SIT3521AC-2C133-SU50.523333X
    SITIME
    VQFN-10
    有源晶振 3.3V ±20ppm 50.523333MHz VQFN-10
SIT3521AC-2C133-SU50.523333X 数据手册
SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Description Features The SiT3521 is an ultra-low jitter, user programmable oscillator which offers the system designer great flexibility and functionality. ◼ ◼ The device supports two in-system programming options after powering up at a default, factory programmed startup frequency: ◼ Any-frequency mode where the clock output can be re-programmed to any frequency between 1 MHz and 340 MHz in 1 Hz steps ◼ ◼ ◼ ◼ Digitally controlled oscillator (DCO) mode where the clock output can be steered or pulled by up to ±3200 ppm with 5 to 94 ppt (parts per trillion) resolution. The device’s default start-up frequency is specified in the ordering code. User programming of the device is achieved via I2C or SPI. Up to 16 I2C addresses can be specified by the user either as a factory programmable option or via hardware pins, enabling the device to share the I2C with other I2C devices. DualMEMS® The SiT3521 utilizes SiTime’s unique temperature sensing and TurboCompensation® technology to deliver exceptional dynamic performance: ◼ ◼ ◼ Programmable frequencies (factory or via I2C/SPI) from 1 MHz to 340 MHz Digital frequency pulling (DCO) via I2C/SPI ▪ Output frequency pulling with perfect pull linearity ▪ 13 programmable pull range options to ±3200 ppm ▪ Frequency pull resolution as low as 5 ppt (0.005 ppb) 0.21 ps typical integrated phase jitter (12 kHz to 20 MHz) Integrated LDO for on-chip power supply noise filtering 0.02 ps/mV PSNR -40°C to 105°C operating temperature LVPECL, LVDS, or HCSL outputs ▪ Programmable LVPECL, LVDS Swing ▪ LVDS Common Mode Voltage Control RoHS and REACH compliant, Pb-free, Halogen-free and Antimony-free Applications ◼ ◼ ◼ ◼ Resistant to airflow and thermal shock ◼ ◼ Resistant to shock and vibration ◼ ◼ Superior power supply noise rejection ◼ ◼ Ethernet: 1/10/40/100/400 Gbps G.fast and xDSL Optical Transport: SONET/SDH, OTN Clock and data recovery Processor over-clocking Low jitter clock generation Server, storage, datacenter Test and measurement Broadcasting Combined with wide frequency range and user programmability, this device is ideal for telecom, networking and industrial applications that require a variety of frequencies and operate in noisy environment. ◼ Block Diagram Package Pinout (10-Lead QFN, 5.0 x 3.2 mm) ◼ SD SC A/ M LK 10 IS O 9 OE / NC 1 8 VDD OE / NC 2 7 OUT- GND 3 6 OUT+ 4 5 A1 A0 /N /N C/ C/ M SS O SI Figure 2. Pin Assignments (Top view) (Refer to Table 14 for Pin Descriptions) Figure 1. SiT3521 Block Diagram Rev 1.01 30 April 2021 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Ordering Information SiT3521 AC -1C133 1 GG156.250000T Part Family “SiT3521” 12 mm Tape & Reel, 3 ku reel 12 mm Tape & Reel, 1 ku reel [2] Revision Letter “A” is the revision of Silicon Frequency 1.000000 to 340. 000000 MHz Temperature Range “C” : Extended Commercial, -20 to 70°C “ I ” : Industrial, -40 to 85°C “E” : Extended Industrial, -40 to 105°C[1] DCXO Pull Range “M” : “B” : “C” : “E” : “F” : “G” : “H” : “X” : “L” : “Y” : “S” : “Z” : “U” : Signaling Type “1”: LVPECL “2”: LVDS “4”: HCSL Package Size “C”: 5.0 x 3.2 mm Frequency Stability/Grade “F”: ±10 ppm “1”: ±20 ppm “2”: ±25 ppm “3”: ±50 ppm ± 25 ppm ± 50 ppm ± 80 ppm ±100 ppm ±125 ppm ±150 ppm ±200 ppm ±400 ppm ± 600 ppm ±800 ppm ±1200 ppm ±1600 ppm ±3200 ppm Serial IF mode “S” : SPI mode[1] “0-G” : I2C mode (See below) 2 I C Factory Programmable Addresses 2 “0-F” : I C Address factory programmed Sets Bits 3: 0 of Device I 2 C address to the Hex value of the ordering code . 2 When the I C address is factory programmed using these codes , pin A0, A1 are NC Voltage Supply “25”: “28”: “30”: “33”: 2.5 V 2.8 V 3.0 V 3.3 V ±10% ±10% ±10% ±10% OE Pin Control “G”: I2C address controlled by A0, A1 pins “-”: OE under software Control. Pin 1 and 2 are both NC. “1”: Pin 1 OE, Pin 2 NC “2”: Pin 1 NC, Pin 2 OE A1:A0 00 01 10 11 I2C Address 1100000 1100010 1101000 1101010 (default) Notes: 1. -40 to 105°C option available only for I2C operation. 2. Bulk is available for sampling only. Rev 1.01 Page 2 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator TABLE OF CONTENTS Description ................................................................................................................................................................................... 1 Features....................................................................................................................................................................................... 1 Applications ................................................................................................................................................................................. 1 Block Diagram ............................................................................................................................................................................. 1 Ordering Information .................................................................................................................................................................... 2 1 Electrical Characteristics ......................................................................................................................................................... 4 2 Device Configurations and Pin-outs ........................................................................................................................................ 9 3 Waveform Diagrams ............................................................................................................................................................. 11 4 Termination Diagrams ........................................................................................................................................................... 13 LVPECL .................................................................................................................................................................... 13 LVDS ........................................................................................................................................................................ 14 HCSL ........................................................................................................................................................................ 15 5 Test Circuit Diagrams ........................................................................................................................................................... 16 6 Architecture Overview ........................................................................................................................................................... 18 7 Functional Overview ............................................................................................................................................................. 18 User Programming Interface ..................................................................................................................................... 18 Start-up output frequency and signaling types ........................................................................................................... 18 In-system programmable options.............................................................................................................................. 18 8 In-system Programmable Functional Description.................................................................................................................. 19 Any-frequency function ............................................................................................................................................. 19 DCO Functional Description ..................................................................................................................................... 23 Pull Range, Absolute Pull Range .............................................................................................................................. 25 Software OE Functional Description ......................................................................................................................... 27 9 I2C/SPI Control Registers...................................................................................................................................................... 28 Register Address: 0x00. DCO Frequency Control Least Significant Word (LSW) .................................................... 28 Register Address: 0x01. OE Control, DCO Frequency Control Most Significant Word (MSW) ................................. 29 Register Address: 0x02. DCO PULL RANGE CONTROL ........................................................................................ 