CARDINAL
CARDINAL COMPONENTS
COMPONENTS
LVPECL Surface Mount TCVCXO
* Serial Communications
* Routers
* Switches
* WAN Interfaces
* Test Equipment
* LVPECL Output
* Industry Standard Outline
Part Numbering Example:
CTVED
CTVED
Applications
CTVED Z - A5 B3 - 222.5792 TS
A5
Z
B3
OPERATING TEMP.
SERIES PACKAGING OPTIONS
CTVED Blank = Bulk
Blank = 0°C ~ +70°C
A5 = -20°C ~ +70°C
Z = Tape and Reel
STABILITY
B3 = ±2.5 ppm
222.5792
TS
FREQUENCY
TRI-STATE
TS = Tri-State
CTVED
Specifications:
Min
Frequency Range:
38
Stability:
Supply Voltage:
Typ
- 2.5
3.135
3.3
Max
Unit
640
MHz
+ 2.5
ppm
3.465
V
+/- 8
Frequency Tuning Range:
ppm
3.0
V
-30
+ 70
°C
Storage Temperature:
-40
+ 85
°C
Duty Cycle:
45
55
10
mS
1
ppm
100
mA
External Control Voltage:
0.35
Operating Temperature:
Start-Up Time:
3
Aging: (ppm/1st Year)
Ta=25C, Vdd=3.3V
Supply Current:
Short Circuit Current:
± 50
mA
RMS Period Jitter:
5
pS
RMS Integrated Jitter:
12kHz to 20MHz
0.7
pS
-120
Phase Noise @ 10kHz:
Dimensions are in mm
PIN Function
1 VCONTROL
2 DISABLE
3 Ground
4 LVPECL +
5 LVPECL 6 Vdd
dBc/Hz
Output Voltage:
Voh
Vol
Rise/Fall Time:
Output Level:
Packaging:
Vdd - 1.62
V
V
0.8
nS
Vdd - 1.025
0.4
LVPECL Levels Test Circuit
LVPECL
Vdd
Tape and Reel 1000 pcs per Reel
OUT
50Ω
50Ω
___
OUT
Cardinal Components, Inc., 155 Rt. 46 W, Wayne, NJ. 07470 TEL: (973)785-1333 FAX: (973)785-0053
E-Mail: sales@cardinalxtal.com
http://www.cardinalxtal.com
Rev.3-6/11/07
2.0 V
CTVED-A5B3-155.52TS 价格&库存
很抱歉,暂时无法提供与“CTVED-A5B3-155.52TS”相匹配的价格&库存,您可以联系我们找货
