TX32-33020S-40.000-X-M 数据手册
Ltr
Date
Revisions
Appr
RoHS Compliant
Pb - Lead Free
Electrical Specifications:
Frequency Range
10.000 to 52.000
Frequency Tolerance
MHz
±2.0
Frequency Stability vs. Operating Temperature
±0.5 ~ ±2.5
Frequency Stability vs. Supply Voltage Change
±0.2
Frequency Stability vs. 10% Load Change
±0.2
Aging per Year
±1.0
Operating Temperature Range
Standard
-20 to +70
Extended
-40 to +85
Storage Temperature Range
ppm Max.
°C
-55 to +125
1.8 ± 5%
Supply Voltage
2.5 ± 5%
VDC
3.3 ± 5%
Input Current
2.5
mA Max.
Output Level
0.8
Vp-p Min.
Output Waveform
Clipped Sinewave
Output Load
10KΩ // 10pF
Phase Noise
@100Hz Offset
-114
@1KHz Offset
-131
@10KHz Offset
-148
Start Up Time
2
dBc/Hz Typ.
ms Max.
Specification Title:
No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan, ROC
TCXO - Ceramic Package
All dimensions are millimeters.
CAD:
TCR
Review:
EG
Appr:
JL
Page:
1/4
Temperature Compensated
Crystal Oscillator
3.2 x 2.5 millimeter Surface Mount
Date:
Jan 8,2020
Part Number:
www.aker-usa.com
TX32 Series
Mechanical Outline and Solder Pad Layout:
3.2 ¡ Ó0.15
Metal Lid
#3
#4
2.5 ¡ Ó0.15
Ceramic Base
AKER
#1
#2
1.2 Max.
1.2
2.2
#2
#4
#3
1.0
0.65
1.0
1.6
#1
0.9
1.4
PIN No.
Connection
#1
NC / GND
#2
GND
#3
Output
#4
VDC
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page: 2/4
Date : Jan 8,2020
P/N: TX32 Series
www.aker-usa.com
B-B SECTION
AKER
AKER
AKER
AKER
B
4.0
1.4
2.7
A-A SECTION
Solder Reflow Characteristics:
Page: 3/4
3.4
3.5
B
Pin #1
AKER
1.0
A
AKER
AKER
AKER
A
4.0
8.0
1.5
2.0
1.75
Carrier Tape Dimensions:
Date : Jan 8,2020
P/N: TX32 Series
www.aker-usa.com
How to build a Part Number:
Series
TX
Parameter
Package
32
3.2 x 2.5 mm
Supply Voltage
Temperature Stability
Output Waveform
18
1.8 VDC ± 5%
25
2.5 VDC ± 5%
33
3.3 VDC ± 5%
005
±0.5 ppm
010
±1.0 ppm
020
±2.0 ppm
25
±2.5 ppm
S
Clipped Sinewave
Frequency
10.000~52.000
MHz
Temperature Range
See Notes
-20 to +70 °C
X
-40 to +85 °C
Packaging
M
250pcs Reel
R
1000pcs Reel
R3
3000pcs Reel
Part Number Example:
TX32-33020S-26.000-X-R
TX32: 3.2 x 2.5 mm SMD Package
33: +3.3 VDC Supply Voltage
020: ±2.0 ppm Temperature Stability
S: Clipped Sinewave Output
26.000 MHz Nominal Frequency
X: -40 to + 85°C Temperature Range
R: Tape and Reel Packaging
Notes:
1- Standard Temperature Range do not need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration.
3- Quantities less than 1000 are shipped bulk in ESD pouches.
4- Specification subject to change without notice.
Page: 4/4
Date : Jan 8,2020
P/N: TX32 Series
www.aker-usa.com
TX32-33020S-40.000-X-M 价格&库存
很抱歉,暂时无法提供与“TX32-33020S-40.000-X-M”相匹配的价格&库存,您可以联系我们找货
