LFXTAL059800REEL
LFXTAL059800REEL
    IQD
    SMD3225_4P
    无源晶振 25MHz ±50ppm 10pF 50Ω -10℃~+60℃
LFXTAL059800REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL059800Reel Customer Part: Description Standard 3.2 x 2.5mm SMD crystal in a ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPX-180 Model Issue number 10 Frequency Parameters Frequency 25.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±10.00ppm @ 25°C ±10.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±5ppm max per year @ 25°C Electrical Parameters Outline (mm) 10.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 50.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: MIL-STD-202F, Method 213B: 1000G, 0.5ms, 1/2 sine wave Vibration: MIL-STD-202F, Method 204D, Test Condition D: 20G (10Hz-2000Hz), 4hrs in 3 mutually perpendicular planes (total 12hrs) Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Dec 21 16:21 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL059800REEL
- 物料型号:LFXTAL059800Reel - 器件简介:标准3.2 x 2.5mm SMD晶体,采用陶瓷封装和密封金属盖,密封性良好。 - 引脚分配:1. Crystal, 2. GND & Lid, 3. Crystal, 4. GND & Lid - 参数特性: - 频率:25.0MHz ±10.00ppm @ 25°C ±10.00ppm -10.00 to 60.00°C - 负载电容(CL):10.00pF,最大7pF - 驱动级别:100µW max - ESR:50.00Ω max - 功能详解:文档未提供详细功能描述。 - 应用信息:文档未提供具体应用信息。 - 封装信息:SMD封装,尺寸3.2 x 2.5mm。 - 环境参数:存储温度范围-55至125°C,抗冲击和抗振性能符合MIL-STD-202F标准。 - 制造细节:符合RoHS指令2015/863/EU和REACh法规,MSL等级为JDEC-STD-033。 - 包装细节:EIA-481-D标准胶带和卷轴包装,每卷1000个,提供其他包装选项。
LFXTAL059800REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL059800REEL”相匹配的价格&库存,您可以联系我们找货
