OXJTGLJANF-25.000000 数据手册
OX Type
3.2 x 2.5 mm SMD Crystal Oscillator
Actual Size
FEATURE
- Typical 3.2 x 2.5 x 0.95mm Ceramic SMD Package
- Tight Symmetry (45 to 55%) Available
- Operation Voltage: 1.8V, 2.5V, 3.3V
- Tri-State Enable/Disable
TYPICAL APPLICATION
- WLAN/WiMAX
- Mobile Phone
- DSC, Set-Top Box, HDTV
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ TO P VIEW ]
2.10 ± 0.15
#2
#2
#1
1.60
1.65 ± 0.15
2.50 ± 0.15
#1
#4
1.10
#3
#3
0.65 ± 0.15
3.20 ± 0.15
#4
0.1 μF
[ B O T T O M V IE W ]
2.10
0.90 ± 0.15
Pin#
0.35
0.95 ± 0.15
[ S ID E V IE W ]
1
2
3
4
Function
1.20
Tri-state
GND
Output
VDD
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3V
Parameter
Supply Voltage Variation (VDD)
Frequency Range
2.5V
Min.
Max.
Min.
Max.
VDD-5%
VDD+5%
VDD-5%
VDD+5%
VDD-5%
VDD+5%
V
1.25
125
1.25
125
1.25
125
MHz
15
10
7
mA
1.5
1.5
1.2
mA
mA
24, 26, 30, 40
At 15pF Load
Fo < 10MHz
No Load Condition, 1.25MHz
Current
Unit
Max.
Standard Frequency
Supply
1.8V
Min.
MHz
No Load Condition, 10MHz
Fo < 20MHz
2
2
1.5
No Load Condition, 20MHz
Fo < 80MHz
3
2.5
1.5
mA
No Load Condition, 80MHz
Fo < 125MHz
8
7
5
mA
Duty Cycle
Output Level
45
55
45
55
45
55
Output High
2.97
2.25
1.62
V
Output Low
0.33
0.25
0.18
V
3
4
5
nSec
Fo < 10MHz
1.25MHz
Transition Time:
10MHz
Fo < 20MHz
3
3
4
nSec
Rise / Fall Time+
20MHz
Fo < 80MHz
3
3
4
nSec
80MHz
Fo < 125MHz
3
3
4
nSec
2
2
2
mSec
2.31
1.75
1.26
V
0.99
0.75
0.54
Startup Time
Tri-State
Enable (High Voltage or Floating)
(Input to Pin 1)
Disable (Low Voltage or GND)
Output Loading
15
15
15
V
pF
Stand by Current (@-40oC to 85oC)
10
10
10
Stand by Current (@-40oC to 125oC)
Period Jitter (Pk-Pk)
40
40
40
pSec
RMS Phase Jitter (12kHz to 20MHz)
1
1
1
pSec
Aging (@ 25oC, 1st Year)
3
3
3
ppm
-55
+125
-55
+125
-55
+125
Storage Temp. Range
A
A
o
C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position
+Transition times are measured between 10% and 90% of VDD,withan output load of 15pF
FREQ. STABILITY vs. TEMP. RANGE
ppm
Temp.( oC)
-10~+60
-20~+70
-40~+85
±20
25
50
* O: Available △:Conditional
X: Not available
*Inclusive of calibration @ 25℃, operating temperature range, input voltage variation,
st
load variation, aging (1 year), shock, and vibration load variation
Note: not all combination of options are available. Other specifications may be available upon request.
34
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(12)08/2019
OXJTGLJANF-25.000000 价格&库存
很抱歉,暂时无法提供与“OXJTGLJANF-25.000000”相匹配的价格&库存,您可以联系我们找货
