LFSPXO022731REEL
LFSPXO022731REEL
    IQD
    SMD7252_4P
    有源晶振 100.000000 MHz 3.3V -40℃~+85℃ HCMOS
LFSPXO022731REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO022731Reel Customer Part: Description Standard 7 x 5mm crystal oscillator in a ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPS-73 Model Issue number 14 Frequency Parameters Frequency 100.0MHz Frequency Stability ±50.00ppm Operating Temperature Range Ageing -40.00 to 85.00°C ±3ppm per year max Electrical Parameters 3.3V ±10% Supply Voltage Current Draw 40.000mA Note: parameters are referenced to 15pF load Outline (mm) Output Details HCMOS Output Compatibility Drive Capability 15pF max Rise and Fall Time 4.0ns max 45/55 Duty Cycle Start up time: 10ms max. 0.9ms typ to 90% of final amplitude ( under ideal conditions @ 25°C) Output Control Standby Operation: Logic ‘1’ (>70% VS) to pad 1 enables oscillator output Logic ‘0’ (
LFSPXO022731REEL
- 物料型号:LFSPXO022731Reel - 器件简介:标准7 x 5mm晶体振荡器,采用陶瓷封装和密封金属盖,密封性良好。 - 引脚分配:1. 待机操作,2. GND,3. 输出,4. +Vs - 参数特性: - 频率:100.0MHz ±50.00ppm - 频率稳定性:-40.00至85.00°C - 老化:±3ppm每年最大 - 供电电压:3.3V ±10% - 电流消耗:40.000mA - 输出细节:HCMOS,15pF最大负载,4.0ns最大上升/下降时间,45/55占空比 - 启动时间:最大10ms达到最终幅度的90% - 功能详解: - 待机操作:逻辑'1'(>70% VS)使能振荡器输出,逻辑'0'(<30% VS)禁用振荡器输出 - 待机电流:最大10µA,典型0.9µA @ 25°C - 应用信息:文档未明确提供应用信息,但根据振荡器的规格,适用于需要高精度时钟信号的电子设备。 - 封装信息:EIA-481-D标准胶带和卷轴包装,卷轴尺寸1000,提供替代包装选项。
LFSPXO022731REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO022731REEL”相匹配的价格&库存,您可以联系我们找货
