LFXTAL061486REEL
LFXTAL061486REEL
    IQD
    SMD5032_4P
    无源晶振 8.192MHz ±30ppm 10pF 150Ω -40℃~+85℃
LFXTAL061486REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL061486Reel Customer Part: Description Standard 5x3.2mm SMD crystal with four pads. Ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPX-104 iss:9.06 Model Issue number 9 Frequency Parameters Frequency 8.1920MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±50.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Outline (mm) Electrical Parameters 10.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 150.00Ω max Environmental Parameters Shock: 1500g, 0.5ms, 3 times in each of 3 mutually perpendicular planes Vibration: 20g (20Hz-2000Hz), 1.52mm amplitude, 20mins in 3 mutually perpendicular planes, 4 cycles Storage Temperature Range: -55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp Au 0.3um~1.0um 260degC max for 30s max Recommended Solder Pad Layout Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 3 Dec 21 5:34 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL061486REEL
物料型号:STM32F103C6T6 器件简介:STM32F103C6T6 是一款基于 ARM Cortex-M3 内核的微控制器,具有 72 MHz 的最高时钟频率,64 KB 的闪存和 20 KB 的 RAM。
引脚分配:该微控制器包含 48 个引脚,支持多种功能,包括 GPIO、ADC 通道、定时器、通信接口等。
参数特性:72 MHz 最高时钟频率,64 KB 闪存,20 KB RAM,支持多种通信协议如 USART、SPI、I2C 等。
功能详解:具有丰富的外设资源,包括 GPIO、ADC、DAC、通用定时器、高级控制定时器等,支持多种通信协议。
应用信息:广泛应用于工业控制、消费电子、医疗设备等领域。
封装信息:LQFP-48 封装,适用于多种 PCB 设计和应用场景。
LFXTAL061486REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL061486REEL”相匹配的价格&库存,您可以联系我们找货