29 Register Address: 0x03. Frac-N PLL Feedback Divider Integer Value and Frac-N PLL Feedback Divider Fraction Value MSW ............................................................................................................................................................... 30 Register Address: 0x04. Frac-N PLL Feedback Divider Fraction Value LSW ........................................................... 30 Register Address: 0x05. Forward Divider, Driver Control ......................................................................................... 30 Register Address: 0x06. Driver Divider, Driver Control ............................................................................................. 31 10 I2C Operation ........................................................................................................................................................................ 32 I2C protocol ............................................................................................................................................................... 32 I2C Timing Specification ............................................................................................................................................ 35 I2C Device Address Modes ....................................................................................................................................... 36 11 SPI Operation ....................................................................................................................................................................... 37 Schematic Examples ................................................................................................................................................................. 40 Dimensions and Patterns ........................................................................................................................................................... 43 Additional Information ................................................................................................................................................................ 44 Revision History ......................................................................................................................................................................... 45 Rev 1.01 Page 3 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 1 Electrical Characteristics All Min and Max limits in the Electrical Characteristics tables are specified over temperature and rated operating voltage with standard output terminations shown in the termination diagrams. Typical values are at 25°C and nominal supply voltage. Table 1. Electrical Characteristics – Common to LVPECL, LVDS and HCSL Parameter Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 1 – 340 MHz Factory or user programmable, accurate to 6 decimal places Frequency Stability Frequency Stability F_stab -10 – +10 ppm -20 – +20 ppm -25 – +25 ppm -50 – +50 ppm – ppm Inclusive of initial tolerance, operating temperature, rated power supply voltage and load variations. First Year Aging F_1y – ±1 Operating Temperature Range T_use -20 – +70 °C Extended Commercial -40 – +85 °C Industrial -40 – +105 °C Extended Industrial. Available only for I2C operation, not SPI. 2.97 3.3 3.63 V 2.7 3.0 3.3 V 2.52 2.8 3.08 V 2.25 2.5 2.75 V 1st-year aging at 25°C Temperature Range Supply Voltage Supply Voltage Vdd Input Characteristics – OE Pin Input Voltage High VIH 70% – – Vdd OE pin Input Voltage Low VIL – – 30% Vdd OE pin Input Pull-up Impedance Z_in – 100 – kΩ OE pin, logic high or logic low Output Characteristics Duty Cycle DC 45 – 55 % Startup and Output Enable/Disable Timing T_start – – 3.0 ms Measured from the time Vdd reaches its rated minimum value Output Enable/Disable Time – Hardware control via OE pin T_oe_hw – – 3.8 µs Measured from the time OE pin reaches rated VIH and VIL to the time clock pins reach 90% of swing and high-Z. See Figure 9 and Figure 10 Output Enable/Disable Time – Software control via I2C/SPI T_oe_sw – – 6.5 µs Measured from the time the last byte of command is transmitted via I2C/SPI (reg1) to the time clock pins reach 90% of swing and high-Z. See Figure 30 and Figure 31 Start-up Time Rev 1.01 Page 4 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Table 2. Electrical Characteristics – LVPECL Specific Parameter Symbol Min. Typ. Max. Unit Condition Current Consumption Idd – – 89 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE Output Disable Leakage Current I_leak – – 58 mA OE = Low – 0.15 – A OE = Low I_driver – – 32 mA Maximum average current drawn from OUT+ or OUT- Output High Voltage VOH Vdd - 1.1V – Vdd - 0.7V V See Figure 5 Output Low Voltage VOL Vdd - 1.9V – Vdd - 1.5V V See Figure 5 V_Swing 1.2 1.6 2.0 V See Figure 6 Tr, Tf – 225 290 ps 20% to 80%, see Figure 6 Current Consumption Maximum Output Current Output Characteristics Output Differential Voltage Swing Rise/Fall Time Jitter RMS Phase Jitter (random) – DCO Mode Only T_phj RMS Phase Jitter (random) – Any-frequency Mode Only T_phj RMS Period Jitter[3] T_jitt – 0.225 0.340 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels – 0.1 0.14 ps f = 156.25, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, all Vdd levels – 0.225 0.340 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels – 0.11 0.15 ps f = 156.25, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, all Vdd levels – 1 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V Max. Unit Note: 3. Measured according to JESD65B. Table 3. Electrical Characteristics – LVDS Specific Parameter Symbol Min. Typ. Condition Current Consumption Idd – – 80 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE – – 61 mA OE = Low Output Disable Leakage Current I_leak – 0.15 – A OE = Low Differential Output Voltage VOD 250 – 455 mV f = 156.25MHz See Figure 7 ΔVOD – – 50 mV See Figure 7 Current Consumption Output Characteristics Delta VOD VOS 1.125 – 1.375 V See Figure 7 Delta VOS ΔVOS – – 50 mV See Figure 7 Rise/Fall Time Tr, Tf – 400 470 ps Measured with 2 pF capacitive loading to GND, 20% to 80%, see Figure 8 RMS Phase Jitter (random) – DCO Mode Only T_phj – 0.21 0.275 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels – 0.1 0.12 ps f = 156.25, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, all Vdd levels – 0.21 0.367 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels – 0.1 0.12 ps f = 156.25, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, all Vdd levels – 1 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V Offset Voltage Jitter RMS Phase Jitter (random) – Any-frequency Mode Only RMS Period Jitter[4] T_phj T_jitt Note: 4. Measured according to JESD65B. Rev 1.01 Page 5 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Table 4. Electrical Characteristics – HCSL Parameter Symbol Min. Typ. Max. Unit Condition Current Consumption Idd – – 93 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE – – 60 mA OE = Low Output Disable Leakage Current I_leak – 0.15 – µA OE = Low Current Consumption Output Characteristics Output High Voltage VOH 0.60 – 0.90 V See Figure 5 Output Low Voltage VOL -0.05 – 0.08 V See Figure 5 V_Swing 1.2 1.4 1.8 V See Figure 6 Rise/Fall Time Tr, Tf – 360 465 ps Measured with 2 pF capacitive loading to GND, 20% to 80%, see Figure 6 RMS Phase Jitter (random) – DCO mode only T_phj – 0.215 0.280 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz all Vdd levels – 0.09 0.12 ps f = 156.25 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, all Vdd levels – 0.220 0.320 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels – 0.1 0.12 ps f = 156.25 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, all Vdd levels – 1.0 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V Output Differential Voltage Swing Jitter RMS Phase Jitter (random) – Any-frequency mode only T_phj RMS Period Jitter[5] T_jitt Note: 5. Measured according to JESD65B. Table 5. I2C Electrical Characteristics – SCLK, SDA, 1 MHz SCLK, 255 Ohm, 550 pF (Max I2C Bus Load) Parameter Symbol Min. Typ. Max. Unit VIL – – 30% Vdd Input Voltage High VIH 70% – – Vdd Output Voltage Low VOL – – 0.4 V IL 0.5 – 24 µA CIN – – 5 pF Input Voltage Low Input Leakage current[6] Input Capacitance Condition 0.1 Vdd < VOUT < 0.9 Vdd Note: 6. Including leakage current from 160 kOhm pull resister at typical condition to Vdd. Table 6. SPI Electrical Characteristics – SCLK, MOSI, SS ¯¯ , MISO Parameter Symbol Min. Typ. Max. Unit Condition Input Pins – SCKL, MOSI, SS ¯¯ Input Voltage Low VIL – – 10% Vdd Input Voltage High VIH 90% – – Vdd Input Capacitance CIN – – 5 pF Output Pin – MISO Output Voltage High VOH 90% – – Vdd IOH = 2.2 mA (Vdd = 2.5 V) Output Voltage Low VOL – – 10% Vdd IOL = 2.7 mA (Vdd = 2.5 V) IL 0.5 – 24 µA 0.1 Vdd< VOUT < 0.9 Vdd Leakage in high impedance mode Rev 1.01 Page 6 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Table 7. Typical Phase Noise: Default start-up or