Number Example:
C16-40.000-10-50100-X1-R
C16- 1.6 x 2.0 mm SMD Seam Seal Crystal Unit
40.000 MHz Nominal Frequency
10 pF Load Capacitance
50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability
Fundamental Mode
-40 to +125° C Temperature Range
R: Tape and Reel Packaging
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
2- Product is shipped in Tape and Reel configuration.
4- Quantities less than 3000 are shipped bulk in ESD pouches.
5- Specification subject to change without notice.
Page:
4/4
Date: May 25, 2017
P/N:
C16 X1 Series
www.aker-usa.com
C1E-40.000-10-50100-X1-R3 价格&库存
很抱歉,暂时无法提供与“C1E-40.000-10-50100-X1-R3”相匹配的价格&库存,您可以联系我们找货
