Ltr
Revisions
Appr
Date
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Electrical Specifications:
Frequency Range
Temperature Stability
Aging per Year
Operating Temperature Range
Standard
Extended
Storage Temperature Range
Supply Voltage
Input Current
Output Voltage
Output Symmetry (Duty Cycle)
2.000 to 10.000 MHz
10.100 to 20.000 MHz
20.100 to 32.000 MHz
32.100 to 50.000 MHz
Logic High (Voh)
Logic Low (Vol)
Standard
Tight
Output Load
Output Level
Phase Jitter (12 KHz to 20 MHz)
Rise and Fall Time
Standby Function
Start Up Time
2.000 to 50.000
±100
±3
-40 to +125
-40 to +85
-55 to +150
+2.5 ± 5% +3.3 ± 5%
6
7
8
7
8
12
90%
10%
40 to 60
45 to 55
15
CMOS
1
7
Tri-State
10
MHz
PPM Max
ºC
Vdd
mA Max
Vdd Min
Vdd Max
pF
ps Max RMS
ns Max
ms Max
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range,
supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year
aging at +25°C.
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Feb 7, 2008
Clock Oscillator
Automotive Temperature Range
Ultra Miniature
2.5 x 2.0 millimeter Surface Mount
General Product Specification
Part Number:
S2 X1 Series
www.aker-usa.com
Mechanical Outline:
Pin1
Pin 3
INH
Output
High or Open
Operating
Low
High Impedance
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: Feb 7, 2008
P/N:
www.aker-usa.com
S2 X1 Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: Feb 7, 2008
P/N:
www.aker-usa.com
S2 X1 Series
How to build a Part Number:
Series
Package
S
2
Parameter
2.5 x 2.0 mm
Supply Voltage
33
25
+3.3 Vdd ± 5%
+2.5 Vdd ± 5%
10
±100 PPM
See Notes
T
40/60%
45/55%
Duty Cycle
Frequency 2.000 to 50.000
MHz
X1
-40 to +125 ºC
Temperature Range
Packaging
R
Tape and Reel
Part Number Example:
S22510-48.000-X1-R
S2: 2.0 x 2.5 mm SMD Package
25: +2.5 Vdd Supply Voltage
10: ±100 PPM Temperature Stability
48.000 MHz Nominal Frequency
X1: -40 to + 125° C Automotive Temperature Range
R: Tape and Reel Packaging
Notes:
1- Standard Duty Cycle does not need to be included in Part Number
description.
2- Product is shipped in Tape and Reel configuration. Each reel contains
1000 pieces.
3- Quantities less than 1000 are shipped bulk in ESD pouches.
4- Specification subject to change without notice.
Page:
4/4
Date: Feb 7, 2008
P/N:
www.aker-usa.com
S2 X1 Series
S21810T-27.000-X1-R 价格&库存
很抱歉,暂时无法提供与“S21810T-27.000-X1-R”相匹配的价格&库存,您可以联系我们找货
