TSMV-H50HM33ST2C-74.17582M
    TRANSKO
    SMD-6
    有源晶振 3.3V 74.17582MHz SMD-6
TSMV-H50HM33ST2C-74.17582M 数据手册
TSMV RoHS Compliant VCXO STANDARD CERAMIC SMD (7.0 x 5.0 x 2.0mm) FEATURES: • LOW NOISE • WIDE FREQUENCY RANGE UPTO 200.000MHz ■ SPECIFICATION PARAMETER MIN. 1 ±10* -40 -55 2.5 FREQUENCY RANGE FREQUENCY STABILITY OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE RANGE SUPPLY VOLTAGE ±10% SUPPLY CURRENT LOGIC FAMILY LOAD LEVEL LOGIC ‘1’ (VOH) OUTPUT LEVEL LOGIC ‘0’ (VOL) SYMMETRY (DUTY CYCLE) RISE AND FALL TIME (Tr/Tf) START-UP TIME ENABLE (VIH) STAND-BY VOLTAGE DISABLE (VIL) ENABLE/ DISABLE DELAY TIME FREQUENCY DEVIATION CONTROL VOLTAGE SLOPE LINEARITY MODULATION BANDWIDTH @-3dB INPUT IMPEDANCE ABSOLUTE PULL RANGE (Optional) AGING @ 25°C + 3°C FUNDAMENTAL PHASE JITTER RMS PLL (3.3V) TYP. MAX. 200 ±100 85 125 5.0 50 HCMOS 15pF UNIT MHz ppm °C °C V mA 0.9 x VDD 40 V V % nS mS V V nS ppm V 0.1 x VDD 60 10 10 50 0.7 x VDD 0.3 x VDD 100 ±200 1/2 VDD VDD Positive 10 ±50 0 % kHz kΩ ppm ppm pS pS 10 50 ±50 ±3 1.0 4.0 0.5 ■ PACKAGE DIMENSIONS NOTE *Available in selected operation temp. See P/N guide for other options See P/N guide for other options See P/N guide for other options See P/N guide for other options @ for 1st year @ 12kHz ~ 20MHz offset ■ REFLOW PROFILE ■ SOLDER PATTERN 2.0 6 5 4 1.8 2.4 170 ±5°C * 150 ±5°C 2.54 2.54 2 Pre-heating
TSMV-H50HM33ST2C-74.17582M 价格&库存
很抱歉,暂时无法提供与“TSMV-H50HM33ST2C-74.17582M”相匹配的价格&库存,您可以联系我们找货