reprogrammed frequency in DCO mode – LVDS output clock Frequency Offsets Output Frequency Phase Noise (dBc/Hz) 156.25 MHz 322.265625 MHz 100 Hz -97.8 -91.5 1 kHz -122.9 -116.5 10 kHz -131.1 -124.6 100 kHz -132.9 -126.3 1 MHz -148.2 -132.0 10 MHz -156.9 -153.0 20 MHz -157.7 -154.2 Table 8. Typical Phase Noise: Reprogrammed frequency in any-frequency Mode – LVDS output clock Output Frequency Phase Noise (dBc/Hz) Frequency Offsets Rev 1.01 156.25 MHz 322.265625 MHz 100 Hz -98.5 -92.7 1 kHz -123.0 -116.6 10 kHz -131.9 -125.3 100 kHz -134.8 -127.9 1 MHz -146.9 -131.2 10 MHz -156.7 -152.7 20 MHz -157.7 -154.1 Page 7 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Table 9. Absolute Maximum Attempted operation outside the absolute maximum ratings of the part may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Parameter Min. Max. Unit -0.5 4.0 V Input Voltage, Maximum (any input pin) – Vdd + 0.3 V V Input Voltage, Minimum (any input pin) -0.3 – V Storage Temperature -65 150 ºC Maximum Junction Temperature – 135 ºC Soldering Temperature[7] (follow standard Pb-free soldering guidelines) – 260 ºC Continuous Power Supply Voltage Range (Vdd) Note: 7. Exceeding this temperature for an extended period of time may damage the device. Table 10. Thermal Consideration[8] Package JA, 4 Layer Board (°C/W) JC, Bottom (°C/W) 5032, 10-pin 55[9] 20 Note: 8. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above Table 10. 9. Value for JA assumes the center pad is soldered down. Table 11. Maximum Operating Junction Temperature[10] Max Operating Temperature(ambient) Maximum Operating Junction Temperature 70°C 95°C 85°C 110°C 105°C 130°C Note: 10. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 12. Environmental Compliance Test Conditions Value Unit Mechanical Shock Resistance MIL-STD-883F, Method 2002 10,000 g Mechanical Vibration Resistance MIL-STD-883F, Method 2007 70 g Soldering Temperature (follow standard Pb free soldering guidelines) MIL-STD-883F, Method 2003 260 °C Moisture Sensitivity Level MSL1 @ 260°C Electrostatic Discharge (HBM) HBM, JESD22-A114 Charge-Device Model ESD Protection JESD220C101 Parameter Latch-up Tolerance Rev 1.01 – – 2,000 V 750 V JESD78 Compliant Page 8 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 2 Device Configurations and Pin-outs Table 13. Device Configurations Programming Interface Addressing Mode I2C SPI Pin 4 Pin 5 Pin 9 Pin 10 Pin controlled A1 A0 SDA SCLK Software NC NC SDA SCLK – SS ¯¯ MOSI MISO SCLK Pin-out Top Views (10-Lead QFN, 5.0 mm x 3.2 mm) VDD 8 VDD 7 OUT- OE / NC 2 7 OUT- 6 OUT+ GND 3 6 OUT+ OE / NC 2 GND 3 5 SS A0 / NC 4 MOSI A1 / NC Figure 3. I2C Mode Rev 1.01 9 1 OE / NC 5 10 OE / NC 8 4 MISO SDA 9 SCLK SCLK 10 1 Figure 4. SPI Mode Page 9 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Table 14. Pin Description Pin Symbol I/O Internal Pull-up/ Pull Down Resistor Function Pin 1 and Pin 2 functions are set by the ordering code in Ordering Information Table. If Software OE mode is selected in Ordering Table, both pin 1 and pin 2 are NC. 1 OE Input NC No Connect 100 kΩ Pull-Up H[11]: Specified frequency output L: Output Driver is disabled: OUT- = High-Z OUT+ = High-Z No Connect Pin 1 and Pin 2 functions are set by the ordering code in Ordering Information Table. If Software OE mode is selected in Ordering Table, both pin 1 and pin 2 are NC. OE Input NC No Connect GND Ground 100 kΩ Pull-Up 2 3 A1 Input NC No Connect ̅̅̅ SS Input No Connect Connect to ground 100 kΩ Pull-Up 4 A0 Input NC No Connect H[11]: Specified frequency output L: Output Driver is disabled: OUT- = High-Z OUT+ = High-Z I2C Address Select, Most Significant Bit (MSB) A1 A0 I2C Address 0 0 1100000 0 1 1100010 1 0 1101000 1 1 1101010 (Default) No Connect. I2C Address is factory set to one of the 16 available addresses shown in Table 27 and also on the Ordering Information Table. 100 kΩ Pull-Up 100 kΩ Pull-Up 5 SPI Chip select, active low I2C Address Select, Least Significant Bit (LSB) A1 A0 I2C Address 0 0 1100000 0 1 1100010 1 0 1101000 1 1 1101010 (Default) No Connect. I2C Address is factory set to one of the 16 available addresses shown in Table 27 and also on the Ordering Information Table. 100 kΩ Pull-Up MOSI Input 6 OUT+ Output Oscillator output 7 OUT- Output Complementary oscillator output 8 VDD Power Connect to Vdd[12] SDA Input 200 kΩ Pull-Up I2C serial data input MISO Output 200 kΩ Pull-Up SPI serial data output SCLK Input 200 kΩ Pull-Up I2C/SPI serial clock input 9 10 SPI serial data input Notes: 11. In OE mode for noisy environments, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If OE pin needs to be left floating, use the NC option. 12. 0.1 μF capacitor in parallel with a 10 μF capacitor are required between VDD and GND. Rev 1.01 Page 10 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 3 Waveform Diagrams OUT- VOH OUT+ VOL GND Figure 5. LVPECL, HCSL Voltage Levels per Differential Pin (i.e. OUT+, or OUT-) V 80% 80% V_ Swing 0V t 20% 20% Tr Tf Figure 6. LVPECL, HCSL Voltage Levels Across Differential Pair (i.e. OUT+ minus OUT-) Rev 1.01 Page 11 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Waveform Diagrams (continued) OUT- VOD OUT+ VOS GND Figure 7. LVDS Voltage Levels per Differential Pin (i.e. OUT+, or OUT-) V 80% 80% 0V t 20% 20% Tr Tf Figure 8. LVDS Differential Waveform (i.e. OUT+ minus OUT-) Vdd OE Voltage Vdd VIH VIL T_oe_hw OE Voltage T_oe_hw OUT- OUT- 90% HZ HZ OUT+ OUT+ GND GND Figure 9. Hardware OE Enable Timing Rev 1.01 Figure 10. Hardware OE Disable Timing Page 12 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 4 Termination Diagrams LVPECL OUT+ Shunt Bias Termination network 0.1μF Zo = 50Ω D+ OUT- Zo = 50Ω D- LVPECL 0.1μF RB RB VDD 50 Ω 50 Ω RB 3.3 V 100 Ω VT 2.5 V 48.7 Ω Figure 11. LVPECL with AC-coupled Termination VDD Thevenin-equivalent Termination network R1 LVPECL R1 OUT+ Zo = 50Ω D+ OUT- Zo = 50Ω D- VDD R1 R2 R2 3.3 V 127 Ω 82.5 Ω 2.5 V 250 Ω 62.5 Ω R2 Figure 12. LVPECL DC-coupled Load Termination with Thevenin Equivalent Network Y-Bias Termination network LVPECL OUT+ Zo = 50Ω D+ OUT- Zo = 50Ω D- R1 VDD R1 R2 R3 3.3 V 50 Ω 50 Ω 50 Ω 2.5 V 50 Ω 50 Ω 18 Ω R2 C1 0.1μF R3 Figure 13. LVPECL with Y-Bias Termination OUT+ Shunt Bias Termination network Zo = 50Ω D+ OUT- Zo = 50Ω D- LVPECL 50 Ω 50 Ω VT=VDD-2V Figure 14. LVPECL with DC-coupled Parallel Shunt Load Termination Rev 1.01 Page 13 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Termination Diagrams (continued) LVDS LVDS Zo = 50Ω OUT+ OUT+ 100 Ω Zo = 50Ω OUT- OUT- Figure 15. LVDS single DC Termination at the Load LVDS 0.1μF Zo = 50Ω OUT+ 100 Ω OUT+ 100 Ω 0.1μF Zo = 50Ω OUT- OUT- Figure 16. LVDS Double AC Termination with Capacitor Close to the Load LVDS Zo = 50Ω OUT+ 100 Ω OUT- OUT+ 100 Ω Zo = 50Ω OUT- Figure 17. LVDS Double DC Termination Rev 1.01 Page 14 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Termination Diagrams (continued) HCSL R1 OUT+ OUT- Zo = 50Ω D+ Zo = 50Ω D- R2 50Ω 50Ω R1 = R2 = 33 Ω Figure 18. HCSL Interface Termination Rev 1.01 Page 15 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 5 Test Circuit Diagrams SDA Power Supply 10 uF 0.1 uF SCL 8 9 Termination Vout VDD 7 6 5 10 1 2 Test Point 4 3 A0/NC A1/NC VDD OE NC 1 kΩ Figure 19. Test Circuit (I2C mode and OE Function for Pin 1) SDA Power Supply 10 uF 0.1 uF SCL 8 9 OE 7 5 2 Test Point 6 10 1 VDD Termination Vout VDD 4 3 A0/NC A1/NC NC 1 kΩ Figure 20. Test Circuit (I2C mode and OE Function for Pin 2) SDA Power Supply 10 uF 0.1 uF SCL 8 9 Termination Vout VDD 7 6 5 10 1 2 NC NC 3 Test Point 4 A1/NC A0/NC Figure 21. Test Circuit (I2C mode and NC Function for both Pin1 and Pin2) Rev 1.01 Page 16 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Test Circuit Diagrams (continued) MISO Power Supply 10 uF SCL 0.1 uF 8 9 Termination Vout VDD 7 6 MOSI 5 10 1 2 Test Point SS 4 3 VDD OE NC 1 kΩ Figure 22. Test Circuit (SPI mode and OE Function for Pin 1) MISO Power Supply 10 uF SCL 0.1 uF 8 9 2 Test Point 6 MOSI 5 2 OE 7 10 VDD Termination Vout VDD SS 4 3 NC 1 kΩ Figure 23. Test Circuit (SPI mode and OE Function for Pin 2) MISO Power Supply 10 uF 0.1 uF SCL 9 8 Termination Vout VDD 7 6 5 10 1 2 NC NC 3 Test Point 4 SS MOSI Figure 24. Test Circuit (SPI mode and NC Function for both Pin1 and Pin2) Rev 1.01 Page 17 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 6 Architecture Overview 7 Based on SiTime’s innovative Elite Platform ®, the SiT3521 delivers exceptional dynamic performance, i.e. resilience to environmental stressors such as shock, vibration and fast temperature transients. Underpinning the Elite platform are SiTime’s unique DualMEMS temperature sensing architecture and TurboCompensation technology, illustrated in Figure 1. DualMEMS is a noiseless temperature sensing scheme. It consists of two MEMS resonators fabricated on the same die substrate. The TempFlat resonator is designed with a flat frequency characteristic over temperature whereas the temperature sensing resonator is