C1E-48.000-10-50100-X1-R3
    AKER(安碁科技)
    SMD2016_4P
    无源晶振 10pF 48MHz ±50ppm 60Ω -40℃~+125℃ SMD2016_4P
C1E-48.000-10-50100-X1-R3 数据手册
RoHS Compliant Pb - Lead Free AEC-Q200 Qualified Ltr Revisions Appr Date Electrical Specifications: Frequency Range Mode of Oscillation Fundamental Frequency Tolerance at 25°C Frequency Stability over Temperature Range Operating Temperature Range Storage Temperature Range Aging Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level 24.000 to 48.000 MHz ±50 ±100 -40 to +125 -55 to +125 ±3 6 to 32 and Series Resonance 3.0 See ESR Table 100 PPM Max (Note 1) ºC PPM Max/Year Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 24.000 to 29.999 120 Fundamental 30.000 to 36.999 100 Fundamental 37.000 to 48.000 80 Fundamental Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: May 25, 2017 Microprocessor Crystal Unit Low Profile 1.2 x 1.6 millimeter Surface Mount General Product Specification Part Number: C16 X1 Series www.aker-usa.com pF Ohm uW Max Mechanical Outline: 1.6 ± 0.15 Ceramic Base 1.2 ± 0.15 #4 Metal Lid #3 AKER #2 #1 0.4 Max. 1.05 0.5 #2 #4 #3 0.6 0.4 0.8 0.3 #1 0.5 #2:GND #4:NC 0.75 Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: May 25, 2017 P/N: C16 X1 Series www.aker-usa.com Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: May 25, 2017 P/N: C16 X1 Series www.aker-usa.com How to build a Part Number: Series Package C 16 Frequency 24.000 to 48.000 6 10 12 16 18 20 32 Load Capacitance Frequency Tolerance (Note 1) Frequency Stability (Note 1) 50 100 Temperature Range X1 Packaging - Parameter 1.6 x 1.2 mm Seam Seal MHz - 6 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF - M R R3 ±50 PPM ±100 PPM -40 to +125 ºC 250pcs / Reel 1000pcs / Reel 3000pcs / Reel Part Number Example: C16-40.000-10-50100-X1-R C16- 1.6 x 2.0 mm SMD Seam Seal Crystal Unit 40.000 MHz Nominal Frequency 10 pF Load Capacitance 50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability Fundamental Mode -40 to +125° C Temperature Range R: Tape and Reel Packaging Notes: 1- Frequency Tolerance and Stability options are limited due to physical size. 2- Product is shipped in Tape and Reel configuration. 4- Quantities less than 3000 are shipped bulk in ESD pouches. 5- Specification subject to change without notice. Page: 4/4 Date: May 25, 2017 P/N: C16 X1 Series www.aker-usa.com
1. 物料型号:C16 X1 Series 2. 器件简介:这是一种低剖面表面贴装的微处理器晶体单元,尺寸为1.2 x 1.6毫米。 3. 引脚分配:文档中提到了两个引脚,#2(GND)和#4(NC,无连接)。 4. 参数特性: - 频率范围:24.000至48.000 MHz - 振荡模式:基频 - 25°C时频率容差:±50 PPM最大 - 温度范围内频率稳定性:±100 PPM - 工作温度范围:-40至+125°C - 存储温度范围:-55至+125°C - 老化:±3 PPM最大/年 - 负载电容:6至32皮法拉和串联谐振 - 并联电容:3.0皮法拉 - 等效串联电阻(ESR):见ESR表 - 驱动水平:100微瓦最大 5. 功能详解:文档提供了详细的电气规格和频率范围与ESR值的对应表。 6. 应用信息:适用于需要微处理器晶体单元的电子设备。 7. 封装信息:密封陶瓷金属封装,提供了机械轮廓和建议布局。
C1E-48.000-10-50100-X1-R3 价格&库存
很抱歉,暂时无法提供与“C1E-48.000-10-50100-X1-R3”相匹配的价格&库存,您可以联系我们找货
