PART CODE:
YP32K76800S002
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
N0223- YP32K76800S002
DATE
Feb. 23, 2021
REVISION
A0
DESCRIPITION
KHz Plastic SMD Crystals, L8.0*W3.8*H2.4mm, 4 Pads, CCMC series
32.76800KHz, +/-20ppm, CL 6pF, Operating Temp. Range -40°C ~+85°C,
ESR 50 Kohm Max, Reflow Profile Condition 260 °C Max. Tape/Reel,
RoHS/RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS
EU 2015/863)
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
TGS CCMC 32K768A20-6-40-50TLH
PART CODE
YP32K76800S002
VENDOR APPROVE
Issued/Checked/Approved
DATE: Feb. 23, 2021
CUSTOMER APPROVE
DATE:
NextGen Components, Inc.
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
YP32K76800S002
KHZ PLASTIC SMD
SMDCRYSTALS
CRYSTAL 2520
8038 TYPE 4 PADS
MAIN FEATURE
• SMD Package, 8038 Type, L8.0*W3.8*H2.4mm, 4 Pads
• Low cost and short lead time
• Industry standard
• Reflow Profile Condition 260 °C Max.
• Cross more competitors part
• RoHS/RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863)
APPLICATION
• Clock source for Portable
• Microcomputer & Automotive Equipment with Low power consumption
RFQ
PART CODE GUIDE
Request For Quotation
YP
32K76800
S
002
1
2
3
4
1) YP: Part family Code for KHz Plastic SMD Crystals, L8.0*W3.8*H2.4mm, 4 Pads, CCMC series
2) 32K76800: Frequency range code for 32.76800KHz
3) S: SMD type, Package Tape/Reel, 3000pcs/Reel
4) 002: Specification code for original part No.: TGS CCMC 32K768A20-6-40-50TLH
MORE FREQUENCY RANGE AVAILABLE (KHz)
32.768
100.00
153.60
PART CODE:
YP32K76800S002
KHZ PLASTIC SMD CRYSTALS 8038 TYPE 4 PADS
DIMENSION (Unit: mm, Tol. +/-0.15mm)
Image for reference
CCMC
Marking
Line 1: Frequency Range
Note:
Recommend Pad Layout
Do not connect pad 2 and Pad 3 to
external devices.
Metal inside may be exposed on the
top or bottom of plastic case
It isn't Quality problem. This will not
affect any quality, reliability and
electrical specification when used
Pin Function
#1 Crystal
#2 Ground
#3 Ground
#4 Crystal
PART CODE:
YP32K76800S002
ELECTRICAL PARAMETERS
Parameter
Part No.
Symbol
Units
Value
Min.
Original Manufacturer
Holder Type
Frequency Range
TGS Crystals
CCMC
32K768
KHz
A
Frequency Tolerance
ppm
Load Capacitance
-6
pF
Frequency/Temp
Coefficient
32.76800
AT Fundamental
-20
-40
-50
+20
0.028
0.034
0.04
°C
-40
+85
°C
-40
+85
KΩ
50
Drive Level
μW
1.0
Shunt Capacitance
(C0)
pF
Dynamic Capacitance
fF
Turnover Temp
°C
0.9
1.35
2.0
1.8
+20
+25
Quality Factor
+30
60000
Capacitance Ratio
450
Aging
ppm/year
Insulation Resistance
±3
MΩ
500
@1st year
@100VDC
± 15VDC
Package
T
RoHS Status
LH
Other
@25°C
6
ppm/C²
Storage Temperance
Equivalent Series
Resistance (ESR)
Max.
TGS
Mode of Oscillation
Operation
Temperance
Typical
Condition
Add Value
N/A
Internal
Control
Code *
N/A
Note: 1) Original Part Number: TGS CCMC 32K768A20-6-40-50TLH
2) * Internal Control Code- 2 letter or digits; Blank: N/A
PART CODE:
YP32K76800S002
RELIABILITY
Test Items
Test Method And Conditions
Reference
Documents
High Temperature
High Humidity Storage
Temperature: 85℃±3℃
Relative Humidity:85%RH
Time: 96 Hours
JIS C5023
High Temperature
Storage
Temperature: 125℃±3℃
Time: 96 Hours.
MIL-STD-883E
Method 1005.8
Low Temperature
Storage
Temperature: -40℃±3℃
Time: 96 Hours.
MIL-STD-883E
Method 1013
Thermal Shock
Temperature 1: -55℃±5℃
Temperature 2: 85℃±5 ℃
Temperature change between T1 and T2 5 min
10cycles maintain T1 and T2 for 30 minutes each cycle
MIL-STD-202F
Method 107
Condition A
Resistance to Solder
Heat
Solder Temperature: 260℃±5℃
Time: 10±1 Seconds
MIL-STD-202F
Method 210E
Solderability
The solder pot temperature is 245±5℃ , dwell time 5±0.5sec
J-STD-002B
Drop Test
3 Times Free Fall from 50cm height table to 3cm thickness
hard wood board
J-STD-002B
Mechanical Shock
Half sine wave,1000 G
3 Times for all 3 directions(X,Y Z)
MIL STD 202F
Method 213B
Vibration
Frequency Range: 10Hz~55Hz
Amplitude: 0.75mm
2 Hours in each direction, total 6 Hours
MIL-STD-883E
Method 2007.3
Leakage Test
Take measurements with a helium
Leakage detector
Leakage Rate≤1×10ˉ³Pa cm³/s
MIL-STD-883E
PART CODE:
YP32K76800S002
SUGGESTED REFLOW PROFILE (For Reference Only)
Total time: 200 Sec. Max. Solder melting point: 220℃
Profile Feature
Pb-Free Assembly
Average Ramp-up Rate (Ts Max to Tp)
3℃/second Max
Preheat
Temperature Min (Ts Min.)
125℃
Temperature Max (Ts Max.)
200℃
Time (ts Min. to ts Max.)
60~180 seconds
Temperature (TL)
217℃
Time (tL)
60~150 seconds
Time maintained
above
Peak/Classification Temperature (Tp)
260 ℃
Time within 5℃ of actual Peak Temperature (tp)
20~40 seconds
Ramp-down rate
6 ℃ /Second Max.
Time 25 ℃ to Peak Temperature
8 minutes Max.
Suggest reflow times
3 Times Max.
PART CODE:
YP32K76800S002
TAPE/REEL (Unit: mm)
All Devices are packed in accordance with EIA standard RS-481-2 and specifications, 3000pcs/Reel
DISCLAIMER
NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained
herein without notice. No liability is assumed as a result of their use or application. No rights under any patent
accompany the sale of any such product(s) or information
很抱歉,暂时无法提供与“YP32K76800S002”相匹配的价格&库存,您可以联系我们找货