by design sensitive to temperature changes. The ratio of frequencies between these two resonators provides an accurate reading of the resonator temperature with 30 µK resolution. The SiT3521 is designed for maximum frequency flexibility with an array of factory programmable options, enabling system designers to configure this precision device for optimal performance in a given application. User Programming Interface The SiT3521 supports either I2C or SPI interface (slave only) as a factory programmable option via the ordering codes. For I2C, the user has the option of using one of the four default addresses selectable with two address pins (A0, A1) or specifying one of the sixteen factory programmed addresses. Refer to I2C/SPI Device Address Modes section for details. Table 15. Programming Interface Ordering Codes By placing the two MEMS resonators on the same die, this temperature sensing scheme eliminates the thermal lag and gradients between the resonator and the temperature sensor, an inherent weakness of the legacy quartz TCXOs. The DualMEMS temperature sensor is then combined with a state-of-the-art temperature compensation circuit in the CMOS IC. The TurboCompensation design, with >100 Hz compensation bandwidth, achieves dynamic frequency stability that is far superior to any quartz devices. The 7th order compensation algorithm enables additional optimization of frequency stability and frequency slope over temperature within any specific temperature range of choice for a given system design. ◼ TechPaper: DualMEMS Temperature Sensing Technology ◼ TechPaper: DualMEMS Resonator TDC Programming Interface Addressing Mode I2C 2 address pins – A0, A1 “G” Factory programmed “0-F” Chip select pin “S” SPI Ordering Code Start-up output frequency and signaling types The SiT3521 is shipped with a default start-up frequency between 1 MHz to 340 MHz in steps of 1 Hz that a user specifies in the ordering code. A user can also specify one of the three differential signaling types in the ordering code. Table 16. Output Format Ordering Codes The Elite platform also incorporates a high resolution, low noise frequency synthesizer along with the industry standard I2C and/or SPI bus. This unique combination enables system designers to digitally control the output frequency in steps as low as 5 ppt (parts per trillion) and over a wide frequency range from 1 MHz to 340 MHz. For more information regarding the Elite platform and its benefits please visit: ◼ SiTime's breakthroughs section Functional Overview Output Format Ordering Code LVPECL “1“ LVDS “2” HCSL “4” In-system programmable options The SiT3521 enables software control of the following features via I2C/SPI: ◼ Any-frequency feature: Output frequency that can be re-programmed to any value between 1 MHz and 340 MHz in 1 Hz steps ◼ DCO feature: Output frequency that can be steered (pulled) by up to ±3200 ppm with 5 to 94 ppt resolution ◼ Software OE feature: Enabling or disabling of the output driver Refer to Chapter 9 for programming details. Rev 1.01 Page 18 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 8 In-system Programmable Functional Description Figure 25 shows hi-level block diagram of In-system programmable oscillator showing user accessible and non-useraccessible circuit blocks. Software OE MEMS 94 MHz Frac-N PLL (feedback divider N) OUTDriver Control DCO User Accessible Block OUT+ Forward Divider (M) Non User Accessible Block Figure 25. In-system Programmable Oscillator Block Diagram Any-frequency function Table 18. Any-frequency user-accessible blocks The any-frequency feature allows users to re-program the device output to a new frequency between 1 MHz to 340 MHz and optimize output driver according to the given new frequency after power-up through the I2C or SPI interface. Device output frequency is defined by a combination of Frac-N PLL feedback divider (N) and forward divider (M). Block Name Available values Register Name Register Address N 13.08511 to 15.96875 N_reg [31:0] 0x03[15:0] = N_reg[31:16] M 2 to 8191 M_reg [12:0] Equation 1: Output frequency, Driver Control 0 to 63 Driver Control Reg [5:0] 0x04[15:0] = N_reg[15:0] 0x05[15:3] = M_reg[12:0] 94 MHz*N Fout = M Table 17 is showing unsupported Frequencies. any-frequency Unsupported Frequency Range (MHz) Max. 300.2125 307.5001 Step 1: N and M dividers values calculation Equation 2: N= To re-program device to the desired output frequency, user should calculate the most appropriate Frac-N PLL feedback and forward divider combination. For a given output frequency, the choice of dividers combination must fall within the allowable ranges (See the Table 18). Calculation of the appropriate N and M values and selection of proper Driver Control values consist of the following steps. Throughout these steps, and example using LVPECL 75 MHz output frequency will be used. Rev 1.01 0x06[2:0] = Driver Control Reg [2:0] Find the lowest allowed M divider value which gives N value (see Equation 2) within allowed Frac-N PLL feedback divider range (see Table 18): Table 17. List of Unsupported Frequencies Min. 0x05[2:0] = Driver Control Reg [5:3] Fout*M 94 MHz Table 19 below shows implementation of this step for the 75 MHz output frequency example. The combination satisfying above conditions is highlighted in blue. Table 19. Frac-N PLL Feedback Divider and Forward Divider Combination Calculation for Output Frequency = 75 MHz Page 19 of 45 M Within 2 to 8191 N Within 13.08511 to 15.96875 16 12.76596 17 13.56383 18 14.36170 19 15.15957 20 15.95745 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Step 2: Calculate N and M Dividers Binary Values Step 3: Select appropriate Drive Control values The selected combination of Frac-N PLL feedback divider and forward divider values should be converted to binary words and then written to the device’s control registers. Number conversion, conditioning and write procedure are as follows. The values calculated in the previous steps for 75 MHz output frequency will be used for example purposes. Select appropriate Drive Control values based on Table 20. Table 20. Driver Control settings Output Driver 2) N_reg[26:0] = 100100000101011100101001110b (final value) Step 2.2: Convert M divider value to binary word 1) M divider value should be converted to 13-bit binary word. As forward divider is always positive no sign bit should be used. In this example, the M value is dec: 17, bin: 0000000010001b 2) Execute bitwise XOR operation on the M value and 0000000011011b mask. 101110b 1 to 250 001000b 250.000001 to 340 000000b Step 4: Write N and M binary values to the device Step 4.1: Read back the contents of 0x06[15:0] Reg6 read back is needed to capture the value of this register so the same values can be written along with the Driver Control Reg[2:0] value Execute bitwise XOR operation on the integer part (01101b) and 01110b mask. The reason for the 01110b mask is to set the default value when the device is in an unprogrammed state and all bit values are 0. Fractional part of the N divider value should be multiplied by 2 27 and then rounded towards nearest integer. Then it should be converted to binary value resulting in a 27-bit binary word. Because the fractional part of N is always positive, no sign bit should be used. In our example, 227 * 0.56383 = 75,675,981.57824. Rounding to the nearest integer gives 75,675,982 and converting to binary: 110110b In the example, Driver Control Reg[5:0]: = 110110b Step 4.2: Write registers to the device in the following sequence 1) Address 0x03 0x03[15:11] = N_reg[31:27] (integer part) 0x03[10:0] = M_reg[26:16] (fractional part, MSW) N_reg[31:27] = 01101b (given integer part) XOR 01110b (mask) = 00011b (final value) 3) 1 to 250 250.000001 to 340 LVDS or HCSL 32 bits are intended for N divider value: MSB 5 bits for integer and LSB 27 for fractional parts Take the integer part of the N divider value and convert to binary. In our example, integer part is dec: 13 and bin: 01101 Drive Control Reg [5:0] LVPECL Step 2.1: Convert N value to binary word (N_reg) 1) Output Frequency (MHz) 2) Address 0x04 0x04[15:0] = N_reg[15:0] (fractional part, LSW) 3) Address 0x06 0x06[15:3] = Values red out at step 3.1 0x06[2:0] = Driver Control Reg[2:0] 4) Address 0x05 0x05[15:3] = N_reg[12:0] 0x05[2:0] = Driver Control Reg[5:3] After the forward divider value 0x05 is written, the outputs will be disabled until the PLL locks to the new frequency and is stable. When the PLL is stable, the clock output will be re-enabled. Figure 26 and Figure 27 show the write sequence, output disable and programming time for I2C and SPI interfaces. M_reg[12:0] = 0000000010001b (given M) XOR 0000000011011b = 0000000001010b (final value) Rev 1.01 Page 20 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Frac-N PLL[31:27] St D_Address[6:0] W A R_Address[7:0]=03 A [15:11] Frac-N PLL[26:16] [10:8] A 0x03[15:8] [7:0] A 0x03[7:0] Frac-N PLL[15:0] [15:8] A A ReSt [7:0] 0x04[15:8] D_Address[6:0] W A R_Address[7:0]=06 A D_Address[6:0] W A R_Address[7:0]=05 A 0x04[7:0] Driver Cotrol[2:0] [15:8] A [7:3] A ReSt 0x06[7:0] 0x06[15:8] PostDiv[12:0] [15:8] [2:0] A 0x05[15:8] Driver Control[5:3] [7:3] [2:0] A Sp 0x05[7:0] Rest of write transaction Slave Drives Bit(s) on Bus Tprogramming Output Frequency f1 Output Frequency f0 Master Drives Bit(s) on Bus OUT+ OUT- St Start Sp Stop W Write Output Disabled R Read OUT+ = High-Z A Acknowledge OUT- = High-Z ReSt Tdisable Repeated Start Figure 26. Changing the Default Start-up Output Frequency Using Auto Address Incrementing (I2C) Rev 1.01 Page 21 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Frac-N PLL[31-27] 0x57 [15:11] R_Address[7:0]=03 Frac-N PLL[26:16] [10:8] [7:0] 0x03[15:8] 0x03[7:0] Frac-N PLL[15:0] Tdelay [15:8] [7:0] 0x04[15:8] 0x04[7:0] 0x57 R_Address[7:0]=06 0x57 R_Address[7:0]=05 Driver Control[2:0] [15:8] [7:3] PostDiv[12:0] 0x05[15:8] Tdelay 0x06[7:0] 0x06[15:8] [15:8] [2:0] Driver Control[5:3] [7:3] [2:0] 0x05[7:0] Rest of write transaction Tprogramming Output Frequency f0 Output Frequency f1 OUT+ OUT- Tdisable Output Disabled OUT+ = High-Z OUT- = High-Z Figure 27. Changing the Default Start-up Output Frequency Using Auto Address Incrementing (SPI) Table 21. Output Disable and Enable Times when Changing the Output Frequency Parameter Delay between transactions Output Disable Time Settling Time for Frequency Change Rev 1.01 Symbol Min. Typ. Max. Unit Condition Tdelay 125 – – µs SPI only Tdisable – – 2.3 µs At 85°C ambient Tre-programming – – 421 µs At 85°C ambient Page 22 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator DCO Functional Description The DCO feature allows users to steer (pull) output frequency by up to ±3200 ppm with 5 to 94 ppt resolution through the I2C or SPI digital interface. The pull range is specified by the value loaded in the digital pull range control register. The 16 pull range choices are specified in the control register and range from ±6.25 ppm to ±3200 ppm. There are several advantages of DCO relative to analog voltage control (VCXO) Table 22 below shows the frequency resolution vs. pull range programmed value. a. b. c. d. e. Frequency Control Resolution as low as 5 ppt. This high resolution minimizes accumulated time error in synchronization applications. Lower system cost – A VCXO may need a Digital to Analog Converter (DAC) to drive the control voltage input. In a DCO, the frequency control is achieved digitally by register writes to the control registers via I2C, thereby eliminating the need for a DAC. Better Noise Immunity – The analog signal used to drive the voltage control pin of a VCXO can be sensitive to noise and the trace over which the signal is routed can be susceptible to noise coupling from the system. The DCO does not suffer from analog noise coupling since the frequency control is performed digitally through I2C. No Frequency Pull non-linearity. The frequency pulling is achieved via fractional feedback divider of the PLL, eliminating any pull non-linearity concern which is typical of quartz based VCXOs. This improves dynamic performance in closed loop operations. Programmable Wide Pull Range – The DCO pulling mechanism is via the fractional feedback divider and is therefore not constrained by resonator pullability as in quartz based solutions. The SiT3521 offers 16 frequency pull range options from ±6.25 ppm to ±3200 ppm, thereby giving system designers great flexibility. Table 22. Frequency Resolution vs. Pull Range Programmed Pull Range Frequency Precision ±25 ppm 5x10-12 ±50 ppm 5x10-12 ±80 ppm 5x10-12 ±100 ppm 5x10-12 ±125 ppm 5x10-12 ±150 ppm 5x10-12 ±200 ppm 5x10-12 ±400 ppm 1x10-11 ±600 ppm 1.4x10-11 ±800 ppm 2.1x10-11 ±1200 ppm 3.2x10-11 ±1600 ppm 4.7x10-11 ±3200 ppm 9.4x10-11 The ppm frequency offset is specified by the 26-bit DCO Frequency control register in two’s complement format as described in the I2C/SPI Register Descriptions. The power up default value is 00000000000000000000000000b which sets the output frequency at its nominal value (0 ppm). To change the output frequency, a frequency control word is written to 0x00[15:0] (Least Significant Word) and 0x01[9:0] (Most Significant Word). The LSW value should be written first followed by the MSW value; the frequency change is initiated after the MSW value is written. In the DCO mode, the device powers up at the nominal operating frequency and pull range specified by the ordering code. After power-up both the pull range and output frequency can be controlled via I2C/SPI writes to the respective control registers. The maximum output frequency change is constrained by the pull range limits. Rev 1.01 Page 23 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Figure 28. Pull range and Frequency Control Word Figure 28 shows how the two’s complement signed value of the frequency control word sets the output frequency within the ppm pull range set by 0x02[3:0]. This example shows use of ±200 ppm pull range. Therefore, to set the desired output frequency, one just needs to calculate the fraction of full scale value ppm, covert to two’s complement binary and then write the values to the frequency control registers. The following formula generates the control word value: Control word Value = = RND((225-1) * ppm shift from nominal/pull range) where RND is the rounding function which rounds the number to the nearest whole number. Two examples follow, assuming the ±200 ppm pull range. Example 1: Default start-up output frequency = 156.25 MHz Desired output frequency = 156.2640625 MHz (+90 ppm) 225-1 corresponds to +200 ppm, and the fractional value required for +90 ppm can be calculated as follows. 90 ppm/200 ppm * (225-1) = 15,099,493.95 Rounding to the nearest whole number yields 15,099,494 and converting to two complement gives a binary value of 111001100110011001100110 and E66666 in hex. Example 2: Default start-up output frequency = 122.88 MHz Desired output frequency = 122.873856 MHz (-50 ppm) Following formula shown above, (-50 ppm/200 ppm) * (225-1) = -8,388,607.75 Rounding to the nearest whole number results in -8,388,608. Converting to two’s complement binary results in 11100000000000000000000000 and 3800000 in hex. Rev 1.01 Page 24 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator To Summarize, the procedure for calculating the frequency control word associated with a given ppm offset is as follows: 1) 2) 3) It is important to note that the maximum DCO Frequency Control update rate is 38 kHz regardless of I2C/SPI bus speed. Pull Range, Absolute Pull Range Calculate the fraction of the half pull range needed. For example, if the total pull range is set for ±100 ppm and a +20 ppm shift from the nominal frequency is needed, this fraction is 20 ppm/100 ppm = 0.2 Pull range (PR) is the amount of frequency deviation that will result from changing the control voltage over its maximum range under nominal conditions. Absolute pull range (APR) is the guaranteed controllable frequency range over all environmental and aging conditions. Effectively, it is the amount of pull range remaining after taking into account frequency stability tolerances over variables such as temperature, power supply voltage, and aging, i.e.: Multiply this fraction by the full half scale word value, 225-1 = 33,554,431, round to the nearest whole number and convert the result to two’s complement binary. Following the +20 ppm example, this value is 0.2 * 33,554,431 = 6,710,886.2 and rounded to 6,710,886. APR = PR − Fstability − Faging Write the two’s complement binary value starting with the Least Significant Word (LSW) 0x00[16:0], followed by the Most Significant Word (MSW), 0x01[9:0]. If the user desires that the output remains enabled while changing the frequency, a 1 must also be written to the OE control bit 0x01[10] if the device has software OE Control Enabled. where Fstability is the device frequency stability due to initial tolerance and variations on temperature, power supply, and load. Table 23 below shows the pull range and corresponding APR values for each of the frequency vs. temperature ordering options. Table 23. DCO Pull Range, APR Options Pull Range Ordering Code Rev 1.01 Programmed Pull Range ppm APR ppm ±10 ppm option APR ppm ±20 ppm option APR ppm ±25 ppm option APR ppm ±50 ppm option M ±25 ±10 – – – B ±50 ±35 ±25 ±20 – C ±80 ±65 ±55 ±50 ±25 E ±100 ±85 ±75 ±70 ±45 G ±125 ±110 ±100 ±95 ±70 H ±200 ±185 ±175 ±170 ±145 X ±400 ±385 ±385 ±380 ±345 Y ±800 ±785 ±785 ±780 ±745 Z ±1600 ±1585 ±1585 ±1580 ±1545 U ±3200 ±3185 ±3185 ±3180 ±3145 Page 25 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Figure 29 below shows the I2C sequence for writing the 4-byte control word using auto address incrementing. It is important to note that if the I2C function is under software control, the software OE control bit 0x01[10] should be “1” during the write sequence to avoid disabling the