C6S-14.31818-20-1010-M
    AKER(安碁科技)
    SMD6035_4P
    无源晶振 20pF ±10ppm 60Ω -10℃~+70℃ SMD6035_4P 14.31818MHz
C6S-14.31818-20-1010-M 数据手册
Ltr RoHS Compliant Pb - Lead Free Appr Date Revisions Electrical Specifications: Frequency Range Fundamental Third Overtone Standard Mode of Oscillation Frequency Tolerance at 25°C Optional Standard Frequency Stability over Temperature Range Optional Standard Extended Operating Temperature Range Storage Temperature Range Aging Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance 7.372 to 133.000 7.372 to 52.000 40.000 to 133.000 ±30 ±25 ±20 ±15 ±10 ±50 ±30 ±25 ±20 ±15 ±10* -10 to +70 -40 to +85 -55 to +125 ±3 10 to 32 and Series Resonance 7.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc MHz MHZ PPM Max PPM Max ºC PPM Max/Year pF Ohms uW Typ M Ohms Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation Frequency Range in MHz 7.372 to 7.999 100 Fundamental 40.000 to 51.999 100 3rd Overtone 8.000 to 9.999 70 Fundamental 52.000 to 79.999 80 3rd Overtone 10.000 to 11.999 50 Fundamental 80.000 to 133.000 70 3rd Overtone 12.000 to 19.999 30 Fundamental 20.000 to 24.999 25 Fundamental 25.000 to 52.000 20 Fundamental ESR Ohm Max Mode of Operation Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Dec 1, 2018 Microprocessor Crystal Unit Low Profile 6.0 x 3.5 millimeter Surface Mount - 4 Pad General Product Specification Part Number: C6S Series www.aker-usa.com Mechanical Outline: Ceramic Base 6.0 ± 0.15 3.5 ± 0.15 Metal Lid #4 #3 AKER #1 #2 1.1 Max. 3.0 4.4 #2 #4 #3 1.35 #2:GND #4:GND 1.3 0.85 1.5 2.4 #1 1.8 Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: Dec 1, 2018 P/N: www.aker-usa.com C6S Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION 6.35 12.0 AKER AKER AKER AKER A 5.5 B A B 1.5 8.0 1.8 3.85 Dimensions are millimeters. A-A SECTION Solder Reflow Characteristics: Page: 3/4 Date: Dec 1, 2018 P/N: www.aker-usa.com C6S Series How to build a Part Number: Series Package Frequency Load Capacitance Standard Frequency Tolerance Option Standard Frequency Stability Option Mode of Oscillation Standard Temperature Range Extended Packaging C 6S 7.372 to 133.000 10 12 16 18 20 32 S 30 25 15 10 50 30 25 15 10 See Notes 3 See Notes X M R - Parameter 6.0 x 3.5 mm - 4 Pad MHz - 10 pF 12pF 16 pF 18 pF 20 pF 32 pF Series - ±30 PPM ±25 PPM ± 15 PPM ±10 PPM ±50 PPM ±30 PPM ±25 PPM ±15 PPM ±10 PPM* - Fundamental Third Overtone - -10 to +70 ºC -40 to +85 ºC - 250pcs Reel 1000pcs Reel Part Number Example: C6S-80.000-S-3030-3-R C6S: 3.5 x 6.0 mm SMD Seam Seal Package - 4 Pad 80.000 MHz Nominal Frequency S: Series Resonance 3030: ±30 PPM Frequency Tolerance and ±30 PPM Frequency Stability 3: Third Overtone Mode -10 to +70° C Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Fundamental mode does not need to be included in Part Number description. * ±10 PPM Temperature Stability is only available from -30 to +85° C. 2- Standard Temperature Range does not need to be included in Part Number description. 3- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 4- Quantities less than 1000 are shipped bulk in ESD pouches. 5- Specification subject to change without notice. Page: 4/4 Date: Dec 1, 2018 P/N: www.aker-usa.com C6S Series
1. 物料型号:C6S系列 2. 器件简介:微处理器晶体单元,低轮廓6.0 x 3.5毫米表面贴装-4垫。 3. 引脚分配:文档中提到了#1、#2、#3和#4,其中#2和#4被标记为GND。 4. 参数特性: - 频率范围:7.372至133.000 MHz,具体取决于模式。 - 振荡模式:基频和三次谐波。 - 频率容差:标准为±30 PPM,可选±25、±20、±15、±10 PPM。 - 频率稳定性:标准为±50 PPM,可选±30、±25、±20、±15、±10 PPM。 - 工作温度范围:标准为-10至+70°C,扩展为-40至+85°C。 - 老化:±3 PPM/年。 - 负载电容:10至32 pF和串联谐振。 - 等效串联电阻(ESR):见ESR表。 - 驱动水平:典型100微瓦。 - 绝缘电阻:在100Vdc±15Vdc下为500M欧姆。 5. 功能详解:文档详细描述了晶体单元的电气特性和操作条件。 6. 应用信息:适用于微处理器时钟源。 7. 封装信息:密封陶瓷金属封装,尺寸为6.0 x 3.5毫米。
C6S-14.31818-20-1010-M 价格&库存
很抱歉,暂时无法提供与“C6S-14.31818-20-1010-M”相匹配的价格&库存,您可以联系我们找货
