VLCUWCWTNF-100.000000 数据手册
High Frequency, Very Low Noise and
Low g-Sensitivity VCXO VLCU-Type series
14 x 9mm SMD package
Actual Size
FEATURE
- VLCU-Type series is a high frequency high performance VCXO offering high
frequency and very low phase noise/Low g-Sensitivity. The part comes in a
small SMD package which makes it suitable for reflow soldering during pick
and place assembly.
- Low Phase Noise
- Low g-Sensitivity
- Small SMD Package
- Low Power Consumption
TYPICAL APPLICATION
- Instrument
- Microwave Communication
- Test & Measurement
- Telecom Systems
- Satellite Communication
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ BOTTOM VIEW ]
[ TOP VIEW ]
5.08 ± 0.10
6.00 ± 0.10
9.10 ± 0.15
#2
#2
5.08 ± 0.10
#1
2.54
[ SIDE VIEW ]
5.08
1.524
3.60 ± 0.15
#1
#4
5.5
#3
#3
1.55 ± 0.10
13.90 ± 0.10
#4
RoHS Compliant
12.90 ± 0.20
Pin#
1
2
3
4
Function
Vcon
1.6
GND
Output
VDD
ELECTRICAL SPECIFICATION OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
Frequency (Fo)
Frequency Stability
(Overall)
Min.
Typ.
Max.
Unit
50
125
MHz
-25
+25
ppm
Operating Temperature
Range
-20oC ~ +70oC
-40oC ~ +85oC
o
Storage Temperature
Range
-45oC ~ +90oC
o
Waveform
Level
C
C
Sine wave
+10
Load
dBm
50
Harmonics
-30
g-Sensitivity
Phase Noise
(Max.)
Test Condition
Standard Frequency: 100MHz,
122.88MHz, 125MHz
Frequency stability includes
frequency tolerance@25oC
and frequency stability vs.
operating temperature range
and voltage variance and 10
years aging.
1.5
dBc
ppb/g
100MHz
122.88MHz
125MHz
-84
-117
-144
-165
-172
-175
-80
-112
-142
-163
-172
-175
-80
-112
-142
-163
-172
-175
dBc/Hz
dBc/Hz
dBc/Hz
dBc/Hz
dBc/Hz
dBc/Hz
Refer to Ordering Information
@ 10Hz
@ 100Hz
@ 1KHz
@ 10KHz
@ 100KHz
@ 1MHz
Note: not all combination of options are available. Other specifications may be available upon request.
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(10) 09/2021
83
ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
Pulling Range
Min.
Typ.
±30
Control Voltage
Positive
Center Voltage
+2.5
VC Input Impedance
Test Condition
V
V
-10
Modulation Bandwidth
Unit
ppm
Slope
Linearity
Max.
+10
1
KHz
100
Mohm
INPUT POWER (PIN = “+VDC”)
Parameter
Min.
Typ.
Max.
Voltage
+4.75
+5
+5.25
V
30
mA
Current
Unit
Test Condition
At maximum supply voltage
ENVIRONMENTAL
Parameter
Reference Std.
Vibration Test
DIN EN 60068-2-6
Thermal Shock
DIN EN 60068-2-14
Mechanical Shock
DIN EN 60068-2-27
Test Condition
10~55Hz, 0.75mm Peak; 55~2000Hz, 10g Peak.
10 Cycles; 3 axis; 1Oct./min.
30 min. @each temperature 10 cycles,
Transfer
VLCUWCWTNF-100.000000 价格&库存
很抱歉,暂时无法提供与“VLCUWCWTNF-100.000000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+190.88831100+22.80995
- 国内价格 香港价格
- 1+261.470561+31.24408
- 10+226.0714110+27.01410
- 50+204.3506050+24.41860
