NI-10M-2500
NI-10M-2500
    TAITIEN(泰艺)
    DIP-6
    有源晶振 10MHz 5V DIP-6
NI-10M-2500 数据手册
Our Performance Your Reputation Oven Controlled Crystal Oscillator NI-10 MHz-2500 series 2500 Series in 36.3x27.2mm DIP package NI-10M-2500 series oscillators is designed for applications where space is at a premium and good frequency stability is required. The oscillators can be used in many communications applications. A choice of quartz resonators offers a variety of performance versus cost options to fit most applications. RoHS Compliant Standard ELECTRICAL SPECIFICATIONS 1. OUTPUT (PIN = “R.F. OUTPUT”) Parameter 1.1. Min. Frequency Typ. Max. 10.000000 Unit Test Condition MHz @ +25 ±1°C 1.2. Initial Accuracy -0.1 +0.1 ppm after turn on power 15 ±1 minutes ≤ 90 days following date code VCO Input at Center Voltage ±0.001V 1.3. Waveform 1.4. Level 1.5. Load 1.6. 1.7. 2. Sine wave +6 +10 dBm Harmonics -30 dBc Spurious -60 dBc Max. Unit Ω 50 FREQUENCY STABILITY Parameter 2.1. +8 Min. Ambient Aging 2.2. Typ. ±3, ±5, ±10 ppb -30 ~ +70 -40 ~ +85 °C Test Condition referenced to 25°C Refer to Table 1 : Ordering Information -0.5 +0.5 ppb per day, at time of shipment after 30 days Daily -0.5 +0.5 ppb Yearly -50 +50 ppb 10 Years -0.3 +0.3 ppm -0.5 +0.5 ppb 0.05 ppb/s 2.3. Voltage 2.4. Short term ±5% change 2.5. Load -0.5 +0.5 ppb ±5% change 2.6. Warm-up -10 +10 ppb in 10 minutes @ +25 ±1°C root Allan variance referenced to 1 hour Page 1of 3 Specifications subject to change without notice Rev(1)06/2013 www.taitien.com sales@taitien.com.tw Our Performance Your Reputation Parameter 2.7. 3. Min. Typ. Phase Noise Max. Unit -95 -90 dBc/Hz @ 1Hz -125 -120 dBc/Hz @ 10Hz -140 -135 dBc/Hz @ 100Hz -148 -145 dBc/Hz @ 1KHz -152 -150 dBc/Hz @ 10KHz ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”) Parameter 3.1. Min. Typ. Tuning Range Max. Unit -0.5 ppm VCO @ Min. Voltage ppm VCO @ Max. Voltage +0.5 3.2. Control Voltage 3.3. Slope 3.4. Center Voltage 0 +5.0 V 0 +4.0 V Test Condition Linearity -10 3.6. Input Impedance 100 Optional, Refer to Table 1 : Ordering Information +2.5 V +2.0 V +10 Optional, Refer to Table 1 : Ordering Information kΩ INPUT POWER (PIN = “+VDC”) Min. Typ. Max. Unit 4.1. Voltage +4.75 +5.0 +5.25 V 4.2. Current 800 mA @ turn on 4.3. Steady State 1.3 W @ +25°C Test Condition REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE") (Optional Function. Refer to Table 1 : Ordering Information.) 5.1. 5.2. 6. Note 1 % Parameter 5. Referenced to frequency at nominal Center Voltage Positive 3.5. 4. Test Condition Parameter Min. Typ. Max. Units Voltage +3.8 +4.0 +4.2 V Load 9 Test Condition Over temperature range in 2.1. kΩ ENVIRONMENTAL Parameter 6.1. Operating Temperature 6.2. Storage Temperature Reference Std. -40°C to +85°C Test Condition Note 2 -55°C to +105°C 6.3. Humidity MIL-STD-202, Method 103 Test Condition A 6.4. Vibration (non-operating) MIL-STD-202, Method 201 0.06” Total p-p, 10 to 55 Hz 6.5. Shock (non-operating) MIL-STD-202, Method 213, Test Condition J 30g, 11ms, half-sine Note 1. Note 2. 95% RH @ +40°C,non-condensing,240 hours When not connected, VCO INPUT is internally held at this voltage. Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the temperature range in 2.1. Page 2of 3 Specifications subject to change without notice Rev(1)06/2013 www.taitien.com sales@taitien.com.tw Our Performance Your Reputation Table 1 : ORDERING INFORMATION TAITIEN Model No. ppb ±3 ±5 ±10 NI-10M-2500 NI-10M-2503 NI-10M-2550 NI-10M-2553 NI-10M-2501 NI-10M-2504 NI-10M-2551 NI-10M-2554 NI-10M-2502 NI-10M-2505 NI-10M-2552 NI-10M-2555 Temp. (℃ ℃) -30~+70 -40~+85 -30~+70 -40~+85 Control Voltage Reference Voltage +2.5V N/A +2.0V +4.0V OUTLINE DRAWING Page 3of 3 Specifications subject to change without notice Rev(1)06/2013 www.taitien.com sales@taitien.com.tw
NI-10M-2500 价格&库存
很抱歉,暂时无法提供与“NI-10M-2500”相匹配的价格&库存,您可以联系我们找货
NI-10M-2500
  • 5+690.176055+89.28481