output. Digital Frequency Control – Least Significant Word (LSW) [15:0] St D_Address[6:0] W A R_Address[7:0]=00 A LSW[15:8] 0x00[15:8] A LSW[7:0] A 0x00[7:0] Digital Frequency Control – Most Significant Word (MSW) [9:0] X X X X X OE 9 8 A 0x01[15:8] A Sp MSW[7:0] 0x01[7:0] STOP condition f0 Output Frequency f0 + f1 ±0.5% Tsettle Tfdelay Slave Drives Bit(s) on Bus Master Drives Bit(s) on Bus St Start Sp Stop W Write R Read A Acknowledge OE Output Enable X “Don’t Care” Register Bit not used. Figure 29. Writing the Frequency Control Word Table 24. DCO Delay and Settling Time Parameter Symbol Min. Typ. Max. Unit Condition Frequency Change Delay Tfdelay – 103 140 µs Time from end of 0x01 reg MSW to start of frequency pull, as shown in Figure 29 Frequency Settling Time Tsettle – 16.5 20 µs Time to settle to ±0.5% of frequency offset, as shown in Figure 29 Rev 1.01 Page 26 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Software OE Functional Description Important note: By default (at startup) output is disabled in this mode and should be enabled by corresponding write operation after start-up. Output driver can be enabled or disabled through control registers 0x01[10] (corresponding part number option should be selected to enable this function, please refer to the OE Pin Control option in Ordering Information section). To enable the output driver, this register should be set to 1, to disable – to 0. NOT USED[15:11] St D_Address[6:0] W A R_Address[7:0]=01 A OE Control[10] DCO Frequency Control[9:0] [15:11] [10] [9:8] A 0x01[15:8] [7:0] A Sp 0x01[7:0] T_oe_sw OUT+ OUTOUT+ OUT- Output Disabled Output Disabled Figure 30. Enable/Disable software OE (I2C) NOT USED[15:11] 0x57 R_Address[7:0]=01 [15:11] OE Control[10] DCO Frequency Control[9:0] [10] [9:8] 0x01[15:8] [7:0] 0x01[7:0] T_oe_sw OUT+ OUTOUT+ OUT- Output Disabled Output Disabled Figure 31. Enable/Disable software OE (I2C) Rev 1.01 Page 27 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 9 I2C/SPI Control Registers The any-frequency, DCO software OE and drive strength control features enable control of frequency pull range, frequency pull value, Output Enable and Drive strength setting via I2C/SPI writes to the control registers. Table 25 below shows the register map summary and the detailed register descriptions follow. Table 25. Register Map Summary Address Bits 0x00 [15:0] RW 0x01 [15:11] R 0x02 0x03 Access Description DCO FREQUENCY CONTROL LEAST SIGNIFICANT WORD (LSW) NOT USED [10] RW [9:0] RW OE CONTROL. This bit is only active if the output enable function is under software control. If the device is configured for hardware control using an OE pin, writing to this bit has no effect. Selection of Pin or Software OE Control is an ordering option shown in Ordering Information Table. DCO FREQUENCY CONTROL MOST SIGNIFICANT WORD (MSW) [15:4] R [3:0] RW NOT USED DCO PULL RANGE CONTROL [15:11] RW FRAC-N PLL FEEBDACK DIVIDER INTEGER VALUE [10:0] RW FRAC-N PLL FEEBDACK DIVIDER FRACTIONAL VALUE, MOST SIGNIFICANT WORD (MSW) 0x04 [15:0] RW FRAC-N PLL FEEBDACK DIVIDER FRACTIONAL VALUE, LEAST SIGNIFICANT WORD (LSW) 0x05 [15:3] RW FORWARD DIVIDER [2:0] RW DRIVER CONTROL [15:2] R 0x06 NOT USED 3 RW DRIVER DIVIDER VALUE [2:0] RW DRIVER CONTROL Register Descriptions Register Address: 0x00. DCO Frequency Control Least Significant Word (LSW) Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Access RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW Default 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Name DCO FREQUENCY CONTROL LEAST SIGNIFICANT WORD (LSW)[15:0] Bits Name 15:0 DCO FREQUENCY CONTROL LEAST SIGNIFICANT WORD Access RW Description Bits [15:0] are the lower 16 bits of the 26 bit FrequencyControlWord and are the Least Significant Word (LSW). The upper 10 bits are in regsiter 0x01[9:0] and are the most significant Frequency Control Word (MSW). The lower 16 bits together with upper 10 bits specify a 26-bit frequency control word. This power up default values of all 26 bits are 0 which sets the output frequency at its nominal value. After powerup, the system can write to these two registers to pull the frequency across the pull range. The register values are 2’s complement to support positive and negative control values. The LSW value should be written before the MSW value because the frequency change is initiated when the new values are loaded into the MSW. More details and examples are discussed in the next section. Rev 1.01 Page 28 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Register Address: 0x01. OE Control, DCO Frequency Control Most Significant Word (MSW) Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Access R R R R R RW RW RW RW RW RW RW RW RW RW RW Default 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Name NOT USED OE Bits Name 15:11 NOT USED Access R 10 OE Control RW DCO FREQUENCY CONTROL[9:0] MSW Description Bits [15:10] are read only and return all 0’s when read. Writing to these bits have no effect. Output Enable Software Control. Allows the user to enable and disable the output driver via I2C. 0 = Output Disabled (Default) 1 = Output Enabled This bit is only active if the output enable function is under software control. If the device is configured for hardware control using an OE pin, writing to this bit has no effect. 9:0 DCO FREQUENCY CONTROL MOST SIGNIFICANT WORD (MSW) RW Bits [9:0] are the upper 10 bits of the 26 bit Frequency Control Word and are the Most Significant Word (MSW). The lower 16 bits are in register 0x00[15:0] and are the least significant Frequency Control Word (MSW). Theses lower 16 bits together with upper 10 bits specify a 26-bit frequency control word. This power up default values of all 26 bits are 0 which sets the output frequency at its nominal value. After powerup, the system can write to these two registers to pull the frequency across the pull range. The register values are 2’s complement to support positive and negative control values. The LSW value should be written before the MSW value because the frequency change is initiated when the new values are loaded into the MSW. More details and examples are discussed in the next section. Register Address: 0x02. DCO PULL RANGE CONTROL Bit 15 14 13 12 11 10 9 6 5 6 5 4 3 2 1 0 Access R R R R R R R R R R R R RW RW RW RW Default 0 0 0 0 0 0 0 0 0 0 0 0 X[13] X[13] X[13] X[13] Name NONE DCO PULL RANGE CONTROL Note: 13. Default values are factory set but can be over-written after power-up. Bits Name Access 15:4 NONE R 3:0 DCOs PULL RANGE CONTROL RW Description Bits [15:4] are read only and return all 0’s when read. Writing to these bits have no effect. Sets the digital pull range of the DCO. The table below shows the available pull range values and associated bit settings. The default value is factory programmed. Bit 3210 0000: Not used 0001: Not used 0010: Not Used 0011: ±25 ppm 0100: ±50 ppm 0101: ±80 ppm 0110: ±100 ppm 0111: ±125 ppm 1100: ±150 ppm 1001: ±200 ppm 1010: ±400 ppm 1011: ±600 ppm 1100: ±800 ppm 1101: ±1200 ppm 1110: ±1600 ppm 1111: ±3200 ppm Rev 1.01 Page 29 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Register Address: 0x03. Frac-N PLL Feedback Divider Integer Value and Frac-N PLL Feedback Divider Fraction Value MSW Bit 15 14 13 12 11 10 9 6 5 6 5 4 3 2 1 0 Access RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW Default x x x x x x x x x x x x x x x x Name Frac-N PLL Feedback Divider Integer Value Frac-N PLL Feedback Divider Fraction Value, MSW Bits Name Access Description 15:11 Frac-N PLL Feedback Divider Integer Value RW Sets the integer value of the Frac-N PLL feedback divider. The default value is factory programmed to correspond to the desired output frequency (hence the x notation in the default value field) and can be changed by the user after powerup. 10:0 Frac-N PLL Feedback Divider Fraction Value, MSW RW Most Significant Word (MSW) of Frac-N PLL feedback divider fraction value. The MSW comprises the upper 11 bits of the 27-bit control word. The default value is factory programmed to correspond to the desired output frequency (hence the x notation in the default value field) and can be changed by the user after powerup. Register Address: 0x04. Frac-N PLL Feedback Divider Fraction Value LSW Bit 15 14 13 12 11 10 9 6 5 6 5 4 3 2 1 0 Access RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW Default x x x x x x x x x x x x x x x x Name Frac-N PLL Feedback Divider Fraction Value, LSW Bits Name Access 15:0 Frac-N PLL Feedback Divider Fraction Value, LSW Description Sets the Least Significant Word of the Frac-N PLL feedback divider fraction. The default value is factory programmed to correspond to the desired output frequency (hence the x notation in the default value field) and can be changed by the user after powerup. RW Register Address: 0x05. Forward Divider, Driver Control Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Access RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW RW Default x x x x x x x x x x x x x 0 0 0 Name Forward Divider Access Driver Control Bits Name 15:3 Forward Divider RW Description Forward Divider Value. The default value is factory programmed to correspond to the desired output frequency (hence the x notation in the default value field) and can be changed by the user after powerup. The Forward Divider Value Range is [2:8191]. 