QTM532-100.000MDE-T
QTM532-100.000MDE-T
    QST(矽睿)
    SMD-4
    有源晶振 1.8V 100MHz SMD-4
QTM532-100.000MDE-T 数据手册
QTM532 MHz CMOS Oscillator Fuel The Digital World Features ● ● ● ● ● ● ● Applications Frequency range : 1MHz to 170MHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Tri-state function available External dimensions (mm) L : 5.0 x W : 3.2 x H : 1.2 RoHS compliant & Pb free ● ● ● ● ● Networking, Server, Storage Wireless communications Fibre channel, Ethernet, SATA, SAS, PCI-E, USB, WLAN, xDSL, xPON PC mainboard, Notebook, HDD, SSD, Graphics card, Computer peripherals Audio, Video, Gaming, Printer, DSC, IP CAM, Consumer products Electrical Characteristics Item Frequency Range (F0) QTM532 Conditions 1MHz ~ 170MHz ±50 , ±25 ppm -10°C ~ +70°C; Note [1] ±50 , ±30 , ±25 , ±15 ppm -40°C ~ +85°C; Note [1] Frequency Stability (Fstab) Operating Temperature Range (T OTR) Supply Voltage (VDD) -10°C ~ +70°C -40°C ~ +85°C 1.8V, 2.5V, 2.8V, 3.3V VDD ± 10% 10 mA Max. 1MHz ~ 75MHz 20 mA Max. 75MHz ~ 170MHz Current Consumption (IDD) Output Type CMOS Output Load (CL) 15 pF Output Voltage High (VOH) 90% VDD Min. Output Voltage Low (VOL) 10% VDD Max. Rise & Fall Time (Tr / Tf) 8 ns Max. Duty Cycle Start-up Time Enable Voltage High, Logic "1" Enable Voltage Low, Logic "0" Phase Jitter, RMS Aging (Faging) Storage Temperature Range (TSTR) 40% ~ 60% 5 ms Max. 70% VDD Min. 30% VDD Max. 1 ps Max. ±3 ppm Max. 10% ~ 90% of VDD Input to Pin1 Note [2] Note [3] at 25°C±3°C, first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, supply voltage, and load. [2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0". [3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz. Rev. 1.05 Page 1 www.qstproducts.com QTM532 MHz CMOS Oscillator Fuel The Digital World Dimensions (Unit: mm) Ordering Information QTM532 - 30.000M B E - T Frequency in Hz Packaging Method T Please contact us for available frequencies Supply Voltage B E C D Rev. 1.05 Tape & Reel Frequency Stability 3.3 V 2.8 V 2.5 V 1.8 V Page 2 B ± 50 ppm ( -10°C ~ +70°C ) A ± 25 ppm ( -10°C ~ +70°C ) E ± 50 ppm ( -40°C ~ +85°C ) G ± 30 ppm ( -40°C ~ +85°C ) D ± 25 ppm ( -40°C ~ +85°C ) H ± 15 ppm ( -40°C ~ +85°C ) www.qstproducts.com QTM532 MHz CMOS Oscillator Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.05 60 sec Page 3 Time (sec) www.qstproducts.com
QTM532-100.000MDE-T
物料型号:QTM532 MHz CMOS Oscillator
器件简介:该振荡器提供1MHz至170MHz的频率范围,适用于数字世界的各种应用。
引脚分配: - 1: ENABLE CONTROL - 2: GND - 3: OUT - 4: VDD
参数特性: - 工作频率稳定性:±50ppm至±15ppm,取决于温度范围 - 工作温度范围:-10°C至+70°C或-40°C至+85°C - 供电电压:1.8V至3.3V - 最大电流消耗:1MHz至75MHz时为10mA,75MHz至170MHz时为20mA - 输出类型:CMOS - 输出负载:15pF - 输出高电平电压:至少90% VDD - 输出低电平电压:最多10% VDD - 上升和下降时间:最大8ns - 占空比:40%至60% - 启动时间:最大5ms - 使能电压高/逻辑"1":至少70% VDD - 相位抖动(RMS):最大1ps - 老化:第一年在25°C+3°C时最多±3ppm - 存储温度范围:-55°C至+125°C
功能详解:文档提供了详细的电气特性表,说明了不同条件下的频率稳定性、工作温度范围、供电电压、电流消耗等参数。
应用信息:适用于网络、服务器、存储、无线通信、PCI-E、USB、WLAN、xDSL、xPON、光纤通道、以太网、SATA、SAS、图形卡、计算机外围设备、主板、笔记本电脑、硬盘、固态硬盘、音频、视频、游戏、打印机、数码相机、IP摄像头和消费类产品。
封装信息:SMD密封陶瓷封装,外部尺寸为长5.0mm x 宽3.2mm x 高1.2mm,符合RoHS和无铅标准。
订购信息:提供了不同频率稳定性和供电电压的型号选择,以及包装方法。
回流焊接曲线:提供了焊接时的熔化点和峰值温度建议。
QTM532-100.000MDE-T 价格&库存
很抱歉,暂时无法提供与“QTM532-100.000MDE-T”相匹配的价格&库存,您可以联系我们找货
