CTVL-A5B3-622.08TS
CTVL-A5B3-622.08TS
    CARDINALCOMPONENTS
    SMD-6
    有源晶振 3.3V 622.08MHz SMD-6
CTVL-A5B3-622.08TS 数据手册
CARDINAL CARDINAL COMPONENTS COMPONENTS LVDS Surface Mount TCVCXO * Serial Communications * Routers * Switches * WAN Interfaces * Test Equipment * LVDS Output * Industry Standard Outline Part Numbering Example: CTVL Z - A5 B3 - 222.5792 TS A5 Z CTVL SERIES CTVL CTVL Applications B3 PACKAGING OPTIONS OPERATING TEMP. Blank = 0°C ~ +70°C Blank = Bulk A5 = -20°C ~ +70°C Z = Tape and Reel STABILITY B3 = ±2.5 ppm 222.5792 TS FREQUENCY TRI-STATE TS = Tri-State CTVL Specifications: Min Frequency Range: 38 Stability: - 2.5 Supply Voltage: 3.135 3.3 Max Unit 640 MHz + 2.5 ppm 3.465 V 3.0 V -30 + 70 °C -40 + 85 °C 45 55 % 10 mS 1 ppm 100 mA External Control Voltage: 0.35 Operating Temperature: Storage Temperature: Start-Up Time: 3 Aging: (ppm/1st Year) Ta=25C, Vdd=3.3V Supply Current: Short Circuit Current: ± 50 mA RMS Period Jitter: 5 pS RMS Integrated Jitter: 12kHz to 20MHz 0.7 pS Phase Noise @ 10kHz: Output Voltage: Voh Vol Output Differential Voltage: Rise/Fall Time: Output Level: Packaging: -120 dBc/Hz Vdd - 1.6 V V 454 mV Vdd - 0.9 247 355 0.4 Dimensions are in mm ppm +/- 8 Frequency Tuning Range: Duty Cycle: Typ 0.8 nS LVDS PIN Function 1 VCONTROL 2 ENABLE 3 Ground 4 LVDS + 5 LVDS 6 Vdd LVDS Levels Test Circuit OUT Tape and Reel 1000 pcs per Reel 50 Ω Vo 50 Ω ___ OUT Cardinal Components, Inc., 155 Rt. 46 W, Wayne, NJ. 07470 TEL: (973)785-1333 FAX: (973)785-0053 E-Mail: sales@cardinalxtal.com http://www.cardinalxtal.com  Rev.3-6/11/07
CTVL-A5B3-622.08TS 价格&库存
很抱歉,暂时无法提供与“CTVL-A5B3-622.08TS”相匹配的价格&库存,您可以联系我们找货
