LFSPXO025876REEL
LFSPXO025876REEL
    IQD
    SMD7050_4P
    有源晶振 13.560000MHz 5V -40℃~+85℃ HCMOS, TTL
LFSPXO025876REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO025876Reel Customer Part: Description Standard 7 x 5mm crystal oscillator in a ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPS-72 Model Issue number 14 Frequency Parameters Frequency 13.560MHz Frequency Stability ±100.00ppm Operating Temperature Range Ageing -40.00 to 85.00°C ±3ppm per year max Electrical Parameters 5.0V ±10% Supply Voltage Current Draw 20.000mA Note: parameters are referenced to 15pF load Outline (mm) Output Details HCMOS/TTL Output Compatibility Drive Capability 15pF std, 50pF max Rise and Fall Time 10.0ns max 45/55% Duty Cycle Start up time: 10ms max 1.1ms typ to 90% of final amplitude (under ideal conditions @ 25°C) Output Control Standby Operation: Logic ‘1’ (>70% Vs) to pad 1 enables oscillator output. Logic ‘0’ (
LFSPXO025876REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO025876REEL”相匹配的价格&库存,您可以联系我们找货
