S23310T-27.000-X1-M
S23310T-27.000-X1-M
    AKER(安碁科技)
    SMD-4
    有源晶振 27MHz 3.3V SMD-4
S23310T-27.000-X1-M 数据手册
Ltr Revisions Appr Date RoHS Compliant Pb - Lead Free AEC-Q200 Qualified Electrical Specifications: Frequency Range Temperature Stability Aging per Year Operating Temperature Range Standard Extended Storage Temperature Range Supply Voltage Input Current Output Voltage Output Symmetry (Duty Cycle) 2.000 to 10.000 MHz 10.100 to 20.000 MHz 20.100 to 32.000 MHz 32.100 to 50.000 MHz Logic High (Voh) Logic Low (Vol) Standard Tight Output Load Output Level Phase Jitter (12 KHz to 20 MHz) Rise and Fall Time Standby Function Start Up Time 2.000 to 50.000 ±100 ±3 -40 to +125 -40 to +85 -55 to +150 +2.5 ± 5% +3.3 ± 5% 6 7 8 7 8 12 20 20 90% 10% 40 to 60 45 to 55 15 CMOS 1 7 Tri-State 10 MHz PPM Max ºC Vdd mA Max Vdd Min Vdd Max % pF ps Max RMS ns Max ms Max Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Feb 7, 2008 Clock Oscillator Automotive Temperature Range Ultra Miniature 2.5 x 2.0 millimeter Surface Mount General Product Specification Part Number: S2 X1 Series www.aker-usa.com Mechanical Outline: Pin1 Pin 3 INH Output High or Open Operating Low High Impedance Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: Feb 7, 2008 P/N: www.aker-usa.com S2 X1 Series Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: Feb 7, 2008 P/N: www.aker-usa.com S2 X1 Series How to build a Part Number: Series Package S 2 Parameter 2.5 x 2.0 mm Supply Voltage 33 25 +3.3 Vdd ± 5% +2.5 Vdd ± 5% Temperature Stability 10 ±100 PPM See Notes T 40/60% 45/55% Duty Cycle Frequency 2.000 to 50.000 MHz X1 -40 to +125 ºC Temperature Range Packaging R Tape and Reel Part Number Example: S22510-48.000-X1-R S2: 2.0 x 2.5 mm SMD Package 25: +2.5 Vdd Supply Voltage 10: ±100 PPM Temperature Stability 48.000 MHz Nominal Frequency X1: -40 to + 125° C Automotive Temperature Range R: Tape and Reel Packaging Notes: 1- Standard Duty Cycle does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Quantities less than 1000 are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date: Feb 7, 2008 P/N: www.aker-usa.com S2 X1 Series
S23310T-27.000-X1-M 价格&库存
很抱歉,暂时无法提供与“S23310T-27.000-X1-M”相匹配的价格&库存,您可以联系我们找货
