SXT53410CC17-25.000M 数据手册
Ceramic SMT 4 Pad Crystal
SXT534 Series
5.0mm x 3.2mm
Features
Applications
• ±10ppm/±10ppm (Tolerance/Stability)
Available
• Communication and Test Equipment
• Ultra-Miniature Package
• Wireless Applications
• PCMCIA
• AT-Cut Fundamental
• High Density Applications
• Tape and Reel
Part Numbering Guide
SXT 53 4 18 A A 48 T - 27.000M
SUNTSU CRYSTAL
FREQUENCY
MHz
MODE OF OPERATION
5.0mm x 3.2mm
Blank : Fundamental
T : 3rd Overtone
4 PAD
OPERATING TEMPERATURE
LOAD CAPACITANCE
FREQUENCY STABILITY
RANGE**
FREQUENCY TOLERANCE
07 : 0°C - +70°C
S : Series
A : ±50ppm
A : ±50ppm
16 : -10°C - +60°C
COMPLIANT
7-30 : 7pF - 30pF
B : ±30ppm
B : ±30ppm
17 : -10°C - +70°C
C : ±25ppm
C : ±25ppm
27 : -20°C - +70°C
D : ±20ppm
D : ±20ppm
38 : -30°C - +85°C
E : ±15ppm
Cage Code: 4GUT4
E : ±15ppm
48 : -40°C - +85°C
F : ±10ppm*
To customize your parameters contact a Suntsu representative.
F : ±10ppm
* For frequency stability option F contact a Suntsu representative. ** For operating temperatures of -55-125°C a Suntsu representative.
Electrical Parameters
Frequency Range
Units
Minimum
MHz
7.9921
Typical
Maximum
Remarks
54
AT-Cut Fundamental.
Frequency Range
MHz
40
125
3rd Overtone
Frequency Tolerance at +25ºC
ppm
-10
+10
See part numbering guide for options.
Frequency Stability vs. Op Temp
ppm
-10
+10
Frequency Stability vs. Aging
ppm
-3
+3
First year @ +25ºC.
Operating Temperature
°C
-40
+85
Storage Temperature
°C
-40
+125
Load Capacitance
pF
7
30
Shunt Capacitance
pF
Drive Level
µW
Insulation Resistance
MΩ
7
10
50
100
500
@ 100VDC ± 15V.
8.000MHz
11.999MHz
Ω
100
AT-Cut Fundamental
12.000MHz
19.999MHz
Ω
80
AT-Cut Fundamental
ESR - 20.000MHz
AT-Cut Fundamental
29.999MHz
Ω
70
30.000MHz ~ 54.000MHz
Ω
50
AT-Cut Fundamental
40.000MHz ~~ 125.000MHz
66.000MHz
Ω
80
50
3rd
Overtone
AT-Cut
Fundamental
Outline Drawing & Recommended Landed Pattern
All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale.
www.suntsu.com
Specifications are subject
to change without notice.
Suntsu Electronics, Inc.
142 TECHNOLOGY DR., SUITE 150
IRVINE, CA 92618
Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXT534 Series
5.0mm x 3.2mm
Environmental Specifications
Mechanical Specifications
Temperature Cycling
MIL-STD-883, Method 1010, Condition B
Mechanical Shock
MIL-STD-202, Method 213, Condition B
Fine Leak Test
MIL-STD-883, Method 1014, Condition A
Vibration
MIL-STD-883, Method 2007, Condition A
Gross Leak Test
MIL-STD-883, Method 1014, Condition C
Resistance to Soldering Heat
MIL-STD-202, Method 210, Condition K
Moisture Resistance
MIL-STD-883, Method 1004
Resistance to Solvents
MIL-STD-202, Method 215
Moisture Sensitivity
J-STD-020, MSL 1
Solderability
MIL-STD-883, Method 2003
Reflow Profile & Part Marking
Tp (Time At 260°C. 20-40 Sec)
260
Rup (Ramp Up, 3°C/Sec Max)
217
Temperature (°C)
200
TI (Time Above 217°C.
60-150Sec)
150
Rdn (Ramp Down,
6°C/Sec Max)
Ts (Preheat Time.
60-180Sec)
T 25°C to Peak (480Sec Max)
Time (sec)
Tape And Reel Dimensions
1,000pcs / Reel
www.suntsu.com
IRVINE, CA 92618
SXT53410CC17-25.000M 价格&库存
很抱歉,暂时无法提供与“SXT53410CC17-25.000M”相匹配的价格&库存,您可以联系我们找货
