S7A3310-160.000-L-X-CT 数据手册
RoHS Compliant
Pb - Lead Free
Ltr
Revisions
Appr
Date
Electrical Specifications:
Frequency Range
Frequency Stability over Temperature
Aging per Year
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Supply Voltage
Input Current
Output Voltage
Differential Output Voltage (Vod)
Offset Voltage (Vos)
Output Symmetry
Output Type
Output Load (Between Q ansd QN)
Rise and Fall Time
Input Enable Voltage
Input Disable Voltage
Phase Jitter (12 KHz to 20 MHz)
13.500 to 99.999MHz
100.000 to 160.000MHz
161.000 to 800.000MHz
Logic High (Voh)
Logic Low (Vol)
13.500 to 99.999MHz
13.500 to 160.000MHz
13.500 to 800.000
±100
±50
±25
±3
-10 to +70
-40 to +85
-55 to +125
1.8 ± 5%
2.5 ± 5%
3.3 ± 5%
50
50
50
50
50
50
50
50
1.6
1.6
1.6
0.9
0.9
0.9
247 to 454
1.125 to 1.375
45 to 55
LVDS - Complimentary Output
100
1
1
1
0.5
0.5
0.5
0.5
0.5
1.26
1.75
2.31
0.54
0.75
0.99
1
2
MHz
PPM Max
ºC
Vdd
mA Max
Vdd Min
Vdd Max
mV
V
Ω
ns Max
Vdd Min
Vdd Max
ps RMS
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply
voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C.
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
MK
Appr:
1/4
Page:
Date: Oct 20, 2019
Clock Oscillator
5.0 x 7.0 mm Surface Mount - 6 Pad
General Product Specification
Part Number:
S7A Series
www.aker-usa.com
Solder Pattern:
Mechanical Outline:
C1: 0.01 uF or 0.1 uF decoupling capacitor is
recommended.
C2: By-Pass capacitor for noise suppression.
Contact Aker for suggested values.
*Package Height:
1.4 mm Max for 77 to 159.900 MHz
1.8 mm Max for 160 to 625 MHz
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Pad Connection:
Pin Connection
1- INH
2- NC
3- GND
4- Output - Q
5- Comp. Output - QN
6- Vdd
Top View
Page:
2/4
Date: Oct 20, 2019
P/N:
S7A Series
www.aker-usa.com
A
B
8.0 ¡ Ó
0.1
Ko:2.0
Ao:5.4
5¢X
(max)
A-A SECTION
Solder Reflow Characteristics:
Page:
3/4
B-B SECTION
AKER
AKER
+0.1
1.7 -0.0
AKER
AKER
A
5¢X(max)
Pin #1
Bo:7.9
B
0.3 ¡ Ó
0.05
16.0 ¡ Ó0.3
4.0 ¡ Ó
0.1
7.5 ¡ Ó0.1
+0.1
1.5 -0.0
2.0 ¡ Ó
0.1
1.75 ¡ Ó0.1
Carrier Tape Dimensions:
Date: Oct 20, 2019
P/N:
www.aker-usa.com
S7A Series
How to build a Part Number:
Series
Package
S
7A
Parameter
5.0 x 7.0 mm - 6 Pad
Supply Voltage
18
25
33
+1.8 Vdd ± 5%
+2.5 Vdd ± 5%
+3.3 Vdd ± 5%
Temperature Stability
10
05
025
±100 PPM
±50 PPM
±25 PPM
Frequency
Output Load
Temperature Range
Packaging
13.500 - 800.000
L
See Notes
X
M
R
MHz
LVDS
-10 to +70 ºC
-40 to +85 ºC
250pcs Reel
1000pcs Reel
Part Number Example:
S7A3305-155.520-L-X-R
S7A: 5.0 x 7.0 mm SMD Package - 6 Pad
33: +3.3 Vdd Supply Voltage
05: ±50 PPM Temperature Stability
155.520 MHz Nominal Frequency
L: LVDS Output
X: -40 to + 85° C Extended Temperature Range
R: Tape and Reel Packaging
Notes:
1- Standard Temperature Range does not need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces.
3- Quantities less than 250pcs are shipped in tape.
4- Specification subject to change without notice.
Page:
4/4
Date: Oct 20, 2019
P/N:
www.aker-usa.com
S7A Series
S7A3310-160.000-L-X-CT 价格&库存
很抱歉,暂时无法提供与“S7A3310-160.000-L-X-CT”相匹配的价格&库存,您可以联系我们找货
