BT-175.000MCB-T
BT-175.000MCB-T
    TXC(台晶)
    SMD-6
    有源晶振 2.5V 175MHz SMD-6
BT-175.000MCB-T 数据手册
Think of Frequency Think of SMD LVDS SAW Oscillators - Differential Output 7.0 x 5.0 x 1.6 mm BT Series Oscillators Series come visit our site http://www.txccorp.com Features .SAW base solution. H Y1 0 S T B 50 T B 156.2 .3.3V and 2.5V operation available. .LVDS output, output frequencies 150 MHz to 700 MHz. .Excellent low phase noise and jitter. .Tri-State function available. .Applications pplications : Fibre Channel, Gigabit Ethernet, Serial ATA, Serial Attached SCSI, PCI-Express, SDH / SONET. .RoHS Compliant / Pb Free. Item / Type BT Output Type LVDS Output Load 100 Ω Oscillation Mode Fundamental Supply Voltage 2.5 V , 3.3 V Frequency Range 150 ~ 700 MHz Overall Frequency Stability * ± 100 ppm , or specify Operating Temperature Range -10 ~ + 70 ℃ , - 5 ~ + 85 ℃ , or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol(Min.) / Voh (Max.) 0.9 V / 1.6 V Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % ) 1 nS Max. Supply Current 80 mA Max. Symmetry 45 ~ 55 % Start-up Time 10 mS Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 pS Max. Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications * Inclusive of frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, aging and vibration. Dimensions Units: mm 73
BT-175.000MCB-T
1. 物料型号:文档中没有明确提到具体的物料型号,但提到了“BT Series”振荡器。
2. 器件简介:文档介绍了SMD LVDS SAW振荡器,具有差分输出。这些振荡器基于SAW技术,提供3.3V和2.5V的电源电压选项,LVDS输出,输出频率范围为150 MHz到700 MHz。它们具有优异的低相位噪声和抖动特性。
3. 引脚分配: - 1: ENABLE CONTROL or NG - 2: ENABLE CONTROL or NC - 3: GND - 4: OUT - 5: OUTN - 6: VDD
4. 参数特性: - 输出类型:LVDS - 输出负载:100 - 振荡模式:基本 - 电源电压:2.5V, 3.3V - 频率范围:150-700 MHz - 整体频率稳定性:±100ppm,或指定 - 工作温度范围:-10-+70°C,-5-+85°C,或指定 - 存储温度范围:-55-+125°C - 电压VOL(最小)/VOH(最大):0.9V/1.6V - 上升时间(Tr)/下降时间(Tf)(20%-80%):最大1纳秒 - 电源电流:最大80毫安 - 对称性:45-55% - 启动时间:最大10毫秒 - 相位抖动(12KHz-20 MHz):最大1皮秒
5. 功能详解:文档提到了振荡器的三态功能,以及它们在Fibre Channel、Gigabit Ethernet、Serial ATA、Serial Attached SCSI、PCI-Express、SDH/SONET等应用中的使用。
6. 应用信息:这些振荡器适用于Fibre Channel、Gigabit Ethernet、Serial ATA、Serial Attached SCSI、PCI-Express、SDH/SONET等。
7. 封装信息:文档提供了封装的尺寸信息,包括7.0 x 5.0 x 1.6 mm的BT系列封装,以及引脚的布局图。
BT-175.000MCB-T 价格&库存
很抱歉,暂时无法提供与“BT-175.000MCB-T”相匹配的价格&库存,您可以联系我们找货
