TSM32-H50GM18ST-33.333M
    TRANSKO
    SMD3225_4P
    有源晶振 33.333MHz 1.8V SMD-4
TSM32-H50GM18ST-33.333M 数据手册
TSM32 RoHS Compliant ULTRA MINIATURE SMD CMOS OSCILLATOR (3.2 x 2.5 x 1.2mm) FEATURES: • LOW COST SMALL SMD PACKAGE • • LOW VOLTAGE/LOW CURRENT AEC-Q200 QUALIFIED OPTION ■ SPECIFICATION FREQUENCY RANGE FREQUENCY STABILITY OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE RANGE SUPPLY VOLTAGE ±10% 25KHz ~ 156.250MHz ±10ppm ~ ±100ppm STD: 0°C ~ 70°C, Option: -40°C ~ 85°C (See P/N guide for other options) -55°C ~ 125°C 1.0VDC ~ 5.0VDC SUPPLY CURRENT 30mA max. LOGIC FAMILY LOAD LEVEL LOGIC ‘1’ (VOH) OUTPUT LEVEL LOGIC ‘0’ (VOL) SYMMETRY(DUTY CYCLE) RISE AND FALL TIME (Tr/Tf) START-UP TIME ENABLE (VIH) STAND-BY VOLTAGE DISABLE (VIL) ENABLE DELAY TIME DISABLE DELAY TIME AGING @ 25°C ± 3°C PHASE JITTER RMS (12kHz ~ 20MHz) CMOS 15pF 0.9 x VDD min. 0.1 x VDD max. STD: 40% / 60% @ 1/2VDD level, Option: 45% / 55% 3.0nS typ. 10nS max. 10mS max. 0.7 x VDD ≤ VIH ≤ VDD or N/C VIL ≤ 0.3 x VDD 10mS max. 10mS max. ±3.0ppm / 1st year max. 1.0pS max. ■ PACKAGE DIMENSIONS ■ SOLDER PATTERN ■ REFLOW PROFILE 2.20 3.2±0.1 3 Marking 150 ±5°C Pre-heating 1.4 * 1 255 ±5°C 170 ±5°C 1.60 2.5±0.1 4 Soldering 1.20
TSM32-H50GM18ST-33.333M 价格&库存
很抱歉,暂时无法提供与“TSM32-H50GM18ST-33.333M”相匹配的价格&库存,您可以联系我们找货
    • 1+28.30680
    • 250+11.29680
    • 500+10.91880
    • 1000+10.73520
