C5S-40.000-12-3030-R
    AKER(安碁科技)
    SMD5032_4P
    无源晶振 -20℃~+70℃
C5S-40.000-12-3030-R 数据手册
Ltr RoHS Compliant Pb - Lead Free Date Revisions Electrical Specifications: Frequency Range Fundamental Third Overtone Standard Mode of Oscillation Frequency Tolerance at 25°C Optional Standard Frequency Stability over Temperature Range Optional Operating Temperature Range Storage Temperature Range Aging Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance Standard Extended 8.000 to 133.000 8.000 to 54.000 40.000 to 133.000 ±30 ±25 ±20 ±15 ±10 ±50 ±30 ±25 ±20 ±15 ±10* -10 to +70 -40 to +85 -55 to +125 ±3 6 to 32 and Series Resonance 7.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc MHz MHZ PPM Max PPM Max ºC PPM Max/Year pF Ohm uW Typ M Ohm Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 8.000 to 9.749 70 Fundamental Frequency Range in MHz ESR Ohm Max Mode of Operation 40.000 to 79.999 100 3rd Overtone 9.750 to 9.999 60 Fundamental 80.000 to 99.999 80 3rd Overtone 10.000 to 11.999 45 Fundamental 100.000 to 133.000 60 3rd Overtone 12.000 to 15.999 35 Fundamental 16.000 to 19.999 30 Fundamental 20.000 to 49.999 25 Fundamental 50.000 to 54.000 20 Fundamental Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Dec 1, 2018 Microprocessor Crystal Unit 5.0 x 3.2 millimeter Surface Mount General Product Specification Part Number: C5S Series www.aker-usa.com Appr Mechanical Outline: 5.0 ± 0.15 3.2 ± 0.15 #4 Ceramic Base Metal Lid #3 AKER #1 #2 1.0 Max. 2.6 3.8 #2 #4 #3 1.4 0.9 1.4 2.3 #1 1.2 #2:GND #4:GND 1.6 Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: Dec 1, 2018 P/N: www.aker-usa.com C5S Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION 5.4 AKER AKER AKER AKER A 12.0 5.5 B A B 1.5 8.0 1.4 3.6 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: Dec 1, 2018 P/N: www.aker-usa.com C5S Series How to build a Part Number: Series Package C 5S Frequency 8.000 to 133.000 6 10 12 16 18 20 32 S Load Capacitance Frequency Tolerance Option Standard Frequency Stability Option Mode of Oscillation See Notes 3 Standard Temperature Range Option See Notes X M R Packaging MHz - 6 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series - 30 20 15 10 50 30 20 15 10 Standard - Parameter 5.0 x 3.2 mm - ±30 PPM ±20 PPM ±15 PPM ± 10 PPM ±50 PPM ±30 PPM ±20 PPM ±15 PPM ±10 PPM* Fundamental Third Overtone -10 to +70 ºC -40 to +85 ºC 250pcs Reel 1000pcs Reel Part Number Example: C5S-40.000-3050-X-R C5S: 5.0 x 3.2 mm SMD Seam Sealed Package 40.000 MHz Nominal Frequency 18 pF Load Capacitance 3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability X: -40 to +85º C Extended Temperature Range R: Tape and Reel Packaging Notes: 1- Fundamental mode does not need to be included in Part Number description. * ±10 PPM Temperature Stability is only available from -30 to +85° C. 2- Other Load Capacitances are availble other than those listed in Part Number table above. 3- Product is shipped in Tape and Reel configuration. 4- Quantities less than 250pcs are shipped in tape 5- Specification subject to change without notice Page: 4/4 Date: May 1, 2013 P/N: C5S Series www.aker-usa.com
物料型号:C5S系列
器件简介:Microprocessor Crystal Unit,5.0 x 3.2 millimeter Surface Mount General Product Specification
引脚分配:#1和#2为引脚,#3和#4为地(GND)
参数特性: - 频率范围:8.000至133.000 MHz,部分型号为8.000至54.000 MHz或40.000至133.000 MHz - 振荡模式:基础模式或第三泛音 - 25°C时频率容差:标准为±30 PPM,可选±25、+20、±15、±10 - 温度范围内频率稳定性:标准为±50 PPM,可选±30、±25、±20、±15、±10(-30至+85°C范围内±10 PPM) - 工作温度范围:标准为-10至+70°C,扩展为-40至+85°C - 存储温度范围:-55至+125°C - 老化:±3 PPM/年 - 负载电容:6至32 pF及串联谐振 - 并联电容:7.0 pF - 等效串联电阻(ESR):见ESR表 - 驱动电平:100 uW典型值 - 绝缘电阻:在100Vdc±15 Vdc时为500 MΩ
功能详解:文档提供了详细的频率范围与ESR值表,规格标题,机械轮廓,载体胶带尺寸,焊接再流特性,如何构建零件编号等信息。
应用信息:适用于微处理器晶体单元的表面贴装
C5S-40.000-12-3030-R 价格&库存
很抱歉,暂时无法提供与“C5S-40.000-12-3030-R”相匹配的价格&库存,您可以联系我们找货
