PXETGCJANF-20.000000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 20MHz 2.8V~3.3V SMD-4
PXETGCJANF-20.000000 数据手册
PX Type 3.2 x 2.5 mm SMD Crystal Oscillator Actual Size FEATURE - Typical 3.2 x 2.5 x 0.95mm ceramic SMD package. - Tight symmetry (45 to 55%) available. - Operation voltage: 1.8V, 2.5V, 3.3V - Tri-state enable/disable TYPICAL APPLICATION - Computer Peripherals - Set-top Box , HDTV - DSC, PDA RoHS Compliant DIMENSION (mm) SOLDER PAD L AYOUT (mm) 2.10 ± 0.15 #2 #2 0.65 ± 0.15 1.65 ± 0.15 2.50 ± 0.15 #1 #4 #1 1.60 #3 #3 1.10 3.20 ± 0.15 #4 0.1 μF [ B O T T O M V IE W ] [ TO P VIEW ] 2.10 0.90 ± 0.15 Pin# 0.35 0.95 ± 0.15 [ S ID E V IE W ] 1 2 3 4 Function 1.20 Tri-state GND Output VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION Parameter Supply Voltage Variation (VDD) Frequency Range VDD Sensitivity (±10 %) 1 MHz Fo < 30 MHz Supply Current 30 MHz Fo < 75 MHz 75 MHz Fo
PXETGCJANF-20.000000 价格&库存
很抱歉,暂时无法提供与“PXETGCJANF-20.000000”相匹配的价格&库存,您可以联系我们找货
