C7S-25.000-8-1520-M
C7S-25.000-8-1520-M
    AKER(安碁科技)
    SMD7050_4P
    无源晶振 25MHz 30Ω 8pF ±15ppm -20℃~+70℃ SMD7050_4P
C7S-25.000-8-1520-M 数据手册
Ltr RoHS Compliant Pb - Lead Free Appr Date Revisions Electrical Specifications: Frequency Range Fundamental Third Overtone Standard Mode of Oscillation Frequency Tolerance at 25°C Optional Standard Frequency Stability over Temperature Range Optional Standard Extended Operating Temperature Range Storage Temperature Range Aging Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance 6.000 to 133.000 6.000 to 50.000 40.000 to 133.000 ±30 ±25 ±20 ±15 ±10 ±50 ±30 ±25 ±20 ±15 ±10* -10 to +70 -40 to +85 -55 to +125 ±3 10 to 32 and Series Resonance 7.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc MHz MHz PPM Max PPM Max ºC PPM Max/Year pF Ohms uW Typ M Ohms Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation Frequency Range in MHz ESR Ohm Max Mode of Operation 6.000 to 7.999 70 Fundamental 40.000 to 79.999 70 3rd Overtone 8.000 to 9.999 40 Fundamental 80.000 to 133.000 60 3rd Overtone 10.000 to 14.999 35 Fundamental 15.000 to 39.999 30 Fundamental 40.000 to 50.000 20 Fundamental Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Dec 1, 2018 Microprocessor Crystal Unit Low Profile 7.0 x 5.0 millimeter Surface Mount - 4 Pad General Product Specification Part Number: C7S Series www.aker-usa.com Mechanical Outline: Ceramic Base Metal Lid 5.0 ± 0.15 7.0 ± 0.15 #4 #3 AKER #2 #1 1.1 Max. 4.6 5.9 #4 #3 1.0 1.4 2.54 #2 2.54 #1 1.7 1.2 #2:GND #4:GND Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: Dec 1, 2018 P/N: www.aker-usa.com C7S Series Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: Dec 1, 2018 P/N: www.aker-usa.com C7S Series How to build a Part Number: Series Package C 7S Frequency 6.000 to 133.000 10 12 16 18 20 32 S Load Capacitance Frequency Tolerance Option Standard Frequency Stability Option Mode of Oscillation See Notes 3 Standard Temperature Range Option See Notes X M R Packaging MHz - - 30 25 20 15 10 50 30 25 20 15 10 Standard - Parameter 5.0 x 7.0 mm 4 Pad - 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series ±30 PPM ±25 PPM ±20 PPM ± 15 PPM ±10 PPM ±50 PPM ±30 PPM ±25 PPM ±20 PPM ±15 PPM ±10 PPM* Fundamental Third Overtone -10 to +70 ºC -40 to +85 ºC 250pcs Reel 1000pcs Reel Part Number Example: C7S-64.000-18-3050-3-R C7S- 5 x 7 mm SMD Seam Seal Package - 4 pad 64.000 MHz Nominal Frequency 18 pF Load Capacitance 3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability Third Overtone Mode -10 to +70° C Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Fundamental mode does not need to be included in Part Number description. * ±10 PPM Temperature Stability is only available from -30 to +85° C. 2- Standard Temperature Range does not need to be included in Part Number description. 3- Product is shipped in Tape and Reel configuration Page: 4/4 Date: Dec 1, 2018 P/N: www.aker-usa.com C7S Series
C7S-25.000-8-1520-M
1. 物料型号:C7S系列 2. 器件简介:这是一种低剖面7.0 x 5.0毫米表面贴装4垫的微处理器晶体单元。 3. 引脚分配:文档中提到了4个引脚,其中#2和#4被标记为GND。 4. 参数特性: - 频率范围:6.000至133.000 MHz - 振荡模式:基础模式6.000至50.000 MHz,三次谐波40.000至133.000 MHz - 频率容差:标准±30 PPM,可选±25、±15、±10 - 频率稳定性:标准±50 PPM,可选±30、±25、±20、±15、±10 - 工作温度范围:标准-10至+70°C,扩展-40至+85°C - 老化:±3 PPM/年 - 负载电容:10至32 pF和串联谐振 - 等效串联电阻(ESR):见ESR表 - 驱动水平:典型100 uW - 绝缘电阻:在100Vdc±15 Vdc时为500 MΩ 5. 功能详解:文档提供了详细的频率范围和ESR值表,以及如何构建部件编号的指南。 6. 应用信息:适用于需要微处理器晶体单元的电子设备。 7. 封装信息:7.0 x 5.0毫米的表面贴装封装,带有金属盖和陶瓷基座。
C7S-25.000-8-1520-M 价格&库存
很抱歉,暂时无法提供与“C7S-25.000-8-1520-M”相匹配的价格&库存,您可以联系我们找货
