SXO75L3B481-125.000M
    SUNTSU
    SMD7050_6P
    有源晶振 125.000000 MHz ±30ppm 3.3V -40℃~+85℃ LVDS
SXO75L3B481-125.000M 数据手册
Ceramic SMT 6 Pad LVDS Oscillator SXO75L Series 7.0mm x 5.0mm Features Applications • ±20ppm (Frequency Stability) Available • Fiber Channel • Ceramic Package • Gigabit Ethernet • LVDS • PCI Express • Tape and Reel • Part Numbering Guide SXO 75 L 3 A 48 1 - 155.520M SUNTSU OSC FREQUENCY MHz TRI-STATE (ENABLE/DISABLE) 1 : Pin 1 2 : Pin 2 7.0mm x 5.0mm LVDS OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C FREQUENCY STABILITY 16 : -10°C - +60°C A : ±50ppm 17 : -10°C - +70°C B : ±30ppm CO M P L I A N T 27 : -20°C - +70°C C : ±25ppm Cage Code : 4GUT4 38 : -30°C - +85°C *D : ±20ppm To customize your parameters, contact a Suntsu representative. 48 : -40°C - +85°C * For Frequency stability option D, contact a Suntsu representative. SUPPLY VOLTAGE 2 : 2.5V±5% 3 : 3.3V±5% Electrical Parameters Units Minimum Frequency Range MHz 80 Typical Maximum 260 Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change, and First Year Aging at 25°C.) ppm -20 +20 See part numbering guide for options Operating Temperature °C -40 +85 See part numbering guide for options Storage Temperature °C -55 +125 Supply Voltage (VDD) - 2.5V Option V 2.375 2.5 2.625 Supply Voltage (VDD) - 3.3V Option V 3.135 3.3 3.465 Current (IDD) - 2.5V Option mA Current (IDD) - 3.3V Option mA 60 Output Load (LVDS) Ω 100 Output Logic Levels High (VOH) V Output Logic Levels Low (VOL) V 0.9 1.1 Differential Output Voltage (VOD) mV 247 330 454 Differential Output Error (DVOD) mV 1.125 1.250 1.375 0.4 0.8 50 55 Offset Voltage (VOS) V 50 1.43 mV Rise (TR) and Fall (TF) Time ns Symmetry (Duty Cycle) % 45 Tri-State Input Voltage - Enable V 0.7*VDD Tri-State Input Voltage - Disable V Start-Up Time ms ps www.suntsu.com Specifications are subject to change without notice. 1.6 50 Offset Error (DVOS) Phase Jitter (12kHz ~ 20MHz) Remarks 50 No Connection 0.3*VDD 10 0.4 1 Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad LVDS Oscillator SXO75L Series 7.0mm x 5.0mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (LVDS) Waveform (LVDS) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 100.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 125.000MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad LVDS Oscillator SXO75L Series 7.0mm x 5.0mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 100.000MHz Frequency - 125.000MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 1,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad LVDS Oscillator SXO75L Series 7.0mm x 5.0mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SXO75L系列
器件简介:这是一款陶瓷表面贴装(SMT) LVDS振荡器,具有±20ppm的频率稳定性,适用于光纤通道、千兆以太网和PCI Express等应用。
引脚分配: - 1:三态或无连接(NC) - 2:三态或无连接(NC) - 3:地(GND) - 4:输出(OUTPUT) - 5:互补输出(COMP OUTPUT) - 6:电源电压(Voo)
参数特性: - 频率范围:80MHz至260MHz - 频率稳定性:包括初始容差、工作温度范围内的稳定性、输出负载变化、电源电压变化和第一年老化 - 工作温度:-40°C至+85°C,具体范围可选项见型号指南 - 存储温度:-55°C至+125°C - 电源电压选项:2.5V±5%或3.3V±5% - 输出负载:5至100欧姆 - 输出逻辑电平:高电平1.43V至1.6V,低电平0.9V至1.1V - 差分输出电压:247mV至454mV - 相位抖动:12kHz至20MHz,典型值0.4ps至1ps
功能详解:该振荡器提供频率稳定性选项,可通过型号指南定制参数。它还具有三态功能,允许通过特定的输入电压来启用或禁用输出。
应用信息:适用于光纤通道、千兆以太网和PCI Express等高速通信应用。
封装信息:7.0mm x 5.0mm的尺寸,采用陶瓷封装,支持胶带和卷轴包装。
环境和机械规格:符合MIL-STD-883和J-STD-020等标准,包括温度循环、泄漏测试、振动、湿度抵抗等。
制造商信息:Suntsu Electronics, Inc.,位于美国加利福尼亚州欧文市。
SXO75L3B481-125.000M 价格&库存
很抱歉,暂时无法提供与“SXO75L3B481-125.000M”相匹配的价格&库存,您可以联系我们找货
