OJJMDLVTNF-212.500000
    TAITIEN(泰艺)
    SMD5032_8P
    有源晶振 212.500000MHz 2.5V -40℃~+85℃ LVDS
OJJMDLVTNF-212.500000 数据手册
OJ-M Type High Frequency and Ultra Low Noise 5.0 x 3.2 mm SMD Crystal Oscillator FEATURE - Low Power Supply Voltage: 3.3, 2.5, and 1.8V supply options - Clock Output: LVPECL, LVDS, CML, HCSL and LVCMOS - Output frequency support from 15MHz to 2.1GHz - Ultra Low Noise, Phase Jitter < 300 fs (Typical: 150 fs at 12kHz to 20MHz frequency offsets) - Tri-state enable / disable mode. - Temperature Range: -40 to 85。C - Pb-free/RoHS Compliant Actual Size TYPICAL APPLICATION - SONET/SDH,. Gigabit Ethernet. - Storage Area Networking (SAN) - SD/HD video - FPGA clock generation RoHS Compliant DIMENSION (mm) SOLDER PAD L AYOUT (mm) PIN ASSIGNMENTS [ BOTTOM VIEW ] #8 #2 #7 #8 #3 #3 #2 #1 4.20 2.54 0.1uF GND 0.70 0.8 #1 #6 2.10 #7 #5 1.27 #4 #4 1.20 #5 2.10±0.20 3.2±0.20 #6 0.64 2.54±0.20 5.0±0.20 1.15 [ TOP VIEW ] 1.40±0.15 [ SIDE VIEW ] PIN# 1 2 3 4 5 6 7 8 FUNCTION LVPECL/LVDS/CML/HCSL NC OE GND Output Comp.Output VDD NC NC CMOS NC OE GND Output NC VDD NC NC 0.8 1.0 Recommended soldering pattern ☆To ensure optimal oscillator performance, place a by-pass capacitor of 0.1uF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION LVPECL Parameter Supply Voltage Variation (VDD) ± 10% Frequency Range Output Level Transition Time (20% - 80%) Duty Cycle Startup Time Tri-State mode (Input to Pin 2) Stand by Current Phase Noise At VDD=3.3V, fout=873.515MHz RMS Phase Jitter (12KHz to 20MHz) Period Jitter Unit Min. Max. Min. Max. VDD -10% 15 VDD +10% 2100 VDD -10% 15 VDD +10% 2100 V MHz MHz 95 VDD – 0.8 VDD – 1.55 0.35 0.35 55 8 0.3 x VDD 95 Max. 300 50 mA V V nSec nSec % mSec 100, 106.25, 125, 156.25, 187.5, 200, 212.5, 266, 300, 312.5, 400, 491.52, 622.08, 644.531250 Standard Frequency Supply Current 2.5V 3.3V Output High Output Low Rise Time Fall Time Enable Disable 1kHz offset 10kHz offset 100kHz offset 1MHz offset 20MHz offset VDD – 1.165 VDD – 2.0 45 0.7 x VDD VDD Typ. -106 -115 -123 -133 -150 150 - 110 VDD – 0.8 VDD – 1.55 0.35 0.35 55 8 0.3 x VDD 110 Max. 300 50 VDD – 1.165 VDD VDD – 2.0 0.8 VDD -– 2.0 45VDD – 1.55 0.7 x VDD Typ. -106 -115 -123 -133 -150 150 - V mA dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz fs ps Note: not all combination of options are available. Other specifications may be available upon request. 58 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(4)01/2020 LVDS Parameter Supply Voltage Variation (VDD) ± 5% Supply Voltage Variation (VDD) ± 10% Frequency Range Standard Frequency Supply Current Output Level Transition Time (20% - 80%) Duty Cycle Startup Time Tri-State mode (Input to Pin 2) Stand by Current Phase Noise 3.3V RMS Phase Jitter (12KHz to 20MHz) Period Jitter 1kHz offset 10kHz offset 100kHz offset 1MHz offset 10MHz offset Parameter Supply Voltage Variation (VDD) ± 5% Supply Voltage Variation (VDD) ± 10% Frequency Range Standard Frequency Supply Current Output Level Transition Time (20% - 80%) Duty Cycle Startup Time Tri-State mode (Input to Pin 2) Stand by Current Phase Noise At VDD=3.3V, Fout=805.664MHz RMS Phase Jitter (12KHz to 20MHz) Period Jitter Unit Min Max. Min Max. 3.63 15 2.97 2100 2.25 15 2.75 2100 1.71 15 1.89 2100 0.9 45 0.7 x VDD Typ. -106 -115 -123 -133 -150 150 - 90 1.6 0.35 0.35 55 8 0.3 x VDD 90 Max. 300 50 0.9 45 0.7 x VDD Typ. -106 -115 -123 -133 -150 150 - 0.9 45 0.7 x VDD Typ. -106 -115 -123 -133 -150 150 - 70 1.6 0.35 0.35 55 8 0.3 x VDD 70 Max. 300 50 Min. 3.63 15 3.3V 80 1.6 -0.35 0.35 55 8 0.3 x VDD 80 Max. 300 50 CML 2.5V Max. 2.97 2100 Min 2.25 15 90 VDD VDD – 0.32 0.35 0.35 55 8 0.3 x VDD 90 Max. 300 50 VDD – 0.085 VDD – 0.6 45 0.7 x VDD Typ. -107 -117 -125 -135 -150 150 - 1.8V Max. 2.75 2100 Min. 1.71 15 80 VDD VDD – 0.32 0.35 0.35 55 8 0.3 x VDD 80 Max. 300 50 VDD – 0.085 VDD – 0.6 45 0.7 x VDD Typ. -107 -117 -125 -135 -150 150 - Max. 1.89 2100 100, 106.25, 125, 156.25, 187.5, 200, 212.5, 266, 300, 312.5, 400, 491.52, 622.08, 644.531250 Output High Output Low Rise Time Fall Time Enable Disable 1kHz offset 10kHz offset 100kHz offset 1MHz offset 20MHz offset Parameter Supply Voltage Variation (VDD)±10% Frequency Range Supply Current Output High Output Level Output Low Transition Time Rise Time (20% - 80%) Fall Time Duty Cycle Startup Time Tri-State mode Enable (Input to Pin 2) Disable Stand by Current Disable Output Load Phase Noise 1kHz offset 10kHz offset At VDD=3.3V, fout= 100kHz offset 873.515MHz 1MHz offset 10MHz offset RMS Phase Jitter (12KHz to 20MHz) Period Jitter 1.8V Max. 100, 106.25, 125, 156.25, 187.5, 200, 212.5, 266, 300, 312.5, 400, 491.52, 622.08, 644.531250 Output High Output Low Rise Time Fall Time Enable Disable At VDD=3.3V, fout=873.515MHz 2.5V Min. VDD – 0.085 VDD – 0.6 45 0.7 x VDD Typ. -107 -117 -125 -135 -150 150 - HCSL 2.5V 3.3V Min. 3.63 15 15 0.66 0 45 0.7 x VDD - Max. 2.97 700 115 700 1.15 0.15 0.4 0.4 55 8 0.3 x VDD 115 Min 2.25 15 15 0.66 0 - 0.7x VDD - 70 VDD VDD – 0.32 0.35 0.35 55 8 0.3 x VDD 70 Max. 300 50 1.8V Max. 2.75 700 100 2100 1.15 0.15 0.4 0.4 55 8 0.3 x VDD 100 50 ohms to GND Typ. Max. Typ. Max. -87 -110 -127 -138 -153 150 - 300 50 -87 -110 -127 -138 -153 150 - 300 50 Min. 1.71 15 15 0.66 0 45 0.7xVDD Typ. -87 -110 -127 -138 -153 150 - V V MHz MHz mA V V nSec nSec % mSec V V mA dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz fs ps Unit V V MHz MHz mA V V nSec nSec % mSec V V mA dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz fs ps Unit Max. 1.89 700 94 2100 1.15 0.15 0.4 0.4 55 8 0.3 x VDD 94 V MHz mA V V nSec nSec % mSec V V mA Max. 300 50 dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz fs ps Note: not all combination of options are available. Other specifications may be available upon request. Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(4) 59 CMOS Parameter Supply Voltage Variation (VDD) Supply Voltage Variation (VDD) Frequency Range Standard Frequency Supply Current Output Level Transition Time (20% - 80%) Duty cycle Startup Time Tri-State mode (Input to Pin 2) Period Jitter 3.3V 2.5V 1.8V Unit Min. Max. Min Max. Min Max. 3.63 15 2.97 250 2.25 15 2.75 250 1.71 15 1.89 250 0.9 x VDD 45 40 0.7 x VDD - 90 0.1 x VDD 1.2 1.2 55 60 8 0.3 x VDD 100 0.9 x VDD 45 40 0.7 x VDD - 80 0.1 x VDD 1.5 1.5 55 60 8 0.3 x VDD 100 0.9 x VDD 45 40 0.7 x VDD - 70 0.1 x VDD 2 2 55 60 8 0.3 x VDD 100 5% 10% 100, 106.25, 125, 156.25, 187.5, 200, 212.5, 266, 300, 312.5, 400, 491.52, 622.08, 644.531250 Output High Output Low Rise Time Fall Time Fout < 100MHz Fout > 100MHz Enable Disable V V MHz MHz mA V V nSec nSec % % mSec V V ps FREQ. STABILITY vs. TEMP. RANGE ppm Temp. (°C) 20 -20~+70 -40~+85 60 25 30 50 O O O O O X Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(4)
OJJMDLVTNF-212.500000 价格&库存
很抱歉,暂时无法提供与“OJJMDLVTNF-212.500000”相匹配的价格&库存,您可以联系我们找货
  • 25+238.2509125+30.86319
