7C
MHz CMOS Oscillator
Features
Applications
Frequency range : 1MHz to 170MHz
SMD seam sealing ceramic package
Supply voltage : 1.8V ~ 3.3V
CMOS output
Tri-state function available
External dimensions (mm)
L : 5.0 x W : 3.2 x H : 1.2
RoHS compliant & Pb free
Networking, Server, Storage
Wireless communications
Fibre channel, Ethernet, SATA, SAS,
PCI-E, USB, WLAN, xDSL, xPON
PC mainboard, Notebook, HDD, SSD,
Graphics card, Computer peripherals
Audio, Video, Gaming, Printer, DSC,
IP CAM, Consumer products
Electrical Characteristics
Item
Frequency Range (F0)
Frequency Stability (Fstab)
Operating Temperature Range (T OTR)
Supply Voltage (VDD)
Current Consumption (IDD)
7C
1MHz ~ 170MHz
±50 , ±25 ppm
-10°C ~ +70°C; Note [1]
±50 , ±30 , ±25 , ±15 ppm
-40°C ~ +85°C; Note [1]
-10°C ~ +70°C
-40°C ~ +85°C
1.8V, 2.5V, 2.8V, 3.3V
1MHz ~ 75MHz
20 mA Max.
75MHz ~ 170MHz
CMOS
Output Load (CL)
15 pF
Output Voltage High (VOH)
90% VDD Min.
Output Voltage Low (VOL)
10% VDD Max.
Rise & Fall Time (Tr / Tf)
8 ns Max.
Phase Jitter, RMS
Aging (Faging)
Storage Temperature Range (T STR)
VDD ± 10%
10 mA Max.
Output Type
Duty Cycle
Start-up Time
Enable Voltage High, Logic "1"
Enable Voltage Low, Logic "0"
Conditions
40% ~ 60%
5 ms Max.
70% VDD Min.
30% VDD Max.
1 ps Max.
±3 ppm Max.
10% ~ 90% of VDD
Input to Pin1
Note [2]
Note [3]
at 25°C±3°C, first year
-55°C ~ +125°C
Notes:
[1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating
temperature, supply voltage, and load.
[2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0".
[3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz.
Rev. 1.05-a
Page 1
www.txccrystal.com
7C
MHz CMOS Oscillator
Dimensions
(Unit: mm)
B
C
F
Ordering Information
7C
± 50 ppm (-10˚C ~ +85˚C)
± 100 ppm (-10˚C ~ +70˚C)
± 100 ppm (-40˚C ~ +85˚C)
30.000M B B - T
Frequency in Hz
Packaging Method
T
Please contact us for
available frequencies
Supply Voltage
B
E
C
D
Rev. 1.05-a
Tape & Reel
Frequency Stability
B
C
F
3.3 V
2.8 V
2.5 V
1.8 V
Page 2
± 50 ppm (-10˚C ~ +70˚C)
www.txccrystal.com
7C
MHz CMOS Oscillator
Packing
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min.
Peak temperature : 260°C ± 10°C, 10 sec. Min.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.05-a
60 sec
Page 3
Time (sec)
www.txccrystal.com
QTM532-33.3330MBB-T 价格&库存
很抱歉,暂时无法提供与“QTM532-33.3330MBB-T”相匹配的价格&库存,您可以联系我们找货
