LFXTAL083388RL3K
LFXTAL083388RL3K
    IQD
    SMD3427_4P
    无源晶振 12MHz ±20ppm 12pF 120Ω -40℃~+105℃
LFXTAL083388RL3K 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL083388RL3K Customer Part: Description Standard 3.2 x 2.5mm SMD crystal in a ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPX-180 Model Issue number 10 Frequency Parameters Frequency 12.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±20.00ppm @ 25°C ±30.00ppm Operating Temperature Range -40.00 to 105.00°C Overtone Order Ageing Fundamental ±5ppm max per year @ 25°C Electrical Parameters Outline (mm) 12.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 120.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: MIL-STD-202F, Method 213B: 1000G, 0.5ms, 1/2 sine wave Vibration: MIL-STD-202F, Method 204D, Test Condition D: 20G (10Hz-2000Hz), 4hrs in 3 mutually perpendicular planes (total 12hrs) Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: RL3K Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 14 Nov 21 17:03 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL083388RL3K
- 物料型号:LFXTAL083388RL3K - 器件简介:标准3.2 x 2.5mm SMD晶体,采用陶瓷封装和密封金属盖,密封性良好。 - 引脚分配:1. Crystal, 2. GND & Lid, 3. Crystal, 4. GND & Lid - 参数特性: - 频率:12.0MHz,25°C时频率公差为±20.00ppm,-40.00至105.00°C时为±30.00ppm。 - 负载电容(CL):12.00pF,最大偏差7pF。 - 驱动电平:100µW。 - ESR(等效串联电阻):最大120.00Ω。 - 谐振电容(C0):未提供具体数值。 - 功能详解:文档未提供详细功能描述。 - 应用信息:文档未提供具体应用信息。 - 封装信息:符合EIA-481-D标准,采用RL3K包装样式,每卷3000个。 - 环境参数:存储温度范围-55至125°C,抗冲击和抗振性能符合MIL-STD-202F标准。 - 制造细节:符合RoHS指令2015/863/EU,MSL等级符合JDEC-STD-033。 - 联系方式:提供了英国、法国、德国、美国的联系电话和电子邮件地址,以及公司网站。
LFXTAL083388RL3K 价格&库存
很抱歉,暂时无法提供与“LFXTAL083388RL3K”相匹配的价格&库存,您可以联系我们找货
LFXTAL083388RL3K
    • 1+7.72200
    • 200+3.08880
    • 500+2.98080
    • 1000+2.92680
