CTED-A5B3-311.04TS
CTED-A5B3-311.04TS
    CARDINALCOMPONENTS
    SMD-6
    有源晶振 3.3V 311.04MHz SMD-6
CTED-A5B3-311.04TS 数据手册
CARDINAL CARDINAL COMPONENTS COMPONENTS LVPECL Surface Mount TCXO * Serial Communications * Routers * Switches * WAN Interfaces * Test Equipment * LVPECL Output * Industry Standard Outline Part Numbering Example: SERIES CTED CTED Z - A5 B3 - 222.5792 TS A5 Z CTED CTED Applications B3 OPERATING TEMP. PACKAGING OPTIONS Blank = 0°C ~ +70°C Blank = Bulk A5 = -20°C ~ +70°C Z = Tape and Reel STABILITY B3 = ±2.5 ppm 222.5792 TS FREQUENCY TRI-STATE TS = Tri-State CTED Max Unit 38 640 MHz Stability: - 2.5 + 2.5 ppm Supply Voltage: 3.135 3.465 V Specifications: Min Frequency Range: Typ 3.3 Operating Temperature: -30 + 70 °C Storage Temperature: -40 + 85 °C Duty Cycle: 45 55 % 10 mS 1 ppm 100 mA Start-Up Time: 3 Aging: (ppm/1st Year) Ta=25C, Vdd=3.3V Supply Current: Short Circuit Current: ± 50 mA RMS Period Jitter: 5 pS RMS Integrated Jitter: 12kHz to 20MHz 0.7 pS Phase Noise @ 10kHz: Output Voltage: Voh Vol Rise/Fall Time: Output Level: Packaging: -120 dBc/Hz Vdd - 1.62 V V 0.8 nS Vdd - 1.025 0.4 LVPECL Dimensions are in mm PIN Function 1 DISABLE 2 NO CONNECT 3 Ground 4 LVPECL + 5 LVPECL 6 Vdd LVPECL Levels Test Circuit Vdd Tape and Reel 1000 pcs per Reel OUT 50Ω 50Ω ___ OUT Cardinal Components, Inc., 155 Rt. 46 W, Wayne, NJ. 07470 TEL: (973)785-1333 FAX: (973)785-0053 E-Mail: sales@cardinalxtal.com http://www.cardinalxtal.com  Rev.3-6/11/07 2.0 V
CTED-A5B3-311.04TS 价格&库存
很抱歉,暂时无法提供与“CTED-A5B3-311.04TS”相匹配的价格&库存,您可以联系我们找货
