SVC75C3B07A2-27.000MT
    SUNTSU
    SMD7050_6P
    有源晶振 27MHz 3.3V ±30ppm SMD7050_6P
SVC75C3B07A2-27.000MT 数据手册
Ceramic SMT 6 Pad CMOS VCXO SVC75C Series 7.5mm x 5.0mm Features Applications • ±20ppm (Frequency Stability) Available • Digital TV • Miniature Package • DVD, STB • CMOS • PCMIA, XDSL • Fundamental or PLL (Phase Lock Loop) Available • Broadband Access • Tape and Reel • Base Stations Part Numbering Guide SVC 75 C 3 A 48 A 2 - 27.000M SUNTSU VCXO 7.0mm x 5.0mm CMOS SUPPLY VOLTAGE 2 : 2.5V±5% 3 : 3.3V±5% 5 : 5.0V±5% FREQUENCY STABILITY A : ±50ppm B : ±30ppm C : ±25ppm Cage Code: 4GUT4 D : ±20ppm To customize your parameters contact a Suntsu representative. *E : ±15ppm * For frequency stability option E contact a Suntsu representative. COMPLIANT Electrical Parameters Units Minimum Frequency Range MHz 1 300 Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change and First Year Aging at 25°C.) ppm -20 +20 See part numbering guide for options. Operating Temperature °C -40 +85 See part numbering guide for options. Storage Temperature °C -55 +125 Only available with AT-Cut Fundamental. Supply Voltage (VDD) 2.5V Option V 2.375 2.5 2.625 Available with AT-Cut Fundamental and PLL. Supply Voltage (VDD) 3.5V Option V 3.135 3.3 3.465 Only available with AT-Cut Fundamental. V 4.750 5.0 5.250 Supply Voltage (VDD) 5.0V Option Typical OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C Maximum FREQUENCY MHz TRI-STATE (ENABLE/DISABLE) Blank: No Connection PULLABILITY 2 : Pin 2 A : ±150ppm 5: Pin 5 B : ±100ppm C : ±80ppm D : ±50ppm Current (IDD) 2.5V Option mA 25 Current (IDD) 3.5V Option mA 25 Current (IDD) 5.0V Option mA V 0.2 2.3 Current Voltage (VC) 3.5V Option V 0.3 3.0 Pullability V 0.5 ppm ±50 Linearity % Output Load (CMOS) pF Output Logic HIGH Level (VOH) V 25mA max (AT-Cut Fund) & 50mA max (PLL). 30 Current Voltage (VC) 2.5V Option Current Voltage (Vc) 5.0V Option Remarks 4.5 ±100 ±150 See part numbering guide for options. 10 15 0.9*VDD Output Logic LOW Level (VOL) V Rise (TR) And Fall (TF) Time ns Symmetry (Duty Cycle) % 45 Tri-State Input Voltage Enable V 0.7*VDD Tri-State Input Voltage Disable V 0.3*VDD Start-Up Time ms 10 Phase Jitter (12KHz ~ 20MHz) ps 1 AT-CUT Fundamental Phase Jitter (12KHz ~ 20MHz) ps 5 PLL (Phase Lock Loop) www.suntsu.com Specifications are subject to change without notice. 0.1*VDD 5 50 55 No Connection Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad CMOS VCXO SVC75C Series 7.5mm x 5.0mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (CMOS) Waveform (CMOS) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 27.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 74.250MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad CMOS VCXO SVC75C Series 7.5mm x 5.0mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 27.000MHz Frequency - 74.250MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 1,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad CMOS VCXO SVC75C Series 7.5mm x 5.0mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SUNTSU SVC75C系列
器件简介:这是一款陶瓷SMT 6 Pad CMOS VCXO,具有±20ppm的频率稳定性,提供微型封装,CMOS兼容,支持基本模式或相位锁定环(PLL)模式,适用于宽带接入。
引脚分配:文档中提供了引脚功能表,包括电压控制、三态或无连接、地、输出等。
参数特性:包括频率范围、频率稳定性、存储温度、供电电压、工作电流、拉出能力、线性度、输出负载、输出逻辑电平、上升和下降时间、对称性、三态输入电压、启动时间、相位抖动等。
功能详解:文档详细描述了器件的电气参数,包括频率稳定性的详细说明,以及不同工作温度下的参数变化。
应用信息:适用于数字电视、DVD、机顶盒(STB)、PCMCIA、xDSL、基站等。
封装信息:提供了7.5mm x 5.0mm的外形尺寸图和焊盘图案。
SVC75C3B07A2-27.000MT 价格&库存
很抱歉,暂时无法提供与“SVC75C3B07A2-27.000MT”相匹配的价格&库存,您可以联系我们找货
