STC53C33O48-20.000MT 数据手册
Ceramic SMT 4 Pad CMOS (VC)TCXO
STC53C Series
5.0mm x 3.2mm
Features
Applications
• ±1.0ppm (Frequency Stability) Available
• Base Stations
• CMOS
• IP networking
• (VC)TCXO
• Cellular and Cordless Phones
• Tape and Reel
Part Numbering Guide
STC 53 C 33 R 48 V E - 19.440M
SUNTSU TCXO
FREQUENCY
MHz
5.0mm x 3.2mm
CMOS
SUPPLY VOLTAGE
25 : 2.5V±5%
27 : 2.7V±5%
30 : 3.0V±5%
33 : 3.3V±5%
CO M P L I A N T
Cage Code: 4GUT4
To customize your parameters contact a Suntsu representative.
Electrical Parameters
FREQUENCY STABILITY
N : ±5.0ppm
O : ±2.5ppm
P : ±2.0ppm
Q : ±1.5ppm
R : ±1.0ppm
Typical
OPERATING
TEMPERATURE RANGE
07 : 0°C - +70°C
16 : -10°C - +60°C
17 : -10°C - +70°C
27 : -20°C - +70°C
38 : -30°C - +85°C
48 : -40°C - +85°C
TCXO/VCTCXO
BLANK : TCXO
V : VCTCXO
Maximum
PULLABILITY
BLANK : TCXO
E : ±12.0ppm
F : ±8.0ppm
G : ±5.0ppm
Units
Minimum
Frequency Range
MHz
6
Remarks
Frequency Tolerance at +25ºC
ppm
-1.5
+1.5
I hour after Reflow
Freq. Stability vs. Op Temp.
ppm
-1.0
+1.0
See part numbering guide for options.
40
Freq. Stability vs. Supply Voltage
ppm
-0.3
+0.3
VDD ±5% Change
Freq. Stability vs. Load
ppm
-0.3
+0.3
±5% Change
Freq. Stability vs. Aging
ppm
-1.0
+1.0
1 Year
Operating Temperature
°C
-40
+85
Storage Temperature
°C
-55
Supply Voltage (VDD)
V
3.135
Current (IDD)
Current Voltage (VC, VCTCXO)
Pullability (VCTCXO)
+125
3.3
mA
3.465
6
V
VDD
Center Voltage: VDD*50%
ppm
±5.0
±12.0
Linearity (VCTCXO)
10
Output Load (CMOS)
pF
15
Output Logic HIGH Level (VOH)
V
Output Logic LOW Level (VOL)
V
Rise (TR) And Fall (TF) Time
ns
Symmetry (Duty Cycle)
Start-Up Time
ms
VC Input Impedance (VCTCXO)
kΩ
0.8*VDD
0.2*VDD
5
40
60
3
100
Phase Noise (Typical) 10Hz Offset
dBc/Hz
-85
Phase Noise (Typical) 100Hz Offset
dBc/Hz
-115
Phase Noise (Typical) 1KHz Offset
dBc/Hz
-135
Phase Noise (Typical) 10KHz Offset
dBc/Hz
-145
Phase Noise (Typical) 100KHz Offset
dBc/Hz
-150
www.suntsu.com
Specifications are subject
to change without notice.
Suntsu Electronics, Inc.
142 TECHNOLOGY DR., SUITE 150
IRVINE, CA 92618
Call: +1-949-783-7300 | Fax: +1-949-783-7301
STC53C Series
5.0mm x 3.2mm
Outline Drawing & Land Pattern
All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale.
Test Circuit (CMOS)
Waveform (CMOS)
Typical Phase Noise Performance (Measured By Agilent E5052A)
Frequency - 19.440MHz
www.suntsu.com
Frequency - 40.000MHz
IRVINE, CA 92618
STC53C Series
5.0mm x 3.2mm
Typical Jitter Performance (Measured By Agilent E5052A)
Reflow Profile
Part Marking
Tp (Time At 260°C. 20-40 Sec)
260
Rup (Ramp Up, 3°C/Sec Max)
217
Temperature (°C)
200
TI (Time Above 217°C.
60-150Sec)
150
Rdn (Ramp Down,
6°C/Sec Max)
Ts (Preheat Time.
60-180Sec)
T 25°C to Peak (480Sec Max)
Time (sec)
Tape And Reel Dimensions
3,000pcs/Reel
www.suntsu.com
IRVINE, CA 92618
STC53C Series
5.0mm x 3.2mm
Environmental Specifications
Mechanical Specifications
Temperature Cycling
MIL-STD-883, Method 1010, Condition B
Mechanical Shock
MIL-STD-202, Method 213, Condition B
Fine Leak Test
MIL-STD-883, Method 1014, Condition A
Vibration
MIL-STD-883, Method 2007, Condition A
Gross Leak Test
MIL-STD-883, Method 1014, Condition C
Moisture Resistance
MIL-STD-883, Method 1004
Solderability
MIL-STD-883, Method 2003
Resistance to Solvents
MIL-STD-202, Method 215
Moisture Sensitivity
J-STD-020, MSL 1
Resistance to Soldering Heat
MIL-STD-202, Method 210, Condition K
www.suntsu.com
IRVINE, CA 92618
STC53C33O48-20.000MT 价格&库存
很抱歉,暂时无法提供与“STC53C33O48-20.000MT”相匹配的价格&库存,您可以联系我们找货
