8Z-18.432MAHE-T
8Z-18.432MAHE-T
    TXC(台晶)
    SMD2520_4P
    无源晶振 100Ω 12pF ±30ppm -40℃~+85℃ 18.432MHz SMD2520_4P
8Z-18.432MAHE-T 数据手册
8Z MHz Crystal Features Applications Frequency range : 12MHz to 66MHz Ceramic SMD package Seam sealing External dimensions (mm) L : 2.5 x W : 2.0 x H : 0.55 RoHS compliant & Pb free Bluetooth, Wireless LAN Microprocessor Mobile phone, Computer, Modem Audio, Video Consumer products Electrical Characteristics Item 8Z Frequency Range F0 12MHz ~ 66MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 Drive Level DL 1 ~ 200μW (100μW Typ.) Load Capacitance CL 6pF, 8pF, 10pF 12pF, 16pF, 18pF, 20pF Aging (at 25°C ± 3°C, first year) Faging ±3ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C 3pF Max. Note [1] Notes: [1] Please contact us for low aging +/-1ppm grade crystals. Motional Resistance (ESR) Fundamental 12 ~ 13 MHz 14 ~ 30 MHz 30 ~ 66 MHz Rev. 1.08 150Ω Max. 100Ω Max. 60Ω Max. Page 1 www.txccrystal.com 8Z MHz Crystal Dimensions (Unit: mm) Ordering Information 8Z - 24.000M A H E Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E B V Q E I J K ± 30 ppm ± 20 ppm ± 10 ppm 6 pF 8 pF 10 pF 12 pF 16 pF 18 pF 20 pF Frequency Stability (over Temp.) A D E T H I K Rev. 1.08 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 30 ppm ± 20 ppm ± 60 ppm ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.txccrystal.com 8Z MHz Crystal Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.08 60 sec Page 3 Time (sec) www.txccrystal.com
8Z-18.432MAHE-T 价格&库存
很抱歉,暂时无法提供与“8Z-18.432MAHE-T”相匹配的价格&库存,您可以联系我们找货
8Z-18.432MAHE-T
  • 1+7.674081+0.99285
  • 10+6.6547810+0.86098
  • 25+6.2916825+0.81400
  • 50+6.0321050+0.78042
  • 100+5.78309100+0.74820
  • 250+5.46890250+0.70755
  • 500+5.24277500+0.67830
  • 1000+5.025911000+0.65024
库存:11090
8Z-18.432MAHE-T
  • 3000+4.700663000+0.60816
  • 6000+4.506536000+0.58304
  • 9000+4.396759000+0.56884
  • 15000+4.2623615000+0.55145
  • 21000+4.1761421000+0.54030
库存:11090
