OYLTDLJANF-20.000000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 25MHz 1.2V SMD-4
OYLTDLJANF-20.000000 数据手册
OX Type Ultra Low Power 3.2 x 2.5mm SMD CMOS Output Crystal Oscillator Actual Size FEATURE - Ultra Low Power Supply Voltage: 0.9V, 1.2V, 1.5V Supply Options - Singled-end Output: CMOS - Frequency Support from 1MHz to 50MHz - Low Noise Typical: 0.3ps at 12kHz to 20MHz Frequency Offsets - Temperature Range: -40 to 85oC Operation - Pb-free/RoHS Compliant RoHS Compliant TYPICAL APPLICATION - loT - Game Console - Smartphone - Wearable Device - Digital Camera - Digital Consumer Electronics DIMENSION (mm) SOLDER PAD L AYOUT (mm) 0.1 μF [ B O T T O M V IE W ] [ TO P VIEW ] 2.10 ± 0.15 1.65 ± 0.15 #2 #2 0.65 ± 0.15 #1 #4 #1 1.60 #3 #3 2.50 ± 0.15 #4 1.10 3.20 ± 0.15 2.10 0.90 ± 0.15 Pin# 0.35 0.95 ± 0.15 [ S ID E V IE W ] 1 2 3 4 Function 1.20 Tri-state GND Output VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 0.9V Parameter Supply Voltage Variation (VDD) Frequency Range At 15pF Load Fo < 10MHz 1.2V 1.5V Unit Min. Max. Min. Max. Min. Max. VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% V 1 50 1 50 1 50 MHz - 1.5 - 2 - 3 mA - 0.9 - 1 - 1.2 mA Supply No Load Condition, 1MHz Current No Load Condition, 10MHz Fo < 20MHz - 1 - 1.2 - 1.2 mA No Load Condition, 20MHz Fo < 50MHz - 1.2 - 1.5 - 1.5 mA Duty Cycle Output Level Transition Time: Rise / Fall Time+ 45 55 45 55 45 55 % Output High 2.97 - 2.25 - 1.62 - V Output Low - 0.33 - 0.25 - 0.18 V 1MHz - 4 - 3 - 3 nSec Fo < 10MHz 10MHz Fo < 20MHz - 3 - 3 - 3 nSec 20MHz Fo < 50MHz - 2 - 2 - 2 nSec Startup Time Enable (High Voltage or Tri-State (Input to Pin 1) Floating) Disable (Low Voltage or GND) - 4 - 4 - 4 mSec 0.7xVDD - 0.7xVDD - 0.7xVDD - V - 0.3xVDD - 0.3xVDD - 0.3xVDD Output Loading 15 15 15 Stand by Current - 100 - 100 - 100 Aging (@ 25oC, 1st Year) - 3 - 3 - 3 Storage Temp. Range Phase Noise V pF -55 +125 -55 +125 -55 +125 Typ. Max. Typ. Max. Typ. Max. A ppm o C 1kHz offset -130 - -133 - -135 - At VDD=1.2V, 10kHz offset -140 - -143 - -143 - Fout=24MHz 100kHz offset -148 - -150 - -150 - 1MHz offset -152 - -155 - -155 - Period Jitter (Pk-Pk) - 40 - 40 - 40 pSec RMS Phase Jitter (Integrated 12kHz to 20MHz) - 1 - 1 - 1 pSec dBc/Hz Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position +Transition times are measured between 10% and 90% of VDD,withan output load of 15pF FREQ. STABILITY vs. TEMP. RANGE ppm Temp.( oC) -10~+60 -20~+70 -40~+85 25 50 * O: Available △:Conditional X: Not available *Inclusive of calibration @ 25℃, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration load variation Note: not all combination of options are available. Other specifications may be available upon request. Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(2)08/2019 33
OYLTDLJANF-20.000000 价格&库存
很抱歉,暂时无法提供与“OYLTDLJANF-20.000000”相匹配的价格&库存,您可以联系我们找货