2:0 Driver Control RW LVDS or HCSL driver Bit Value Frequnecy range 001 1 to 250 MHz 000 250.000001 to 340 MHz LVPECL driver Bit Value Rev 1.01 Frequnecy range 110 1 to 250 MHz 101 250.000001 to 340 MHz Page 30 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Register Address: 0x06. Driver Divider, Driver Control Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Access R R R R R R R R R R R R RW RW RW RW Default 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Name Driver Divider NOT USED Bits Name 15:4 NOT USED 3 Driver Divider Access R RW Description Bits [15:4] are read only and return all 0’s when read. Writing to these bits have no effect. Driver divider value. DO NOT change this bit. Default value is 2 for SiT3521. Bit Value 2:0 Driver Control RW Driver Control Driver Divider 0 2 (default, DO NOT change) 1 1 (bypass) LVDS or HCSL driver Bit Value 000 Frequency range 1 to 340 MHz LVPECL driver 110 Rev 1.01 Page 31 of 45 1 to 340 MHz www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 10 I2C Operation I2C protocol Data valid START and STOP conditions The SDA line must be stable during the high period of the SCLK. SDA transitions are allowed only during SCLK low level for data communication. Only one transition is allowed during low SCLK pulse to communicate one bit of data. Figure 32 shows the detailed timing diagram. The idle I2C bus state occurs when both SCLK and SDA are not being driven by any master and are therefore in a logic HI state due to the pull up resistors. Every transaction begins with a START (S) signal and ends with a STOP (P) signal. A START condition is defined by a high to low transition on the SDA while SCLK is high. A STOP condition is defined by a low to high transition on the SDA while SCLK is high. START and STOP conditions are always generated by master. This slave module also supports repeated START (Sr) condition which is same as START condition instead of STOP condition (Blue color line shows repeated START in Figure 33). SDA SCLK data line stable: data valid change of data allowed setup time Figure 32. Data and clock timing relation in I2C bus SDA hold time hold time setup time SCLK S P START Condition STOP Condition Figure 33. START and STOP (or repeated START) condition Rev 1.01 Page 32 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Data Transfer Format Write/Read sequence Every data byte is eight bits long. The number of bytes that can be transmitted per transfer is unrestricted. Data is transferred with the MSB (Most Significant Bit) first. The detailed data transfer format is shown in Figure 34 below. This I2C slave module supports 7-bit device addressing format. The 8th bit is a read/write bit and “1” indicates a read transaction and a “0” indicates a write transaction. The register addresses are 8-bits long with an address range of 0 to 255 (00h to FFh). Auto address incrementing is supported which allows data to be transferred to contiguous addresses without the need to write each address beyond the first address. Since the maximum register address value is 255, the address will roll from 255 to back to 0 when auto address incrementing is used. Obviously, auto address incrementing should only be used for writing to contiguous addresses. The data format is 16bit (two bytes) with the most significant byte being transferred first. For a read operation, the starting register address must be written first. If that is omitted, reading will start from the last address in the auto-increment counter of the device, which has a startup default of 0x00. The acknowledge bit must occur after every byte transfer and it allows the receiver to signal the transmitter that the byte was successfully received and another byte may be sent. The acknowledge signal is defined as follows: the transmitter releases the SDA line during the acknowledge clock pulse so the receiver can pull the SDA line low and it remains stable low during the high period of this clock pulse. Setup and hold times must also be taken into account. When SDA remains high during this ninth clock pulse, this is defined as the Not-Acknowledge signal (NACK). The master can then generate either a STOP condition to abort the transfer, or a repeated START condition to start a new transfer. The only condition that leads to the generation of NACK from the SiT3521 is when the transmitted address does not match the slave address. When the master is reading data from SiT3521, the SiT3521 expects the ACK from the master at the end of received data, so that the slave releases the SDA line and the master can generate the STOP or repeated START. If there is NACK signal at the end of data, then the SiT3521 tries to send the next data. If the first bit of next data is “0”, then the SiT3521 holds the SDA line to “0”, thereby blocking the master from generating a STOP/(re)START signal. Rev 1.01 Page 33 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator SDA acknowledge from slave MSB SCLK 1 S or Sr 2 7 acknowledge from slave 9 ACK 8 1 2 3 to 8 START Condition 9 ACK P or Sr STOP Condition Figure 34. Data Transfer Format SDA 1 to 7 SCL 8 9 1 to 8 9 1 to 8 9 1 to 8 9 S P START condition slave address W register address ACK ACK data-MSB ACK data-LSB ACK STOP condition Figure 35. Write Sequence SDA 1 to 7 SCL 8 9 1 to 8 9 1 to 8 9 S START condition P slave address R ACK data-MSB ACK data-LSB ACK STOP condition Figure 36. Read Sequence Rev 1.01 Page 34 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator I2C Timing Specification The below timing diagram and table illustrate the timing relationships for both master and slave. tSU;DAT tr tf VIH SDA VIL tr tf VIH tHD;STA VIL 9 8 2 1 SCLK tHIGH tVD;DAT tHD;DAT tLOW 1/fSCLK S START Condition tBUF SDA tSU;STO tVD;ACK tHD;STA tSU;STA 9 8 SCLK S P Sr STOP Condition START Condition Repeated START Condition Figure 37. I2C Timing Diagram Table 26. I2C Timing Requirements All Min and Max limits are specified over temperature and rated operating voltage with 255 Ohm resistor and 550 pF output load unless otherwise stated. Typical values are at 25°C and nominal supply voltage. Parameter Symbol SCLK clock frequency Low period of SCLK clock Standard mode Fast mode plus [14] Fast mode Min. Typ. Max. Min. Typ. Max. fSCLK – – tLOW 470 – 100 – – – 1300 – High period of SCLK clock tHIGH 400 Rise time of both SCLK and SDA tr – – – 600 – 120 – Fall time of both SCLK and SDA tf 30 – 300 Hold time for Start condition tHD;STA 4000 – Setup time for Start condition tSU;STA 470 Data setup time tSU;DAT Data hold time tHD;DAT Data valid time Unit Min. Typ. Max. 400 – – 1000 kHz – 500 – – ns – – 260 – – ns – 120 – – 120 ns 30 – 300 30 – 120 ns – 600 – – 260 – – ns – – 600 – – 260 – – ns 250 – – 100 – – 50 – – ns 0 – – 0 – – 0 – – ns tVD;DAT – – 3450 – – 900 – – 450 ns Data valid acknowledge time tVD;ACK – – 3450 – – 900 – – 450 ns Setup time for stop condition tSU:STO 400 – – 600 – – 260 – – ns I2C bus free time between stop and start tBUF 470 – – 1300 – – 500 – – ns Notes: 14. Fast mode plus is not supported in Extended Industrial temperature range. Rev 1.01 Page 35 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator I2C Device Address Modes There are two I2C Address modes: 1) Factory Programmed Mode. The lower 4 bits of the 7-bit device address are set by ordering code as shown in Table 27 below. There are 16 factory programmed addresses available. In this mode, pins 4 and 5 are NC and pin control of the I2C address is not available. 