QTS532-20.000MBP-T
QTS532-20.000MBP-T
    QST(矽睿)
    SMD-6
    有源晶振 20MHz 3.3V SMD-6
QTS532-20.000MBP-T 数据手册
QTS532 Temperature Compensated Crystal Oscillator Fuel The Digital World Features ● ● ● ● ● ● ● ● Applications Frequency range : 10MHz to 52MHz SMD seam sealing ceramic package Supply voltage : 3.3V Free Run Stability for 20 Years : ±4.6ppm (Stratum 3) Clipped Sinewave output Voltage control function available External dimensions (mm) L : 5.0 x W : 3.2 x H : 1.5 RoHS compliant & Pb free ● ● ● ● ● Wireless communications, Smallcell, Base station Precise timing & synchronization network (IEEE1588, Sync.E), OTN, PTN, Switch Test and measurement equipment Smart grid Stratum 3 Electrical Characteristics Item Nominal Frequency Range (F 0) Frequency Tolerance (Ftol) vs Temperature Frequency Stability QTS532 Conditions 10MHz ~ 52MHz ±2.0 ppm Max. Note [1] ±0.1ppm, ±0.28ppm, ±0.5ppm Note [2] vs Load ±0.1 ppm Max. Load ±5% vs Supply Voltage ±0.1 ppm Max. VDD ±5% Operating Temperature Range (T OTR) -40°C ~ +85°C Supply Voltage (VDD) 3.3V Current Consumption (IDD) 5.0 mA Max. Output Type Clipped Sinewave Output Load 10kΩ // 10pF Output Level 0.8 V(p-p) Min. Start-up Time 2.5 ms Max. Note [3] Auto Frequency Control (AFC) Range ±5ppm ~ ±16ppm VCTCXO, optional VC = 1.5±1.0V Phase Noise -130 dBc/Hz Typ. at 1kHz offset Aging (Faging) ±1 ppm Max. at 25°C, first year 24 Hours Holdover Stability ±40 ppb Max. Note [4] Free Run Stability for 20 Years ±4.6 ppm Max. Note [5] Storage Temperature Range (T STR) -55°C ~ +125°C Rev. 1.02 Page 1 www.qstproducts.com QTS532 Temperature Compensated Crystal Oscillator Fuel The Digital World Notes: [1] Refer to nominal frequency, operation after 2 times of reflow at 25°C. [2] Refer to (Fmax + Fmin)/2. [3] Decoupling capacitor is required in external circuit. [4] 24 hours at constant temerature after 48 hours operation [5] Inclusive of initial tolerence at 25°C, variations over temerature, supply voltage, load, reflow soldering and aging for 20 years. Dimensions Pin function Function Pin Pin 1 TCXO VCTCXO GND or NC AFC Pin 2 NC Pin 3 GND Pin 4 OUTPUT Pin 5 NC Pin 6 VDD Recommended pad layout (Unit: mm) Ordering Information QTS532 - 19.200M B P - Frequency in Hz T Packaging Method T Please contact us for available frequencies Tape & Reel Frequency Stability (over Temp.) Supply Voltage B Rev. 1.02 F G O P T U 3.3 V Page 2 ± 0.5 ppm ± 0.5 ppm ± 0.28 ppm ± 0.28 ppm ± 0.1 ppm ± 0.1 ppm ( -40°C ~ +85°C ), ( -40°C ~ +85°C ), ( -40°C ~ +85°C ), ( -40°C ~ +85°C ), ( -40°C ~ +85°C ), ( -40°C ~ +85°C ), VCTCXO TCXO VCTCXO TCXO VCTCXO TCXO www.qstproducts.com QTS532 Temperature Compensated Crystal Oscillator Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min., 200 sec. Max. Peak temperature : 260°C ± 10°C, 10 sec. Min., 30 sec. Max. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.02 60 sec Page 3 Time (sec) www.qstproducts.com
QTS532-20.000MBP-T
物料型号:QTS532
器件简介:温度补偿晶体振荡器,用于数字世界的时间同步。
引脚分配: - Pin1: GND或NC(自动频率控制AFC) - Pin2: NC - Pin3: GND - Pin4: 输出 - Pin5: NC - Pin6: VDD
参数特性: - 供电电压:3.3V - 频率范围:10MHz至52MHz - 20年自由运行稳定性:±4.6ppm(Stratum 3) - 工作温度范围:-40°C至+85°C - 输出类型:削波正弦波 - 输出负载:10kΩ//10pF - 输出电平:最小0.8V峰峰值 - 启动时间:最大2.5毫秒 - 老化(Faging):第一年在25°C时±1ppm - 存储温度范围:-55°C至+125°C
功能详解: - 该振荡器具有自动频率控制功能,频率稳定性随温度、负载和电源电压变化而变化。 - 提供了外部尺寸和推荐的焊盘布局。
应用信息: - 适用于小型基站、无线通信网络、智能电网、精确计时与同步、测试和测量设备。
封装信息: - 封装类型:SMD,尺寸为5.0mm x 3.2mm x 1.5mm。
QTS532-20.000MBP-T 价格&库存
很抱歉,暂时无法提供与“QTS532-20.000MBP-T”相匹配的价格&库存,您可以联系我们找货
