CTP3-32.768-6-20-R
CTP3-32.768-6-20-R
    AKER(安碁科技)
    SMD8038_4P
    无源晶振 50Ω 6pF ±20ppm -20℃~+70℃ SMD8038_4P 32.768KHz
CTP3-32.768-6-20-R 数据手册
RoHS Compliant Pb - Lead Free Ltr Revisions Appr Date Electrical Specifications: Nominal Frequency Frequency Tolerance at 25º C Aging Turnover Temperature Temperature Coefficient Temperature Range (Operating) Temperature Range (Storage) Equivalent Series Resistance Load Capacitance Shunt Capacitance Motional Capacitance Drive Level Insulation Resistance Quality Factor Capacitance Ratio Resistance to Shock Standard Optional Standard Optional Standard Optional 32.768 ±20 ±15 ±3 (first year) 25 ±5 -0.035 ± 0.008 PPM/ ºC² -10 to +60 -40 to +85 -55 to +125 50 12.5 6.0 1.5 3.0 1.0 500 at at 100 Vdc ± 15 Vdc 70000 450 ±5 PPM maximum offset from 75 cm drop test in all axes on to a hard surface. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: June 10, 2006 Microprocessor Crystal Unit 32.768 KHz 3.8 x 8.0 millimeter Surface Mount Thermoplastic Package General Product Specification Part Number: CTP3-32.768-12.5-20 www.aker-usa.com KHz PPM ºC K Ohm Max pF pF Typ fF Typ uW Max M Ohm Min Typ - Mechanical Outline: Package is Thermoplastic. Dimensions are millimeters. PCB Solder Pad Layout: Pad Connection: Top View Page: 2/4 Date: June 10, 2006 P/N: CTP3-32.768-12.5-20 www.aker-usa.com Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: June 10, 2006 P/N: CTP3-32.768-12.5-20 www.aker-usa.com How to build a Part Number: Series Package Frequency Load Capacitance Standard Option Frequency Tolerance Standard Option Standard Temperature Range Option Packaging CTP 3 32.768 12.5 6 20 15 See Notes X R - Parameter 3.8 x 8.0 mm Thermoplastic SMD KHz - 12.5 pF 6 pF - ±20 PPM ±15 PPM - -10 to +60 ºC -40 to +85 ºC - Tape and Reel Part Number Example: CTP3-32.768-12.5-20-R CTP3- 3.8 x 8.0 mm Thermoplastic SMD Package 32.768 KHz Nominal Frequency 12.5 pF Load Capacitance 20: ±20 PPM Frequency Tolerance -10 to +60° C Temperature Range R: Tape and Reel Packaging Frequency vs. Temperature Characteristics: To calculate the frequency stability the parabolic curvature constant (K) is needed. For calculating the stability at 45 ° C? 1- Change in temperature (T) is (45-25) = +20 ° C 2 2- Change in frequency is (-0.035 x (° C) ) = 2 (-0.035 x (20) = -14 PPM Notes: 1- Standard Temperature Range does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 3000 pieces. 3- Quantities less than 3000 are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date: June 10, 2006 P/N: CTP3-32.768-12.5-20 www.aker-usa.com
CTP3-32.768-6-20-R 价格&库存
很抱歉,暂时无法提供与“CTP3-32.768-6-20-R”相匹配的价格&库存,您可以联系我们找货