2) A0, A1 Pin Control. This mode allows the user to select between four I2C Device addresses as shown in Table 28. Table 27. Factory Programmed I2C Address Control I2C Address Ordering Code Device I2C Address 0 1100000 1 1100001 2 1100010 3 1100011 4 1100100 5 1100101 6 1100110 7 1100111 8 1101000 9 1101001 A 1101010 B 1101011 C 1101100 D 1101101 E 1101110 F 1101111 Rev 1.01 Table 28 is only valid for the ordering option which does not use the I2C address pins A0, A1. Table 28. Pin Selectable I2C Address Control A1 Pin 4 A0 Pin 5 I2C Address 0 0 1100000 0 1 1100010 1 0 1101000 1 1 1101010 Ordering Information Table is only valid for the ISP-DCXO device option which uses pin control (A0, A1) of the I2C address. This mode corresponds to ordering code “G” in the I2C address section of the ordering code table. Page 36 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator 11 SPI Operation SPI (Serial Peripheral Interface) is a 4-pin synchronous serial protocol that allows a master device to initiate halfduplex communication with one or more slave devices. The pin functions are as follows: The following Figure 38 illustrates the logical connection between one SPI master and 3 SPI slaves. Note that this diagram is shows only an example logical connection and is not a detailed schematic intended to show pull-up resistors and other components which may also be required. SCLK: Serial Clock which supports up to 5 MHz operating frequency. There are two allowed states for idle SCLK state, HI and LOW and these states are called clock phase. There are also two modes for clock sampling edge, rising edge and falling edge and these modes are called clock polarity. Since there are two allowed clock phases and two allowed clock polarities, this means there are four total modes of SPI operation as illustrated below in Figure 39. MOSI: Master Output Slave Input. This is the data input pin to the SiT3521 and is used by the master to write data to the SiT3521 control registers. MISO: Master Input Slave Output. This is the data output pin of the SiT3521 and is used by the master to read data from the SiT3521 control registers. SS ¯¯ : Active Low SPI Chip Select. This pin is used by the master to select the SiT3521 as the active slave device on the SPI bus. When the master drives the SiT3521 pin low, the SiT3521 is selected as the target of a read or write transaction. Slave 0 Slave 2 SS MISO SCLK MOSI SS MISO SCLK MOSI SS MISO SCLK MOSI SPI Master Slave 1 MOSI MISO SCLK SS0 SS1 SS2 Figure 38. Multi-slave SPI bus connections Mode Mode 0 Mode 1 SCLK Polarity SCLK_POL Low At Start SCLK Phase SCLK_PHA Rising Edge Low At Start Falling Edge Falling Edge Mode 2 High At Start Mode 3 High At Start Rising Edge Figure 39. SPI operation modes Rev 1.01 Page 37 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator The SiT3521 can support all four operating modes. By default, modes 0 and 3 are supported, but modes 1 and 2 can be supported in the future. The serial byte interface format is shown below: 8-bit command (read or write), 8-bit SPI address and 16-bit data. The serial order is most significant bit (MSB) first. The SPI protocol also supports auto address incrementing which means the address will automatically increment after the first transaction. Auto address incrementing will result in higher data throughput when writing to registers with contiguous addresses. If it is required to write to noncontiguous addresses, a write command and register address must be used for each transaction after the delay (125 us min). Without such delay, the device will consider command and address bytes as a data for the consequent register. Command[7:0] WRITE: 57h READ: A5h The detail register descriptions are covered in the I2C/SPI Control Registers. A description of DCO control is in DCO Functional Description and a description of changing the output center frequency is in any-frequency Functional Description. The below Figure 41 shows the timing diagram for modes 0 and 3. Address[7:0] Data[15:0] 00: DCXO Frequency Control 01: DCXO Frequency Control, OE 02: DCXO Pull Range Control 03: PFM Control 04: PFM Control 05: PLL Post Divider Control Differential Drive Strength 06: Differential Driver Control Figure 40. SPI control word format Rev 1.01 Page 38 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator VIH SS VIL tSCLK tsSU tHIGH tsH SCLK tdSU tdH tLOW MOSI tV VOH MISO VOL Figure 41. SPI Timing Diagram (Mode 0/3) Table 29. SPI Timing Requirements[15] Symbol Min. Typ. Max. Unit Setup time for MOSI to SCLK Rising Edge Parameter tdSU 28 – – ns Hold time for MOSI to SCLK Rising edge tdH 1 – – ns tv – – 30 ns Period of SCLK tSCLK – – 200 ns High Width of SCLK tHIGH – tSCLK/2 – ns Low Width of SCLK tLOW – tSCLK/2 – ns Setup time for SSB falling edge to SCLK rising edge tsSU 1.5*tSCLK – – ns Hold time from SSB rising edge to SCLK rising edge tsH 1.5*tSCLK – – ns Time from active edge of SCLK clock to valid MISO data available at pin Notes: 15. SPI is not supported in Extended Industrial temperature range. Rev 1.01 Page 39 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Schematic Examples Figure 42. Schematic Example (LVPECL, I2C mode) Figure 43. Schematic Example (HCSL, I2C mode) Rev 1.01 Page 40 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Schematic Examples (continued) Figure 44. Schematic Example (LVDS, I2C mode) Figure 45. Schematic Example (LVPECL, SPI mode) Rev 1.01 Page 41 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Schematic Examples (continued) Figure 46. Schematic Example (HCSL, SPI mode) Figure 47. Schematic Example (LVDS, SPI mode) Rev 1.01 Page 42 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Dimensions and Patterns Package Size – Dimensions (Unit: mm)[16] Recommended Land Pattern (Unit: mm)[17] 5.0 x 3.2 x 0.85 mm Notes: 16. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of the device. 17. The center pad has no electrical function. Soldering down the center pad to the GND is recommended for best thermal dissipation, but is optional. Rev 1.01 Page 43 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Additional Information Table 30. Additional Information Document Description Download Link ECCN #: EAR99 Five character designation used on the commerce Control List (CCL) to identify dual use items for export control purposes. — HTS Classification Code: 8542.39.0000 A Harmonized Tariff Schedule (HTS) code developed by the World Customs Organization to classify/define internationally traded goods. — Part number Generator Tool used to create the part number based on desired features. https://www.sitime.com/part-number-generator Manufacturing Notes Tape & Reel dimension, reflow profile and other manufacturing related info https://www.sitime.com/support/resource-library/manufacturing-notes-sitimeproducts Qualification Reports RoHS report, reliability reports, composition reports http://www.sitime.com/support/quality-and-reliability Performance Reports Additional performance data such as phase noise, current consumption, and jitter for selected frequencies http://www.sitime.com/support/performance-measurement-report Termination Techniques AN10029 Termination design recommendations http://www.sitime.com/support/application-notes Layout Techniques AN10006 Layout recommendations http://www.sitime.com/support/application-notes Time Master Web Based Configurator Tool to establish proper programming https://www.sitime.com/time-master-web-based-configurator Evaluation Boards SiT6712EB Evaluation Board User Manual https://www.sitime.com/support/user-guides Demo Boards SiT6701DM, SiT6702DM Demo Board User Manual https://www.sitime.com/support/user-guides Rev 1.01 Page 44 of 45 www.sitime.com SiT3521 1 to 340 MHz Elite Platform I2C/SPI Programmable Oscillator Revision History Table 31. Revision History Revisions Release Date 0.1 3-Mar-2017 Change Summary Initial draft 0.2 10-Mar-2017 Added I2C Timing diagram for ISP Function Modified Block Diagram to include approximate MEMS frequency (47 MHz) Updated ISP function procedure Updated Package Drawing 0.21 10-Mar-2017 Added Table 5, I 2C Electrical Characteristics 0.22 11-Oct-2017 Fixed I2C Timing diagram on page 12 to show output disabled when first PFM value is written. Added Output Drive Strength Control to Block Diagram on page 9 Changed PFM Range from 12.59 - 16.34 to 13.83 – 15.43. Changed 156.25 MHz programming example so that it corresponds to the new PFM range. Updated logo and company address, other page layout changes 0.90 2-Apr-2018 Preliminary release 0.99 22-Aug-2018 Updated thermal numbers, fixed minor errors 0.991 25-Apr-2020 ±10 ppm option Updated POD (Dimensions Drawings) Added Evaluation and Demo Boards reference in Additional Information Other page layout changes Added HTS classification code Added 105°C support for I2C operation Increased max operating junction temperature for 70°C and 85°C ambient Updated Frac-N PLL numbers in Table 19 Updated I2C Timing Requirements for “Fall time of both SCLK and SDA” 1.0 4-Nov-2020 Updated I2C Write/Read Sequence section Updated schematics Updated frequency re-programming section Updated register description section Removed HCSL maximum output current specification Changed rev table date format Final release 1.01 30-Apr-2021 Updated Table 17 Updated hyperlink to Manufacturing Notes; Changed date format SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439 © SiTime Corporation 2017-2021. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liabili ty for any loss, damage or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or (iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress. Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below. CRITICAL USE EXCLUSION POLICY BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE. SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly prohibited. Rev 1.01 Page 45 of 45 www.sitime.com
SIT3521AC-2C133-SU50.523333X 价格&库存
很抱歉,暂时无法提供与“SIT3521AC-2C133-SU50.523333X”相匹配的价格&库存,您可以联系我们找货
